The plugin is 'check_qnapdisk'.
When I try to run the plugin manually, this is what I get:
[root@nagios libexec]# ./check_qnapdisk
Can't locate object method "new" via package "Nagios::Plugin" (perhaps you forgot to load "Nagios::Plugin"?) at ./check_qnapdisk line 16.
our $np = Monitoring::Plugin->new(
#! /usr/bin/perl -w
# Changelog
# Version 1.0.2 2014.06.10 added smart info to plugin output thanks to http://exchange.nagios.org/directory/Reviews/dit_w/1#/
# Version 1.0.1 2014.02.19 change some vars from my to our thanks to http://exchange.nagios.org/directory/Reviews/navi/1
# Version 1.0 2013.01.19
use strict ; use warnings ; use Monitoring::Plugin ; use Net::SNMP qw(oid_lex_sort oid_base_match) ;
our $PROGNAME = "check_qnapdisk" ;
our $VERSION = "1.0.2" ;
#instantiate Monitoring::Plugin
usage => "Usage: $PROGNAME [-h] [-V] -H hostname [-t timeout] [-r retries] [-C community] [-p port] [-w warning] [-c critical] [-T C | F ] [-g temp_warning] [-l
temp_critical] [-v verbose]",
version => $VERSION,
blurb => 'This plugin checks all disk slots on your QNAP NAS host with snmp and will output OK, UNKNOWN, WARNING or CRITICAL if the resulting number is over the
specified thresholds. Enable on your QNAP NAS the snmpd (see the QNAP adminguide too).',
shortname => "QNAPDISK",
extra => "THRESHOLDs for -w and -c are specified 'min:max' or 'min:' or ':max' (or 'max'). If specified '\@min:max', a warning status will be generated if the
count *is* inside the specified range. \nExample: $PROGNAME -H 'ip-address or [DNS,host]name' -t 5 -r 2 -C public -p 161 -w 2: -c 1: -T C -g 25 -l 35 -v"
$np->add_arg(
spec => 'warning|w=s',
help => qq{-w, --warning=INTEGER,[INTEGER] Maximum number of allowable result, outside of which a warning will be generated. If omitted, no warning is
generated.},
default => '0:',
required => 0,
$np->add_arg(
spec => 'critical|c=s',
help => qq{-c, --critical=INTEGER,[INTEGER] Maximum number of the generated result, outside of which a critical will be generated. },
default => '0:',
required => 0,
$np->add_arg(
spec => 'temperature|T=s',
help => qq{-T, --temperature=STRING, Specify to use Celsius (default) or Fahrenheit on the command line. Use Temp.},
default => 'C',
required => 0,
$np->add_arg(
spec => 'temp_warning|g=s',
help => qq{-g, --temp_warning=INTEGER,[INTEGER] Specify the warning maximum degrees on the command line. Use Temp.},
default => "0:",
required => 0,
$np->add_arg(
spec => 'temp_critical|l=s',
help => qq{-l, --temp_critical=INTEGER,[INTEGER] Specify the critical maximum degrees on the command line. Use Temp.},
default => "0:",
required => 0,
$np->add_arg(
spec => 'port|p=s',
help => qq{-p, --port=INTEGER, Specify the snmp port on the command line, default 161.},
default => 161,
required => 1,
$np->add_arg(
spec => 'retries|r=s',
help => qq{-r, --retries=INTEGER, Specify the number of retries the command line, default 2.},
default => 2,
required => 1,
$np->add_arg(
spec => 'community|C=s',
help => qq{-C, --community=STRING, Specify the community name on the command line, default public.},
default => "public",
required => 1,
$np->add_arg(
spec => 'host|H=s',
help => qq{-H, --host=STRING, Specify the host on the command line.},
required => 1,
$np->getopts;
# start counting down to timeout
alarm $np->opts->timeout;
sub open_snmp_session {
my ($session, $error) = Net::SNMP->session(
-hostname => shift || $np->opts->host,
-community => shift || $np->opts->community,
-port => shift || $np->opts->port,
-timeout => shift || $np->opts->timeout,
-retries => shift || $np->opts->retries,
return ($session,$error)
##==============main=============##
my $mibthree_stat = '.1.3.6.1.4.1.24681.1.2.11.1.4' ;
my $mibthree_temp = '.1.3.6.1.4.1.24681.1.2.11.1.3' ;
my $mibthree_type = '.1.3.6.1.4.1.24681.1.2.11.1.5' ;
my $mibthree_size = '.1.3.6.1.4.1.24681.1.2.11.1.6' ;
