MRTG / Status check and port number
CFT6Server
I noticed that if you use non-standard port for SNMP and enters that in the Network switch wizard, it will configure the bandwidth check correctly, but it will not update the port status check with the port number. So on the ones I am using nonstandard port (161), then I have to manually edit each $ARG3$ in status check and add in the -p option.
Re: MRTG / Status check and port number
Thanks for reporting this - I have verified the issue and reported it as a bug. Thank you!
The internal bug ID is 7269.
