No Data , No chart in Report since the upgrate to 523
Since the last upgrate from version 416 to version 523 , lot of functionally Report doesn't seems to work.(SLA Report , Avaibility , ..)
Host data , Service Data are equal to zero .
The result is the same for all host , services , service groups , ...
The log file update.log does not seem have error
Thank
Thank
NAGIOS XI 5.2.3 offline
vm Centos 6.4 - 64 bits
Re: No Data , No chart in Report since the upgrate to 523
Do "Host Detail" and "Service Detail" pages update properly (i.e. Last Check, Status Information)? Have you tried stopping/starting nagios and ndo2db services? Do you see any errors in the apache error log and/or the mysqld.log? Run the following commands and show the output in code wraps:
Is opening a new support ticket in our email ticketing system an option for you? We may need to review the "profile.zip".
uname -a
cat /etc/*release
ps -efBe sure to check out our Knowledgebase for helpful articles and solutions!
Hi ,
All others function run correctly.
i have error in apache log file
tle last error i have in mysql log file was
In response to your request
[Sun Jan 03 03:41:04 2016] [notice] Digest: generating secret for digest authentication ...
[Sun Jan 03 03:41:04 2016] [notice] Digest: done
[Sun Jan 03 03:41:04 2016] [notice] Apache/2.2.15 (Unix) DAV/2 PHP/5.3.3 mod_ssl/2.2.15 OpenSSL/1.0.1e-fips configured -- resuming normal operations
[Mon Jan 04 09:44:39 2016] [error] [client 160.147.161.227] PHP Warning: ldap_bind(): Unable to bind to server: Invalid credentials in /usr/local/nagiosxi/html/includes/components/ldap_ad_integration/adLDAP/src/adLDAP.php on line 714, referer: http://eyes-sid.intradef.gouv.fr/nagiosxi/login.php?redirect=/nagiosxi/index.php%3f&noauth=1
[Mon Jan 04 09:46:47 2016] [error] [client 160.147.161.54] PHP Warning: ldap_bind(): Unable to bind to server: Invalid credentials in /usr/local/nagiosxi/html/includes/components/ldap_ad_integration/adLDAP/src/adLDAP.php on line 714, referer: http://eyes-sid.intradef.gouv.fr/nagiosxi/login.php?redirect=/nagiosxi/index.php%3f&noauth=1
[Mon Jan 04 09:47:07 2016] [error] [client 160.147.161.54] PHP Warning: ldap_bind(): Unable to bind to server: Invalid credentials in /usr/local/nagiosxi/html/includes/components/ldap_ad_integration/adLDAP/src/adLDAP.php on line 714, referer: http://eyes-sid.intradef.gouv.fr/nagiosxi/login.php
[Mon Jan 04 10:05:17 2016] [error] [client 160.147.161.227] PHP Notice: Undefined variable: service in /usr/local/nagiosxi/html/includes/components/xicore/status-object-detail.inc.php on line 2817, referer: http://eyes-sid.intradef.gouv.fr/nagiosxi/includes/components/xicore/status.php?show=hostdetail&host=gtp-auth
[Mon Jan 04 12:23:59 2016] [error] [client 160.147.161.227] PHP Warning: simplexml_load_file(): I/O warning : failed to load external entity "/usr/local/nagios/share/perfdata/aedem/Processus_Tomcat.xml" in /usr/local/nagiosxi/html/includes/components/capacityplanning/capacityplanning.inc.php on line 227, referer: http://eyes-sid.intradef.gouv.fr/nagiosxi/includes/components/xicore/status.php?show=services&servicegroup=Srv_DEMAT