my $mibthree_smart = '.1.3.6.1.4.1.24681.1.2.11.1.7' ;
my $OID_Sysname = '.1.3.6.1.2.1.1.5.0' ;
my $OID_Hardware = '.1.3.6.1.2.1.1.1.0' ;
# let's see if the qnap wants to speak with us
my ($session,$error)=open_snmp_session($np->opts->host);
if ( ! defined ($session)) {
print "ERROR1: Could not open connection: $error \n";
exit 2;
if (!defined $session) {
printf "ERROR2: %s.\n", $error;
exit 1;
# open the connection ask your qnap
my @oids_sgos4 = ($OID_Hardware,$OID_Sysname) ;
my $result = $session->get_request(-varbindlist => \@oids_sgos4,) ;
my $result1 = $session->get_table(-baseoid => $mibthree_stat ) ;
my $result2 = $session->get_table(-baseoid => $mibthree_temp ) ;
my $result3 = $session->get_table(-baseoid => $mibthree_type ) ;
my $result4 = $session->get_table(-baseoid => $mibthree_size ) ;
my $result5 = $session->get_table(-baseoid => $mibthree_smart ) ;
my $msg = $result->{$OID_Sysname}.", ".$result->{$OID_Hardware} ;
my %qnap_states = ( 0 => "ready" , -5 => "no Disk" , -6 => "invalid" , -9 => "rwError" , -4 => "unknown" );
my (@state,$min_disk,$real_disk,$max_disk)=0;
my $nagios_view=""; my $temp_disk_max="0"; my $temp_disk_min="0";
foreach (oid_lex_sort(keys(%{$result1}))) {
$min_disk= 1 ; # yes is min 1 Disk available :-)
my $disk_id=substr($_,30,2);
$nagios_view .= "\nDisk $disk_id Status: $qnap_states{$result1->{$_}}";
if ( $result1->{$_} eq 0 ) {
$real_disk++;
$msg .= ", Disk$disk_id:$qnap_states{$result1->{$_}}";
$state[$disk_id-1]=0;
foreach (oid_lex_sort(keys(%{$result5}))) {
if ( $disk_id == substr($_,30,2)) {
$result5->{$_} =~ s/\s+$//;
$nagios_view .= ", SmartInfo: $result5->{$_}";
foreach (oid_lex_sort(keys(%{$result3}))) {
$result3->{$_} =~ s/\s+$//;
$nagios_view .= ", Typ: $result3->{$_}";
foreach (oid_lex_sort(keys(%{$result4}))) {
$nagios_view .= ", Size: $result4->{$_}";
foreach (oid_lex_sort(keys(%{$result2}))) {
my @temp_diskid=split(/ /,$result2->{$_});
if ($np->opts->temperature eq "C") {
if ($temp_disk_max < $temp_diskid[0]) { $temp_disk_max = $temp_diskid[0];
if ($temp_disk_min > $temp_diskid[0] ) { $temp_disk_min =
$temp_diskid[0]; }
if ($temp_disk_min eq "0") { $temp_disk_min = $temp_diskid[0]; }
if ($np->opts->temperature eq "F") {
$temp_diskid[1] =~ s/C\///;
if ($temp_disk_max < $temp_diskid[1]) { $temp_disk_max =
$temp_diskid[1];}
if ($temp_disk_min > $temp_diskid[1] ) { $temp_disk_min =
$temp_diskid[1]; }
if ($temp_disk_min eq "0") { $temp_disk_min = $temp_diskid[1]; }
$nagios_view .= ", Temp: $result2->{$_}";
} else {
$real_disk++;
if ( $result1->{$_} != -5 || $result1->{$_} != 0 ) {
$state[$disk_id-1]=2;
if ( $result1->{$_} == -5 ) {
$real_disk--;
$max_disk=$disk_id;
$session->close();
$msg .= ", max. Temperature:".$temp_disk_max.$np->opts->temperature;
if ($np->opts->verbose) {
$msg .= "\n=================$nagios_view\n\n";
# Perfdata methods disk
my $perfdata_code_disk = $np->add_perfdata(
label => "Disk",
value => $real_disk,
#uom => "kB",
warning => $np->opts->warning,
critical => $np->opts->critical,
min => $min_disk,
max => $max_disk,
# Perfdata methods temperature
my $perfdata_code_temp = $np->add_perfdata(
label => "Temp",
value => $temp_disk_max,
uom => $np->opts->temperature,
warning => $np->opts->temp_warning,
critical => $np->opts->temp_critical,
min => $temp_disk_min,
max => $temp_disk_max,
# Threshold methods disks
my $threshold_code_disk = $np->check_threshold(
check => $real_disk,
$np->nagios_exit( $threshold_code_disk, "$msg" ) if $threshold_code_disk != 0 ;
# Threshold methods temperature
my $threshold_code_temp = $np->check_threshold(
check => $temp_disk_max,
) if defined $np->opts->temperature;
$np->nagios_exit( $threshold_code_temp, "$msg" ) if $threshold_code_temp != 0 ;
foreach (@state){
if ($threshold_code_disk < $_) {$threshold_code_disk=$_;}
$np->nagios_exit( $threshold_code_disk, "$msg" ) ;
# thanks
