Snapshot stuck in "IN_PROGRESS" - can't delete
mike4vr
Post by mike4vr »
We have a snapshot "logstash-2015.12.08" that is stuck in "IN_PROGRESS" mode. I've tried deleting it, but it won't work. I've also tried resetting all jobs, but that makes no difference either. Any troubleshooting steps I can take to resolve this and get my snanpshots working again?
I've tried "touching" a file as the nagios user in the repository directory and it works fine. So, I'm sure this is not a permission issue.
jolson
Attack Rabbit
Re: Snapshot stuck in "IN_PROGRESS" - can't delete
Post by jolson »
Are you capable of deleting files from the backup directory as the 'nagios' user? I recommend jumping over to your backup directory and deleting the appropriate file:
cd /mnt/nlsbackup/indices
rm -rf logstash-2015.12.02
That should take care of the partial index backup - adjust the index name to be certain you're removing the bad index. Also you'll want to delete any snapshot- or metadata- files that match the same index name from /mnt/nlsbackup.
Let me know if that helps. Thanks!
Twits Blog
mike4vr
Post by mike4vr »
Thank you. Do you recommend deleting all partial backups?
jolson
Attack Rabbit
Post by jolson »
If you're on an older version of Nagios Log Server (<1.4.0) I recommend deleting all PARTIAL or FAILED backups entirely. The old version of our backup system could not self-delete.
What I highly recommend is updating to Nagios Log Server version 1.4.0 - we redesigned the backup system to be more fault-tolerant and self-sustainable. The new system also synchronously backs up your indices, which can improve backup speeds as well.
The new version can be downloaded here: https://www.nagios.com/downloads/nagios ... ver-source
Thanks!
Jesse
Twits Blog
mike4vr
Post by mike4vr »
Thanks. We are already up-to-date with 1.4.0. I believe I've cleared the issue with your suggestion.
Are we all set to close this up then?
