[2015-12-30 12:47:47,850][DEBUG][action.bulk ] [e63648a3-d912-4f5d-a867-1b99282a5e7c] observer: timeout notification from cluster service. timeout setting [1m], time since start [1m]Code: Select all
service elasticsearch stop
service elasticsearch status
tail /var/log/elasticsearch/*.logCode: Select all
curl -XGET 'localhost:9200/_cat/recovery?v'
curl 'localhost:9200/_cat/plugins?v'
curl 'localhost:9200/_cluster/health?level=indices&pretty'
cat /usr/local/nagioslogserver/var/cluster_*
curl 'localhost:9200/_cat/nodes?v'
curl 'localhost:9200/_cat/master?v'Code: Select all
[2015-12-30 14:13:23,582][INFO ][node ] [e63648a3-d912-4f5d-a867-1b99282a5e7c] stopping ...
[2015-12-30 14:13:24,740][INFO ][node ] [e63648a3-d912-4f5d-a867-1b99282a5e7c] stopped
[2015-12-30 14:13:24,741][INFO ][node ] [e63648a3-d912-4f5d-a867-1b99282a5e7c] closing ...
[2015-12-30 14:13:24,756][INFO ][node ] [e63648a3-d912-4f5d-a867-1b99282a5e7c] closed
# service elasticsearch start
Starting elasticsearch: [ OK ]
[root@kdcnagls1n3 ~]# tail -f /var/log/elasticsearch/80e9022e-f73f-429e-8927-f23d0d88dfd2.log
[2015-12-30 14:15:44,510][INFO ][node ] [e63648a3-d912-4f5d-a867-1b99282a5e7c] version[1.6.0], pid[855 2], build[cdd3ac4/2015-06-09T13:36:34Z]
[2015-12-30 14:15:44,511][INFO ][node ] [e63648a3-d912-4f5d-a867-1b99282a5e7c] initializing ...
[2015-12-30 14:15:44,524][INFO ][plugins ] [e63648a3-d912-4f5d-a867-1b99282a5e7c] loaded [knapsack-1.5.2. 0-f340ad1], sites []
[2015-12-30 14:15:44,587][INFO ][env ] [e63648a3-d912-4f5d-a867-1b99282a5e7c] using [1] data paths, m ounts [[/nfs/logdata (10.242.145.237:/vol/v_kdcnagiosnfs1_kdcnagls1n3_logs)]], net usable_space [1.4tb], net total_space [ 2.4tb], types [nfs]
[2015-12-30 14:15:49,375][INFO ][node ] [e63648a3-d912-4f5d-a867-1b99282a5e7c] initialized
[2015-12-30 14:15:49,375][INFO ][node ] [e63648a3-d912-4f5d-a867-1b99282a5e7c] starting ...
[2015-12-30 14:15:49,501][INFO ][transport ] [e63648a3-d912-4f5d-a867-1b99282a5e7c] bound_address {inet[/0: 0:0:0:0:0:0:0:9300]}, publish_address {inet[/10.242.102.109:9300]}
[2015-12-30 14:15:49,511][INFO ][discovery ] [e63648a3-d912-4f5d-a867-1b99282a5e7c] 80e9022e-f73f-429e-8927 -f23d0d88dfd2/JEOqkDrhRwSBJG84nTHzvA
[2015-12-30 14:15:59,538][INFO ][cluster.service ] [e63648a3-d912-4f5d-a867-1b99282a5e7c] new_master [e63648a3-d9 12-4f5d-a867-1b99282a5e7c][JEOqkDrhRwSBJG84nTHzvA][kdcnagls1n3.bchydro.bc.ca][inet[/10.242.102.109:9300]]{max_local_storag e_nodes=1}, reason: zen-disco-join (elected_as_master)
[2015-12-30 14:15:59,935][INFO ][http ] [e63648a3-d912-4f5d-a867-1b99282a5e7c] bound_address {inet[/12 7.0.0.1:9200]}, publish_address {inet[localhost/127.0.0.1:9200]}
[2015-12-30 14:15:59,936][INFO ][node ] [e63648a3-d912-4f5d-a867-1b99282a5e7c] started
[2015-12-30 14:16:00,176][INFO ][discovery.zen ] [e63648a3-d912-4f5d-a867-1b99282a5e7c] updating discovery.zen. minimum_master_nodes from [-1] to [1]
[2015-12-30 14:16:00,630][INFO ][gateway ] [e63648a3-d912-4f5d-a867-1b99282a5e7c] recovered [327] indices into cluster_state
[2015-12-30 14:16:01,641][DEBUG][action.search.type ] [e63648a3-d912-4f5d-a867-1b99282a5e7c] All shards failed for p hase: [query_fetch]
org.elasticsearch.action.NoShardAvailableActionException: [nagioslogserver][0] null
at org.elasticsearch.action.search.type.TransportSearchTypeAction$BaseAsyncAction.start(TransportSearchTypeAction. java:160)
at org.elasticsearch.action.search.type.TransportSearchQueryAndFetchAction.doExecute(TransportSearchQueryAndFetchA ction.java:57)
at org.elasticsearch.action.search.type.TransportSearchQueryAndFetchAction.doExecute(TransportSearchQueryAndFetchA ction.java:47)
at org.elasticsearch.action.support.TransportAction.execute(TransportAction.java:75)
