New to Nagios XI, although I have a simple Nagios core setup and demoing Nagios XI to see if it makes sense to purchase
How do you add monitoring services and processes for Win 7 clients? I've read to use the add Windows Server wizard, is this the best practice or do I resort to manually modifying files?
Cris
Monitor Win 7 client services
Re: Monitor Win 7 client services
The Windows wizard will get you started with some basic checks. If you want to do anything more advanced, it's much easier to use the core configuration manager to make changes.
Perhaps take a look at some of the common checks on Troy's website: http://sites.box293.com/nagios/guides/common-checks
Former Nagios Employee.
me.
me.
crisdaniels
I appreciate the link, but it doesn't explicitly state how to do this in Nagios XI core config manager (service management)
Looking at the existing service checks isn't giving me quite enough information.
I actually understand how it works better in regular Nagios core. Is there anyone with screenshots of even the simplest (say monitoring of explorer.exe) so I can understand how to do this in NagiosXI?
TIA
Cris
TIA
Cris
Well, when it comes to monitoring explorer.exe, this very easy to accomplish via the Windows Server Wizard - you can still apply that to a Win client machine, just don't enable the checks unique to a server, such as ISS of course. The Windows Server Wizard has by default some check boxes to monitor services and process which the Windows client Wizard does not have.
This short video walks one through the set-up:
Monitoring A Windows Server With Nagios XI - IT Infrastructure Monitoring
https://www.youtube.com/watch?v=fJwgB0- ... AC46F099DE
-Hope this helps -
-Hope this helps -
crisdaniels
Ah.. ok. This is what I had been wondering. If I need to monitor more than just the basic items such as disk space, ping, and CPU, can I just use the Windows server wizard, or is there some reason that this will not work...
I am fine to use the CCM, and I know exactly what I want to do, but I dont quite know the correct syntax and how to accomplish this.
Let me use the Windows Server Wizard and see if that doesnt do the trick.
Cris
Cris
Take a look and try it out. Post back if you have any further questions regarding how to do this. The core configuration manager can be a beast at first, but it's pretty simple once you get the hang of it.
me.
me.
