Are these events simply being sent to a syslog input, or are there any filters involved? If it's just the syslog input, let's observe the following:
Default syslog input filter:
<%{POSINT:priority}>(?:%{SYSLOGTIMESTAMP:timestamp}|%{TIMESTAMP_ISO8601:timestamp8601}) (?:%{SYSLOGFACILITY} )?%{SYSLOGHOST:logsource} %{SYSLOGPROG}:%{SYSLOGBASE2} %{GREEDYDATA:message}
Your log:
<166>Dec 14 13:37:45 10.0.106.152 f46715f-f625-002481e8dc5 esxhost.me.net Vpxa: / /vmfs/volumes/55cb3008-4356f04a-1d59-002481e8dc5c/ /vmfs/volumes/55c34512-4dc40a26-a712-002481e8dc5c/ /vmfs/volumes/55cb3064-927b61d2-c3a7-002481e8dc5c/ /vmfs/volumes/55c345c4-21f16885-19ee-002481e8dc5c/ /vmfs/volumes/55cb3049-dc9f4850-41d3-002481e8dc5c/
Plugging both of them into a
debugger gives us the following result:
Not the result we were looking for. After some playing around, it looks like your log doesn't match the syslog input because it doesn't match the standard syslog format:
Notice that the default filter matches:
Meaning that the program must come immediately after the logsource. In a log that follows the format exactly, you'll see something like this:
Dec 14 08:51:01 localhost kernel:
For some reason your log includes the 'f46715f-f625-002481e8dc5 esxhost.me.net ' bit of information, which appears to throw out filter off. You'll likely have to design a custom filter to fit your ESXI syslogs:
http://support.nagios.com/forum/viewtop ... 37&t=32221
http://support.nagios.com/forum/viewtop ... 68#p134768
Less long:
http://support.nagios.com/forum/viewtop ... 28#p137728
This pattern may give you a good start:
https://github.com/harrytruman/logstash ... stash.conf