at org.elasticsearch.action.search.TransportSearchAction.doExecute(TransportSearchAction.java:104)
at org.elasticsearch.action.search.TransportSearchAction.doExecute(TransportSearchAction.java:43)
at org.elasticsearch.client.node.NodeClient.execute(NodeClient.java:98)
at org.elasticsearch.client.FilterClient.execute(FilterClient.java:66)
at org.elasticsearch.rest.BaseRestHandler$HeadersAndContextCopyClient.execute(BaseRestHandler.java:92)
at org.elasticsearch.client.support.AbstractClient.search(AbstractClient.java:338)
at org.elasticsearch.rest.action.search.RestSearchAction.handleRequest(RestSearchAction.java:84)
at org.elasticsearch.rest.BaseRestHandler.handleRequest(BaseRestHandler.java:53)
at org.elasticsearch.rest.RestController.executeHandler(RestController.java:225)
at org.elasticsearch.rest.RestController.dispatchRequest(RestController.java:170)
at org.elasticsearch.http.HttpServer.internalDispatchRequest(HttpServer.java:121)
at org.elasticsearch.http.HttpServer$Dispatcher.dispatchRequest(HttpServer.java:83)
at org.elasticsearch.http.netty.NettyHttpServerTransport.dispatchRequest(NettyHttpServerTransport.java:327)
at org.elasticsearch.http.netty.HttpRequestHandler.messageReceived(HttpRequestHandler.java:63)
at org.elasticsearch.common.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler .java:70)
at org.elasticsearch.common.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564)
at org.elasticsearch.common.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendUpstream(Default ChannelPipeline.java:791)
at org.elasticsearch.http.netty.pipelining.HttpPipeliningHandler.messageReceived(HttpPipeliningHandler.java:60)
at org.elasticsearch.common.netty.channel.SimpleChannelHandler.handleUpstream(SimpleChannelHandler.java:88)
at org.elasticsearch.common.netty.handler.codec.http.HttpChunkAggregator.messageReceived(HttpChunkAggregator.java: 145)
at org.elasticsearch.common.netty.handler.codec.http.HttpContentDecoder.messageReceived(HttpContentDecoder.java:10 8)
at org.elasticsearch.common.netty.channel.Channels.fireMessageReceived(Channels.java:296)
at org.elasticsearch.common.netty.handler.codec.frame.FrameDecoder.unfoldAndFireMessageReceived(FrameDecoder.java: 459)
at org.elasticsearch.common.netty.handler.codec.replay.ReplayingDecoder.callDecode(ReplayingDecoder.java:536)
at org.elasticsearch.common.netty.handler.codec.replay.ReplayingDecoder.messageReceived(ReplayingDecoder.java:435)
at org.elasticsearch.common.netty.OpenChannelsHandler.handleUpstream(OpenChannelsHandler.java:74)
at org.elasticsearch.common.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:559)
at org.elasticsearch.common.netty.channel.Channels.fireMessageReceived(Channels.java:268)
at org.elasticsearch.common.netty.channel.Channels.fireMessageReceived(Channels.java:255)
at org.elasticsearch.common.netty.channel.socket.nio.NioWorker.read(NioWorker.java:88)
at org.elasticsearch.common.netty.channel.socket.nio.AbstractNioWorker.process(AbstractNioWorker.java:108)
at org.elasticsearch.common.netty.channel.socket.nio.AbstractNioSelector.run(AbstractNioSelector.java:337)
at org.elasticsearch.common.netty.channel.socket.nio.AbstractNioWorker.run(AbstractNioWorker.java:89)
at org.elasticsearch.common.netty.channel.socket.nio.NioWorker.run(NioWorker.java:178)
at org.elasticsearch.common.netty.util.ThreadRenamingRunnable.run(ThreadRenamingRunnable.java:108)
at org.elasticsearch.common.netty.util.internal.DeadLockProofWorker$1.run(DeadLockProofWorker.java:42)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:745)
[2015-12-30 14:16:01,661][DEBUG][action.search.type ] [e63648a3-d912-4f5d-a867-1b99282a5e7c] All shards failed for p hase: [query_fetch]
