Nagios 3.5 / NagioSQL auto write config
phpsteve
Post by phpsteve »
Have not found any information on this version. I have had everything automated for a long time and off and on I try and dabble some with auto writing out the services/config which is in DB to file. I have yet to be successful in getting this to work as post data doesn't work and there are no API's that I know of to do this. Any thoughts or anyone know of a way to auto-write services.cfg in nagiosql against core 3.5?
Re: Nagios 3.5 / NagioSQL auto write config
This would be possible in XI using our API, but as NagiosQL is not our project I can't speak to whether an API exists or how to do this. You would probably have better luck reaching out to their authors on their forums.
phpsteve
Post by phpsteve »
Thanks for the information. I will likely end up moving over in the future anyways.
Is there anything else we can help you out with, or can I close this thread out?
