Upgrade fails from 5.2.0 to 5.2.3
Please find attached log
br,
Peter Calum
TDC
Denmark
Peter Calum
Re: Upgrade fails from 5.2.0 to 5.2.3
Do you have the "Config::Tiny" perl module installed? Try running the following command to install the package:
then rerun the upgrade. Did this help?
yum install perl-Config-TinyBe sure to check out our Knowledgebase for helpful articles and solutions!
Hi
It was not able to find this module
Loaded plugins: product-id, rhnplugin, security, subscription-manager
This system is receiving updates from RHN Classic or RHN Satellite.
Setting up Install Process
No package perl-Config-Tiny available.
Error: Nothing to do
uname -a
Linux khk9dsg25.ip.tdk.dk 2.6.32-573.7.1.el6.x86_64 #1 SMP Thu Sep 10 13:42:16 EDT 2015 x86_64 x86_64 x86_64 GNU/Linux
[root@khk9dsg25 ~]# cat /etc/redhat-release
Red Hat Enterprise Linux Server release 6.7 (Santiago)
rgds,
Peter
uname -a
rgds,
Peter
Peter Calum
I found the rpm here :
http://pkgs.org/centos-6/centos-i386/pe ... h.rpm.html
And then it worked.
Starting httpd:
UPGRADE COMPLETED!
Peter Calum
TDC
Denmark
And then it worked.
Starting httpd:
UPGRADE COMPLETED!
Peter Calum
TDC
Denmark
Peter Calum
Good to see that worked, still weird it couldn't find it in the repo.
Is there anything else we can do for you in this thread?
Former Nagios Employee.
me.
me.
We can close this issue
thanks,
Peter Calum
TDC, Denmark
thanks,
Peter Calum
TDC, Denmark
Peter Calum
Hi
Tried a yum search install name is perl-Config-Tiny.noarch
I think you try to install with a wrong name in ./upgrade script
[root@khk9dsg25 ~]# yum search perl-Config-Tiny
================================================== N/S Matched: perl-Config-Tiny ===================================================
perl-Config-Tiny.noarch : Perl module for reading and writing .ini style configuration files
Name and summary matches only, use "search all" for everything.
[root@khk9dsg25 ~]#
[root@khk9dsg25 ~]# yum install perl-Config-Tiny.noarch
Nothing to do
[root@khk9dsg25 ~]#
/Peter
[root@khk9dsg25 ~]#
Nothing to do
[root@khk9dsg25 ~]#
/Peter
Peter Calum
Interesting, when I do a yum search for perl-Config-Tiny I get nothing found as well:
But "yum install perl-Config-Tiny" and "perl-Config-Tiny.noarch" both work for me..
: configuration filesBut "yum install perl-Config-Tiny" and "perl-Config-Tiny.noarch" both work for me..
