Cluster is now red with unassigned shards and missing indice
mike4vr
Post by mike4vr »
We keep having problems with our cluster health, unassigned indices, and backups. Please see the screenshot:
mike4vr
Re: Cluster is now red with unassigned shards and missing in
Post by mike4vr »
Bump for urgency.
We do not appear to be receiving any new logs at this time.
hsmith
Agent Smith
Post by hsmith »
Bumping will not result in a faster response time to your thread. We have a dashboard system we use internally that tracks posts by age, and bumping it will make your thread look newer than it actually is.
Can I see the output of the following commands?
free -m
df -ih
df -h
curl 'localhost:9200/_cluster/health?level=indices&pretty'
Former Nagios Employee.
me.
mike4vr
Post by mike4vr »
 free -m
             total       used       free     shared    buffers     cached
Mem:         32110      31881        228          0        251      10950
-/+ buffers/cache:      20679      11431
Swap:         4031          0       4031
df -ih
Filesystem           Inodes IUsed IFree IUse% Mounted on
/dev/mapper/VolGroup-lv_root
                        61M  131K   61M    1% /
tmpfs                  4.0M     2  4.0M    1% /dev/shm
/dev/sda1              126K    46  125K    1% /boot
/dev/mapper/VolGroup-lv_home
                       2.9M    17  2.9M    1% /home
192.168.29.20:/data/logging
                       349M  162K  349M    1% /mnt/repo
df -h
Filesystem            Size  Used Avail Use% Mounted on
                      958G  456G  454G  51% /
tmpfs                  16G     0   16G   0% /dev/shm
/dev/sda1             477M   62M  390M  14% /boot
                       45G   52M   43G   1% /home
                      5.4T  2.1T  3.0T  42% /mnt/repo
  "cluster_name" : "98ec1d45-73e0-4296-ba7f-d7d71953b7e8",
  "status" : "yellow",
  "timed_out" : false,
  "number_of_nodes" : 2,
  "number_of_data_nodes" : 2,
  "active_primary_shards" : 171,
  "active_shards" : 315,
  "relocating_shards" : 0,
  "initializing_shards" : 2,
  "unassigned_shards" : 25,
  "number_of_pending_tasks" : 1,
  "number_of_in_flight_fetch" : 0,
  "indices" : {
    "nagioslogserver" : {
      "number_of_shards" : 1,
      "number_of_replicas" : 1,
      "active_primary_shards" : 1,
      "active_shards" : 1,
      "initializing_shards" : 0,
      "unassigned_shards" : 1
    "logstash-2015.12.08" : {
      "status" : "green",
      "number_of_shards" : 5,
      "active_primary_shards" : 5,
      "active_shards" : 10,
      "unassigned_shards" : 0
    "logstash-2015.12.26" : {
      "status" : "green",
    "logstash-2015.12.25" : {
      "active_shards" : 9,
    "logstash-2015.12.07" : {
      "active_shards" : 5,
      "unassigned_shards" : 5
    "logstash-2015.12.28" : {
      "status" : "green",
    "logstash-2015.12.09" : {
    "logstash-2015.12.27" : {
      "unassigned_shards" : 3
    "logstash-2016.01.03" : {
      "status" : "green",
    "logstash-2015.01.04" : {
      "status" : "green",
    "logstash-2016.01.02" : {
      "active_shards" : 6,
      "unassigned_shards" : 4
    "logstash-2015.12.29" : {
    "logstash-2015.01.03" : {
      "status" : "green",
    "logstash-2015.12.06" : {
      "status" : "green",
    "logstash-2015.12.05" : {
      "status" : "green",
    "logstash-2016.01.04" : {
      "status" : "green",
    "logstash-2015.12.10" : {
      "status" : "green",
    "nagioslogserver_log" : {
      "status" : "green",
    "logstash-2015.12.11" : {
      "status" : "green",
    "logstash-2015.12.12" : {
      "status" : "green",
    "logstash-2015.12.31" : {
      "status" : "green",
    "logstash-2015.12.13" : {
    "logstash-2015.12.19" : {
      "status" : "green",
    "logstash-2015.12.18" : {
      "status" : "green",
    "logstash-2015.12.17" : {
    "logstash-2015.12.16" : {
      "status" : "green",
    "logstash-2015.12.15" : {
      "status" : "green",
    "logstash-2015.12.14" : {
      "status" : "green",
    "logstash-2015.12.23" : {
      "status" : "green",
    "logstash-2015.12.24" : {
      "status" : "green",
    "logstash-2016.01.01" : {
      "status" : "green",
    "logstash-2015.12.21" : {
      "status" : "green",
    "logstash-2015.12.22" : {
      "status" : "green",
    "logstash-2015.12.20" : {
    "kibana-int" : {
      "active_shards" : 8,
Note that I closed an empty index and the cluster status went to yellow. If I try to delete it, it comes back and status turns red. Either way, we're down at the moment.
hsmith
Agent Smith
Post by hsmith »
@mike4vr , would you be able to send in a ticket to [email protected]? I discussed this with jolson, and this looks like something that may be easiest resolved in a remote session.
Thanks.
me.
mike4vr
Post by mike4vr »
Ticket sent and time booked. Thanks.
hsmith
Agent Smith
Post by hsmith »
I'll go ahead and close this post, since we will handle the communication through the ticket.
Thank you.
me.