[Mon Jan 04 12:47:00 2016] [error] [client 160.147.161.227] PHP Notice: Undefined variable: service in /usr/local/nagiosxi/html/includes/components/xicore/status-object-detail.inc.php on line 2817, referer: http://eyes-sid.intradef.gouv.fr/nagiosxi/includes/components/xicore/status.php?show=hostdetail&host=gtp-appli4
[Mon Jan 04 12:54:14 2016] [error] [client 160.147.161.227] PHP Warning: ldap_bind(): Unable to bind to server: Invalid credentials in /usr/local/nagiosxi/html/includes/components/ldap_ad_integration/adLDAP/src/adLDAP.php on line 714, referer: http://eyes-sid.intradef.gouv.fr/nagiosxi/login.php?redirect=/nagiosxi/admin/index.php%3f&noauth=1
[Mon Jan 04 13:04:14 2016] [error] [client 160.147.161.227] PHP Warning: ldap_bind(): Unable to bind to server: Invalid credentials in /usr/local/nagiosxi/html/includes/components/ldap_ad_integration/adLDAP/src/adLDAP.php on line 714, referer: http://eyes-sid.intradef.gouv.fr/nagiosxi/login.php?logout
[Mon Jan 04 13:05:04 2016] [error] [client 160.147.161.227] PHP Warning: array_multisort(): Argument #1 is expected to be an array or a sort flag in /usr/local/nagiosxi/html/includes/utils-tools.inc.php on line 33, referer: http://eyes-sid.intradef.gouv.fr/nagiosxi/index.php
cp: cannot stat `/usr/local/nagios/var/objects.cache\r': No such file or directory
tar: Removing leading `/' from member names
[Mon Jan 04 13:19:25 2016] [error] [client 160.147.161.227] PHP Notice: Undefined offset: 1 in /usr/local/nagiosxi/html/includes/components/graphexplorer/templates/perfdata.inc.php on line 239, referer: http://eyes-sid.intradef.gouv.fr/nagiosxi/perfgraphs/
[Mon Jan 04 13:19:25 2016] [error] [client 160.147.161.227] PHP Notice: Undefined offset: 2 in /usr/local/nagiosxi/html/includes/components/graphexplorer/templates/perfdata.inc.php on line 239, referer: http://eyes-sid.intradef.gouv.fr/nagiosxi/perfgraphs/
[Mon Jan 04 13:19:25 2016] [error] [client 160.147.161.227] PHP Notice: Undefined offset: 3 in /usr/local/nagiosxi/html/includes/components/graphexplorer/templates/perfdata.inc.php on line 239, referer: http://eyes-sid.intradef.gouv.fr/nagiosxi/perfgraphs/
[Mon Jan 04 13:19:26 2016] [error] [client 160.147.161.227] PHP Notice: Undefined offset: 1 in /usr/local/nagiosxi/html/includes/components/graphexplorer/templates/perfdata.inc.php on line 239, referer: http://eyes-sid.intradef.gouv.fr/nagiosxi/perfgraphs/
[Tue Jan 05 10:00:21 2016] [error] [client ::1] PHP Warning: pg_pconnect(): PostgreSQL link lost, unable to reconnect in /usr/local/nagiosxi/html/db/adodb/drivers/adodb-postgres64.inc.php on line 682
[Tue Jan 05 10:00:21 2016] [error] [client ::1] PHP Notice: Undefined variable: result in /usr/local/nagiosxi/html/includes/db.inc.php on line 249
[Tue Jan 05 10:00:21 2016] [error] [client ::1] PHP Warning: pg_pconnect(): Unable to connect to PostgreSQL server: could not connect to server: Connection refused\n\tIs the server running on host "localhost" and accepting\n\tTCP/IP connections on port 5432?\ncould not connect to server: Connection refused\n\tIs the server running on host "localhost" and accepting\n\tTCP/IP connections on port 5432? in /usr/local/nagiosxi/html/db/adodb/drivers/adodb-postgres64.inc.php on line 682
[Tue Jan 05 10:00:43 2016] [notice] caught SIGTERM, shutting down
[Tue Jan 05 10:01:35 2016] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Tue Jan 05 10:01:35 2016] [notice] Digest: generating secret for digest authentication ...
