Good morning,
I need to activate the LDAP auth in NagiosXI. Under "Admin-->System Extensions-->Manage Components" I see LDAP Authentication:
Provides LDAP authentication for Nagios XI.
Experimental Version: 0.3 Author: Nagios Enterprises, LLC.
I tried to configure the component but I can't see inside “AdminUsersManage Users” the checkbox to add new user trough LDAP.
Can you help me in activating LDAP correctly?
Thank you
Francesco
Re: LDAP authentication for Nagios XI
Can you provide a screenshot to show us where you're at?
Did you add your authentication server already?
Hi rkennedy,
Attached the screenshots.
The LDAP Server is up and running.
Thank you
Francesco
Thank you
Francesco
What version of XI are you running?
Former Nagios Employee.
me.
me.
Nagios XI 2014R2.7
You need to upgrade to XI 5 in order to have that functionality.
If you decide to upgrade then you should disable the old LDAP component that you setup under Admin > Manage Components and then upgrade and then setup LDAP under Admin > LDAP/AD Integration.
I imagined.
Thank you for support
Francesco
Francesco
Is there anything else we can do for you, or should we lock this thread up?
me.
me.
