Ports
ranjitw
Ports
Post by ranjitw »
Hi All,
Could you please let me know what would be the default port which would be used for communication between inside components of Nagios XI .
Example port being used for communication between NDOUtils -> My SQL
NagiosSQL -> Configuration Files
Nagios core -> NDOUtils
Nagios XI -> PostgreSQL.
Please update the attachment with relevant port numbers.
Regards,
Ranjit W
ranjitw
Re: Ports
Post by ranjitw »
Please ignore internal scripts component of the image.
Regards,
Ranjit W
jolson
Attack Rabbit
Re: Ports
Post by jolson »
Postgresql: 5432
MySQL: 3306
Flow of information:
Ndoutils -> MySQL
Nagios XI -> NagiosQL -> 3306:MySQL -> configuration files
Aside from MySQL and Postgres, the other components you mentioned don't listen on ports - they either use Unix Domain Sockets or don't listen at all. Let me know if you have any questions, thanks!
Twits Blog