[Tue Jan 05 10:01:35 2016] [notice] Digest: done
[Tue Jan 05 10:01:37 2016] [notice] Apache/2.2.15 (Unix) DAV/2 PHP/5.3.3 mod_ssl/2.2.15 OpenSSL/1.0.1e-fips configured -- resuming normal operations
[Tue Jan 05 10:13:26 2016] [error] [client 160.147.161.227] PHP Notice: Trying to get property of non-object in /usr/local/nagiosxi/html/includes/utils-reports.inc.php on line 225, referer: http://eyes-sid.intradef.gouv.fr/nagiosxi/reports/availability.php?&=
[Tue Jan 05 10:13:26 2016] [error] [client 160.147.161.227] PHP Warning: Invalid argument supplied for foreach() in /usr/local/nagiosxi/html/includes/utils-reports.inc.php on line 225, referer: http://eyes-sid.intradef.gouv.fr/nagiosxi/reports/availability.php?&=
150829 9:10:01 [ERROR] /usr/libexec/mysqld: Incorrect key file for table './nagios/nagios_logentries.MYI'; try to repair it
150829 9:10:02 [ERROR] Got error 127 when reading table './nagios/nagios_servicestatus'
150829 9:10:06 [ERROR] /usr/libexec/mysqld: Incorrect key file for table './nagios/nagios_hoststatus.MYI'; try to repair it
150829 9:10:22 [ERROR] Got error 127 when reading table './nagios/nagios_servicestatus'
ps -ef
UID PID PPID C STIME TTY TIME CMD
root 1 0 0 10:00 ? 00:00:01 /sbin/init
root 2 0 0 10:00 ? 00:00:00 [kthreadd]
root 3 2 0 10:00 ? 00:00:00 [migration/0]
root 4 2 0 10:00 ? 00:00:00 [ksoftirqd/0]
root 5 2 0 10:00 ? 00:00:00 [stopper/0]
root 6 2 0 10:00 ? 00:00:00 [watchdog/0]
root 7 2 0 10:00 ? 00:00:00 [migration/1]
root 8 2 0 10:00 ? 00:00:00 [stopper/1]
root 9 2 0 10:00 ? 00:00:00 [ksoftirqd/1]
root 10 2 0 10:00 ? 00:00:00 [watchdog/1]
root 11 2 0 10:00 ? 00:00:00 [migration/2]
root 12 2 0 10:00 ? 00:00:00 [stopper/2]
root 13 2 0 10:00 ? 00:00:00 [ksoftirqd/2]
root 14 2 0 10:00 ? 00:00:00 [watchdog/2]
root 15 2 0 10:00 ? 00:00:00 [migration/3]
root 16 2 0 10:00 ? 00:00:00 [stopper/3]
root 17 2 0 10:00 ? 00:00:00 [ksoftirqd/3]
root 18 2 0 10:00 ? 00:00:00 [watchdog/3]
root 19 2 0 10:00 ? 00:00:00 [events/0]
root 20 2 0 10:00 ? 00:00:00 [events/1]
root 21 2 0 10:00 ? 00:00:00 [events/2]
root 22 2 0 10:00 ? 00:00:00 [events/3]
root 23 2 0 10:00 ? 00:00:00 [cgroup]
root 24 2 0 10:00 ? 00:00:00 [khelper]
root 25 2 0 10:00 ? 00:00:00 [netns]
root 26 2 0 10:00 ? 00:00:00 [async/mgr]
root 27 2 0 10:00 ? 00:00:00 [pm]
root 28 2 0 10:00 ? 00:00:00 [sync_supers]
root 29 2 0 10:00 ? 00:00:00 [bdi-default]
root 30 2 0 10:00 ? 00:00:00 [kintegrityd/0]
root 31 2 0 10:00 ? 00:00:00 [kintegrityd/1]
root 32 2 0 10:00 ? 00:00:00 [kintegrityd/2]
root 33 2 0 10:00 ? 00:00:00 [kintegrityd/3]
root 34 2 0 10:00 ? 00:00:00 [kblockd/0]
root 35 2 0 10:00 ? 00:00:00 [kblockd/1]
root 36 2 0 10:00 ? 00:00:00 [kblockd/2]
root 37 2 0 10:00 ? 00:00:00 [kblockd/3]
root 38 2 0 10:00 ? 00:00:00 [kacpid]
