Indices re-opened?
CFT6Server
Indices re-opened?
Post by CFT6Server »
After the holidays, I found our cluster status to be red. I am still not sure what happened and when this started, but looks like it's been a while and the shards are happy. I clicked on the index status page and looks like there's a lot of older indexes that are opened ?! I am not sure why that is....
What's the best way to tackle this? and to get our cluster back to green....
CFT6Server
Re: Indices re-opened?
Looks like it re-opened all the previous index? As it shows that all index status as opened for some reason....
Lots of shards and pending tasks...
# curl localhost:9200/_cluster/health?pretty
  "cluster_name" : "80e9022e-f73f-429e-8927-f23d0d88dfd2",
  "status" : "yellow",
  "timed_out" : false,
  "number_of_nodes" : 6,
  "number_of_data_nodes" : 6,
  "active_primary_shards" : 1501,
  "active_shards" : 2869,
  "relocating_shards" : 0,
  "initializing_shards" : 12,
  "unassigned_shards" : 121,
  "number_of_pending_tasks" : 7013,
  "number_of_in_flight_fetch" : 0
CFT6Server
Update: After closing all previously closed, status went back to yellow and is now reallocating shards.
I wonder why it will open old shards, which are supposed to be removed and archived as well.
jolson
Attack Rabbit
Post by jolson »
It'll be important to capture the elasticsearch log - it should give a reason why your indices were closed.
tar czf elasticlog.tar.gz /var/log/elasticsearch/*
Are your indices still balancing? Was there any recent power outage or similar that may have triggered such a situation?
Twits Blog
CFT6Server
I'll capture the logs... looks like once it returned to green status, the closed indexes are "opened" again.... seems like backup/maintenance didn't run. I'll try to reset and see if that helps.
jolson
Attack Rabbit
Post by jolson »
Let me know if that helps - I'll keep an eye out for the logs once you collect them. Thanks!
Twits Blog
CFT6Server
So I think there must be some recovery information that's stuck? I rebooted a single node today and it is re-opening my indices again. I am not sure why this is happening.
jolson
Attack Rabbit
Post by jolson »
I think we should have a remote session - if you could mail into [email protected] I would be happy to pick up the ticket and get the remote going as soon as possible.
I dealt with a very similar case today, and it's possible that your problem is similar.
Twits Blog
CFT6Server
Hi jolson, reporting back, the indexes did get reopened again, which means the configuration change didn't prevent if from re-reading everything. But after allowing it to run through it and re-delete, it seems to have settled.
jolson
Attack Rabbit
Post by jolson »
I'm happy to hear it - keep me updated if anything does wind up looking out of the ordinary. :)
Twits Blog
