Passive alerts returning as missing randomly and then OK
illectronic
Post by illectronic »
I have 4 servers sending passive checks to nagios core 3. The checks are making it there, but sometimes it says "plugin out of bounds" and these are critical alerts so we receive emails. Within 30 seconds it refreshes and goes to an OK state. Below is the cron and script sending data via nsca.
Thanks.
*/2 * * * * /opt/home/cl/cron_for_aws
MASTER_PORT_A=5667
MASTER_HOST_AWS=ip
ROOT=~cloverleaf/libexec
NSCA=${ROOT}/send_nsca
NSCA_AWS=${ROOT}/send_nsca_1.9
NSCA_AWS_CMD="-H ${MASTER_HOST_AWS} -p ${MASTER_PORT_A} -c ${NSCA}.cfg"
ECHO="/bin/echo -e"
tempfile=/tmp/cldp-nsca-aws.$$
trap "rm $tempfile" 0 1 2 15
# these must get changed per host and per service
this_host='saturn'
# format of the file must be
# hostname_in_nagios service_name_in_nagios status extended
# check for mysql replication
x=`${ROOT}/check_mysql -ucl-ppass -S`
status=$?
x=${x##REPLICATION }
message=${x##*:}
line="${this_host}\tmysql_replication\t${status}\t${x}"
echo $x
$ECHO $line > $tempfile
$NSCA_AWS $NSCA_AWS_CMD < $tempfile
# check for mysql at ALL
x=`${ROOT}/check_mysql -ucl -ppass`
status=$?
x=${x##MYSQL }
message=${x##OK }
line="${this_host}\tmysql_status\t${status}\t${message}"
# check for disk space
x=`${ROOT}/check_disk -w 10% -c 5% -p /`
status=$?
x=${x##DISK }
message=${x##* }
line="${this_host}\tdisk_space\t ${status}\t${message}"
# check for /opt space
x=`${ROOT}/check_disk -w 10% -c 5% -p /opt`
status=$?
x=${x##DISK }
message=${x##* }
line="${this_host}\topt_space\t ${status}\t${message}"
# check for file
MAGIC_FILE=~cl/html/images/SENTINEL
x=`${ROOT}/check_file_age -w 600 -c 900 -f ${MAGIC_FILE}`
status=$?
#status=${x%% *}
message=${x##*-}
line="${this_host}\tcheck_rsync\t${status}\t${message}"
# check for activity
# needs to be in the ginger directory
cd ~cl/html/riviera/
x=`/usr/bin/php ~cl/html/riviera/ck_activity.php`
status=$?
#status=${x%% *}
message=${x##*-}
line="${this_host}\tweb_active\t${status}\t${message}"
# check for News update
x=`/usr/bin/php ~cl/libexec/saturn-mysql-check.php`
status=$?
message=${x##*-}
line="${this_host}\tnews_update\t${status}\t${message}"
(Additional information added by Jesse):
-Upgraded recently from CentOS 5 to CentOS 7
-Upgraded recently from Nagios Core 3.x to a higher version of 3.x
-send_nsca was updated
-send_nsca is running via cron every minute
-Issue happens to the four servers below that all have these checks, other passive checks are not alerting:
        use                     passive-check
        host_name               mercury
        service_description     disk_space
        use                     passive-check
        host_name               mercury
        service_description     opt_space
        use                             passive-check
        host_name                      mercury
        service_description             mysql_status
        use                             passive-check
        host_name                       mercury
        service_description             mysql_replication
        use                             passive-check
        host_name                       mercury
        service_description             web_active
        register                        0
        use                             passive-check
        host_name                       mercury
        service_description             check_rsync
        use                             12-hour-active-check
        host_name                       mercury
        service_description             Awstats Copy
        check_command                   check_file_age!90000!180000!/var/www/awstats/digeo-mercury
        host_name                       mercury
        service_description             Log Schlep
        check_command                   check_logs!mercury
        register                        0
define servicegroup{
        servicegroup_name       mercury_noncrit
        alias                   Mercury Non-Critical
        members                mercury, opt_space, mercury, disk_space, mercury, mysql_replication, mercury, check_rsync
        servicegroup_name       mercury_crit
        alias                   Mercury Critical
        members                 mercury, mysql_status
#       Non-Critical Service Alerts
#  Daytime: immediate e-mail
#           pagers if not acknowledged in 30 min.
#           e-mail every hour
#  After Hours: single e-mail
define serviceescalation{
        first_notification      1
        last_notification       1
        notification_interval   30
        escalation_period       24x7
        contact_groups          cld, digeo
        first_notification      2
        last_notification       2
        escalation_period       days
        contact_groups          pagers
        first_notification      3
        last_notification       0
        notification_interval   120
        contact_groups          cld
        last_notification       1
        notification_interval   60
        escalation_period       nights
        contact_groups          cld
#        Critical Service Alerts
# Daytime: immediate page
#          immediate e-mail
#          hourly e-mails
# After Hours: immediate e-mail
#              immediate page
#              follow-up page in 30 min.
        last_notification       1
        last_notification       2
        notification_interval   59
        last_notification       0
        contact_groups          cld
        last_notification       3
        last_notification       3
        contact_groups          cld
Reason: Additional information added from IRC conversation
Re: Passive alerts returning as missing randomly and then OK
Post by Box293 »
illectronic wrote:The checks are making it there, but sometimes it says "plugin out of bounds"
Does "making it there" mean the correct output is hitting the nsca daemon on the core server but for some reason "plugin is out of bounds" is being submitted to the nagios command pipe?
Have a look at this guide:
http://sites.box293.com/nagios/guides/n ... core-4-0-x
Right at the bottom there is a Debug Logging section.
Can you enable this on your Nagios Core server so we can capture the data being received and pinpoint what is going on.
illectronic
I enabled logging and everything coming in to nsca in /var/log/messages is as expected. There are no errors such as missing plugins. All checks are returning something.
illectronic
I have enabled flap detection for now which is cutting the alerts by 90%. I would really like to know why nagios says plugin is missing while nsca sends valid information. Something sounds off.
Thanks to all
ssax
Dreams In Code
Post by ssax »
Please give us the exact error from the logs? Is it giving an error code?
Do you have any way to see what is sent into it? The plugin out of bounds kind of sounds like it's being returned from passive check output since nagios wouldn't have any idea about a plugin when reading a passive check.
illectronic
It was just saying out of bounds then it would get the proper results. In any case, I converted all the passive checks to active checks and it works fine now.
Did you want us to keep looking into this then or are we good to close this thread out?
