check_nrpe!check_swap!-a '-w 50 -c 20'
architek
Post by architek »
I'm using Nagios XI - Installed Version: 5.2.3 and it seems the swap usage graph is the other way around, instead of showing the usage on the graphs, its showing the available swap. Since most nags graphs show the usage and this is also called Swap Usage it is confusin, how can I correct the template ?
Re: check_nrpe!check_swap!-a '-w 50 -c 20'
Post by Box293 »
Is this for NRPE Clients?
How was the service created? Using a wizard?
