Chord Diagram Sort by?
CFT6Server
What is the default Chord Diagram sorted by? The amount of Flows? Bytes?
Re: Chord Diagram Sort by?
This is actually a really good question and not one I have an answer to right now. Doesn't seem to be based on the IP/port, and I saw plenty of screenshots where the chunks were not going from biggest to smallest. I've asked the developers for comment and I will update you when I get a reply.
Update: I was told it should be sorted by amount of bytes.
