message "NRPE:unable to read output"
Hi Team,
I am trying to monitor an AIX server, I have installed nrpe agent on the remote host but when I am trying to monitor server parameters I find "NRPE: unable to read output" message. Please find the attached snapshot for this.
When I run the same script on remote server I receive the required output.
I have set the permission for /usr/local/nagios/libexec as 755 and same permission for all scripts.
kindly help on this.
Thanks in advance.
Thanks in advance.
Thanks & Regards,
I2MP Team.
I2MP Team.
Re: message "NRPE:unable to read output"
Does it work from the XI command line?
Can you post the nrpe.cfg from the remote server here for us to take a look at?
Former Nagios Employee.
me.
me.
This is what it says when nothing was sent back to NRPE on STDOUT, among other things... I had a script that printed an error on STDERR, but returned 0 so the status was ok, and it said the exact same thing.
The troubleshooting guide has a section on this message:
https://assets.nagios.com/downloads/nag ... utions.pdf
No it is not working from XI command line.
Please find the below nrpe file.
Thanks & Regards,
I2MP Team.
I2MP Team.
What is the result when you run it over command line?
Please find the attached snapshot. I am getting "NPRE: unable to read data" message when I am trying to run the command from Nagios server command line.
Thanks & Regards,
I2MP Team.
I2MP Team.
Can you also post the script that is linked to 'check_cpu_custom'?
I am unable to provide you the script of check_cpu_custom.
please find the details regarding check_disk, find the attached snapshot output when I am running the cmd from Nagios server also find the snapshot output on remote server which is required to be monitored.
Thanks & Regards,
I2MP Team.
I2MP Team.
This might have to do with permissions on the client machine.
On the client machine, can you run the following and post the output?
ls -l /usr/local/nagios/libexec/
Is the path correct? Can you run the following commands on the client (remote machine) and show the output?command[check_disk]=/usr/local/nagios/libexec/check_disk $ARG1$
/usr/local/nagios/libexec/check_disk -V
/usr/local/nagios/libexec/check_disk -w 15% -c 10% -p /homeBe sure to check out our Knowledgebase for helpful articles and solutions!
