After a recent upgrade to XI 5.2.3 we're starting to notice the Monitoring Engine stops across several XI hosts at random times. Seems to be after a few hours though. This is occurring on XI hosts with both moderate and low load.
Nothing really stands out in /var/log/messages
Please advise.
Monitoring Engine randomly stops in Nagios XI 5.2.3
Nagios XI 2024R2.2.1 (8 Servers)
Nagios Fusion 2024R1.0.2
Re: Monitoring Engine randomly stops in Nagios XI 5.2.3
This is the first report of this that I have seen. Does it not come back up until you start it? What logs have you checked?
Former Nagios Employee.
me.
me.
No it does not, requires manual start. I've checked /var/log/messages only.hsmith wrote:This is the first report of this that I have seen. Does it not come back up until you start it? What logs have you checked?
Can you take a look at /usr/local/nagios/var/nagios.log and see if there is anything telling?
me.
me.
Another oddity worth mentioning is that the system check located top right in the header menu indicates "Monitoring Engine stopped" with a red icon, but the Admin > System Status > XI System Component Status is indicates running with a green icon.
UPDATE: NOT ALWAYS THE CASE. Engine stopped again and the icon was red in both interfaces.
A few obscure "[1449858778] External command error: Command failed", but nothing else that stands out.hsmith wrote:Can you take a look at /usr/local/nagios/var/nagios.log and see if there is anything telling?
Can you post the result of tail -n200 /usr/local/nagios/var/nagios.log for us to actually take a look at?
Emailed as an attachment to xisupportrkennedy wrote:Can you post the result of tail -n200 /usr/local/nagios/var/nagios.log for us to actually take a look at?
Engine stopped again. Seems to happen roughly every 6 hours.
Yo say this is happening on multiple XI hosts? All the same symptoms?
Nagios XI 5.8.1
https://outsideit.net
