negate plug-in - No data returned from command
disarm76
Post by disarm76 »
I'm trying to use the negate plug-in to change CRITICAL to OK. It is, according to the plug-in help, a default feature so no need to specify.
However, as you can see below, I can run the plug-in I need (check_as400) and it works fine, but not with negate.
[root@nagios libexec]# ./check_as400 -H trqvida -u nagiosc -p ********  -v CJ TEMPBATCH
CRITICAL - job(TEMPBATCH) NOT IN SYSTEM
[root@nagios libexec]# ./negate /usr/local/nagios/libexec/check_as400 -H trqvida -u nagiosc -p ********  -v CJ TEMPBATCH
I even changed the timeout time, since check_as400 is on a 60s timeout but I get the same result. And the 'No date returned..." return is instantaneous.
[root@nagios libexec]# ./negate -t 70 /usr/local/nagios/libexec/check_as400 -H trqvida -u nagiosc -p ********  -v CJ TEMPBATCH
On other hand I can create my own script that manipulates the results and concatenate it. Anyone know how to do that?
Can you help me with this problem? Thanks.
Using:
NagiosXI 5.2.3
CentosOS 6.6 64bit
Re: negate plug-in - No data returned from command
Post by Box293 »
What is the output of:
/usr/local/nagios/libexec/negate /usr/local/nagios/libexec/check_dummy 0 OK
echo $?
Does your password have any special characters? Perhaps try putting the password in single quotes.
./negate /usr/local/nagios/libexec/check_as400 -H trqvida -u nagiosc -p '********' -v CJ TEMPBATCH
disarm76
Post by disarm76 »
Thanks for helping!
OK the first:
[root@nagios libexec]# /usr/local/nagios/libexec/negate /usr/local/nagios/libexec/check_dummy 0 OK
OK: OK
[root@nagios libexec]# echo $?
2
The password is alphanumeric but tried the quotes getting the same result.
Post by Box293 »
The check_as400 plugin is going to be the source of the problem.
Does the check_as400 plugin have a verbose argument to show what is happening?
What happens when you test as the nagios user?
su nagios
disarm76
Post by disarm76 »
OK, so the check_as400 connects via telnet and with verbose active:
[root@nagios libexec]# ./check_as400 -d -H trqvida -u nagiosc -p **********  -v CJ TEMPBATCH
Establishing connection to server...done.
Logging in...
  waiting for screen...
    waiting for token IBM CORP...
    token received.
  sending login information for nagiosc...
  waiting for login to process...
    waiting for token ===>...
    token received.
Login completed.
Sending command (4)...
    waiting for token F3=...
    token received.
    waiting for token Selection...
Logging out...
  sending F3...
    token received.
  requesting signoff...
    waiting for token stem...
    token received.
Job ending immediately
    token received.
  terminating connection...
Logged out.
As nagios, I get the same:
[nagios@nagios libexec]$ ./negate /usr/local/nagios/libexec/check_as400 -d -H trqvida -u nagiosc -p ********** -v CJ TEMPBATCH
Can you try running the check as the Nagios user and then the echo command? This will show us if the script is exiting properly or not.
then run -
echo $?
Please post the output of both commands for us to take a look at.
disarm76
Post by disarm76 »
[nagios@nagios libexec]$ ./check_as400 -d -H trqvida -u nagiosc -p ********  -v CJ TEMPBATCH
Logging in...
    token received.
    token received.
Login completed.
    token received.
Logging out...
  sending F3...
    token received.
    token received.
    token received.
Logged out.
[nagios@nagios libexec]$ echo $?
2
Can you post your check_as400 plugin that you are using here so we can review it?
The check_as400 plugin I found uses a .as400 file that is stores on the system to get the username and password to login to the AS400 server and I am thinking that when the negate plugin runs the check_as400 check, it doesn't have the correct permissions to open the text file it uses for the login credentials.
Also, can you run the following and post the output here?
ls -l /usr/local/nagios/libexec
As @tgriep posted above - the issue may be the permissions with that file. Please do post the output of what he mentioned.
I did create a simple bash script to change the exit codes as needed. Change the password in the -p parameter. If permissions are the issue though, then this script will not work either.
#!/bin/bash
# define vars
script=$(/usr/local/nagios/libexec/check_as400 -d -H trqvida -u nagiosc -p password CJ TEMPBATCH)
# switch CRITICAL to OK
if [[ $script == *"CRITICAL"* ]]
then
echo "OK"
exit 0
# WARNING stays the same
elif [[ $script == *"WARNING"* ]]
then
echo "WARNING"
exit 1
# switch OK to CRITICAL
elif [[ $script == *"OK"* ]]
then
echo "CRITICAL"
exit 2
# catchall UNKNOWN
else
echo "UNKNOWN"
exit 3
fi
disarm76
Post by disarm76 »
OK, it's working! Well, it's one script for one alert but these kind of alerts are rare.
Thank you for your help!
[root@nagios libexec]# ./check_as400_job_TEMPBATCH_negated.sh
OK - BATCH Terminado
As a test I gave full permissions to all as400 files and still got the same result:
[root@nagios libexec]# ls -la *as400*
-rwxrwxrwx 1 apache nagios   225 Nov 18 17:42 check_as400
-rwxrwxrwx 1 apache nagios   225 Nov 18 17:37 check_as400_BK
-rwxrwxrwx 1 apache nagios 35004 Nov 20 17:41 check_as400.class
-rwxrwxrwx 1 apache nagios   787 Nov 20 17:41 check_as400_cmd_vars.class
-rwxrwxrwx 1 apache nagios  1517 Nov 20 17:41 check_as400_lang.class
-rwxrwxrwx 1 apache nagios 11646 Nov 28  2013 check_as400sql.php
-rwxrwxrwx 1 root   nagios   474 Dec 29 09:36 check_as400_trqvida_job_TEMPBATCH_negated.sh
[root@nagios libexec]# ls -la .as400*
-rwxrwxrwx 1 apache nagios 12 Nov 20 11:26 .as400
[root@nagios libexec]# /usr/local/nagios/libexec/negate /usr/local/nagios/libexec/check_as400  -H trqvida -u nagiosc -p *******  -v CJ TEMPBATCH
