Error trying to update Nagios to 5.2.3
SavaSC
Post by SavaSC »
I can not get NagiosXI to upgrade to 5.2.3 through the web interface. (I have not tried manually.) Here is what it says:
---- Starting Nagios XI Backup ----
Backing up Core Config Manager (NagiosQL)...
tar: Removing leading `/' from member names
Backing up Nagios Core...
tar: /usr/local/nagios/var/rw/nagios.qh: socket ignored
tar: /usr/local/nagios/var/ndo.sock: socket ignored
Backing up Nagios XI...
Backing up MRTG...
Backing up NRDP...
Backing up Nagvis...
Backing up MySQL databases...
Backing up PostgresQL databases...
Backing up logrotate config files...
Backing up Apache config files...
Compressing backup...
BACKUP COMPLETE
Backup stored in /store/backups/nagiosxi/autoupgrade_backup.1450898112.tar.gz
---- Starting Nagios XI Upgrade ----
Cleaning up temp directory...
Downloading Latest Nagios XI Tarball...
Archive:  sourceguardian/ixed4.lin.x86-32.zip
  inflating: /usr/lib/php/modules/ixed.5.1.lin
Sourceguardian extension found for PHP version 5.1
Sourceguardian extension already in php.ini
Stopping httpd: [  OK  ]
Starting httpd: [  OK  ]
Checking required prereqs...
Please wait...
OLD VERSION: 513
Loaded plugins: fastestmirror
Determining fastest mirrors
 * addons: mirror.team-cymru.org
 * base: centos.host-engine.com
 * epel: linux.mirrors.es.net
 * extras: mirrors.cmich.edu
 * updates: mirrors.arsc.edu
Setting up Install Process
Package automake-1.9.6-3.el5.noarch already installed and latest version
Package autoconf-2.59-12.noarch already installed and latest version
Package php-mbstring-5.1.6-45.el5_11.i386 already installed and latest version
Package 2:nmap-6.47-1.i386 already installed and latest version
Package subversion-1.6.11-12.el5_10.i386 already installed and latest version
Nothing to do
Error getting repository data for rpmforge, repository not found
Just at a glance, it looks like it's telling me it's already at the latest version, but it continues to say a new version is available.
Any suggestions on what to try?
Re: Error trying to update Nagios to 5.2.3
Can you please post the result of the following command?
yum repolist
Also, please attach a screenshot of Nagios telling you that a new version is available for us to take a look at.
Post by Box293 »
Does your XI server need to use a proxy to get internet access?
SavaSC
Post by SavaSC »
rkennedy wrote:Can you please post the result of the following command?
yum repolist
I have attached screen shots.
SavaSC
Post by SavaSC »
Box293 wrote:Does your XI server need to use a proxy to get internet access?
No, it does not.
However, our network engineers have been trying to close up as many ports as they can for security reasons. What port(s) does Nagios use to update?
Post by Box293 »
It uses port 80 to get yum updates.
Can you try a manual upgrade and post the full log here please:
https://assets.nagios.com/downloads/nag ... nstall.pdf
SavaSC
Post by SavaSC »
Box293 wrote:It uses port 80 to get yum updates.
I can do the manual upgrade, no problem. What log do you want me to give you?
Post by Box293 »
It should be upgrade.log in the directory you run the upgrade from.
SavaSC
Post by SavaSC »
Got the same message. Attached is the log.
Post by Box293 »
Can you try installing rpmforge as outlined in this link and let us know if it fixes your problem:
http://www.tecmint.com/enable-rpmforge-repository/
