Change notification delay
YukonFish
Post by YukonFish »
We want to change all the alerts notification for the hosts/services that exist in the nagios.
We want to recive only email when the alert was checked 3 times and not immediately.
This is because we have some network problems and we do not want to recive false emails..
Is there any way in the CCM to change this configuration to all hosts?
Eli
Re: Change notification delay
Post by Box293 »
This can be performed using the Bulk Modifications tool.
CCM
Tools
Bulk Modifications
NOTE: This is a part of the Enterprise Edition license. If you did not purchase this then you can activate the trial which will let you use the tool and get a taste of it's power.
YukonFish
Post by YukonFish »
Found it.
Great!!
Thank you!!
hsmith
Agent Smith
Post by hsmith »
Is there anything else you could use help with in this thread?
Former Nagios Employee.
me.
