Upgrade banner says fail, but log says completed
krobertson71
Post by krobertson71 »
Subject says it all. I run through the update via the GUI. It completes with 0 errors (A lot of warning for contact groups etc but this is just a test box) but the box at the top reads "The upgrade did not complete successfully. The version number shows the updated 5.2.3 but no upgrade snapshot is available.
Screenshots below:
krobertson71
Re: Upgrade banner says fail, but log says completed
When I click "Check for updates" at the bottom of the screen next to the current version number, it takes me to the Nagios page and states that I am at the current version.
When I go to admin>Check For Updates I get the screenshot above with the red banner still showing, log saying everything is good, but no upgrade config to rollback.
I have restarted Nagios and "Applied Configuration" both successfully but still no change in the screenshot above.
hsmith
Agent Smith
Post by hsmith »
That's just a display bug, the upgrade should have completed successfully. I believe 5.2.3 has the fix that will make subsequent upgrades no longer show this error.
Former Nagios Employee.
me.
krobertson71
Yeah everything seems fine. I did find the autobackup that was made.
I checked out a lot and all seems well.
Thanks for the update.
Close er down.
hsmith
Agent Smith
Post by hsmith »
Glad to hear it's good. I'll close this thread.
me.