root 39 2 0 10:00 ? 00:00:00 [kacpi_notify]
root 40 2 0 10:00 ? 00:00:00 [kacpi_hotplug]
root 41 2 0 10:01 ? 00:00:00 [ata_aux]
root 42 2 0 10:01 ? 00:00:00 [ata_sff/0]
root 43 2 0 10:01 ? 00:00:00 [ata_sff/1]
root 44 2 0 10:01 ? 00:00:00 [ata_sff/2]
root 45 2 0 10:01 ? 00:00:00 [ata_sff/3]
root 46 2 0 10:01 ? 00:00:00 [ksuspend_usbd]
root 47 2 0 10:01 ? 00:00:00 [khubd]
root 48 2 0 10:01 ? 00:00:00 [kseriod]
root 49 2 0 10:01 ? 00:00:00 [md/0]
root 50 2 0 10:01 ? 00:00:00 [md/1]
root 51 2 0 10:01 ? 00:00:00 [md/2]
root 52 2 0 10:01 ? 00:00:00 [md/3]
root 53 2 0 10:01 ? 00:00:00 [md_misc/0]
root 54 2 0 10:01 ? 00:00:00 [md_misc/1]
root 55 2 0 10:01 ? 00:00:00 [md_misc/2]
root 56 2 0 10:01 ? 00:00:00 [md_misc/3]
root 57 2 0 10:01 ? 00:00:00 [linkwatch]
root 59 2 0 10:01 ? 00:00:00 [khungtaskd]
root 60 2 0 10:01 ? 00:00:00 [kswapd0]
root 61 2 0 10:01 ? 00:00:00 [ksmd]
root 62 2 0 10:01 ? 00:00:00 [khugepaged]
root 63 2 0 10:01 ? 00:00:00 [aio/0]
root 64 2 0 10:01 ? 00:00:00 [aio/1]
root 65 2 0 10:01 ? 00:00:00 [aio/2]
root 66 2 0 10:01 ? 00:00:00 [aio/3]
root 67 2 0 10:01 ? 00:00:00 [crypto/0]
root 68 2 0 10:01 ? 00:00:00 [crypto/1]
root 69 2 0 10:01 ? 00:00:00 [crypto/2]
root 70 2 0 10:01 ? 00:00:00 [crypto/3]
root 78 2 0 10:01 ? 00:00:00 [kthrotld/0]
root 79 2 0 10:01 ? 00:00:00 [kthrotld/1]
root 80 2 0 10:01 ? 00:00:00 [kthrotld/2]
root 81 2 0 10:01 ? 00:00:00 [kthrotld/3]
root 82 2 0 10:01 ? 00:00:00 [pciehpd]
root 84 2 0 10:01 ? 00:00:00 [kpsmoused]
root 85 2 0 10:01 ? 00:00:00 [usbhid_resumer]
root 86 2 0 10:01 ? 00:00:00 [deferwq]
root 117 2 0 10:01 ? 00:00:00 [kdmremove]
root 118 2 0 10:01 ? 00:00:00 [kstriped]
root 347 2 0 10:01 ? 00:00:00 [scsi_eh_0]
root 348 2 0 10:01 ? 00:00:00 [scsi_eh_1]
root 355 2 0 10:01 ? 00:00:00 [mpt_poll_0]
root 356 2 0 10:01 ? 00:00:00 [mpt/0]
root 357 2 0 10:01 ? 00:00:00 [scsi_eh_2]
root 411 2 0 10:01 ? 00:00:00 [kdmflush]
root 413 2 0 10:01 ? 00:00:00 [kdmflush]
root 430 2 0 10:01 ? 00:00:00 [jbd2/dm-0-8]
root 431 2 0 10:01 ? 00:00:00 [ext4-dio-unwrit]
root 475 2 0 10:01 ? 00:00:00 [flush-8:0]
root 509 1 0 10:01 ? 00:00:00 /sbin/udevd -d
root 740 2 0 10:01 ? 00:00:00 [vmmemctl]
root 901 2 0 10:01 ? 00:00:00 [jbd2/sda1-8]
root 902 2 0 10:01 ? 00:00:00 [ext4-dio-unwrit]
root 936 2 0 10:01 ? 00:00:00 [kauditd]
root 1327 2 0 10:01 ? 00:00:00 [flush-253:0]
root 1329 1 0 10:01 ? 00:00:00 /usr/sbin/vmtoolsd
root 1420 1 0 10:01 ? 00:00:00 auditd
root 1440 1 0 10:01 ? 00:00:00 /sbin/rsyslogd -i /var/run/syslogd.pid -c 5
dbus 1453 1 0 10:01 ? 00:00:00 dbus-daemon --system
root 1495 1 0 10:01 ? 00:00:00 /usr/sbin/sshd
root 1504 1 0 10:01 ? 00:00:00 xinetd -stayalive -pidfile /var/run/xinetd.pid
ntp 1514 1 0 10:01 ? 00:00:00 ntpd -u ntp:ntp -p /var/run/ntpd.pid -g
root 1542 1514 0 10:01 ? 00:00:00 ntpd -u ntp:ntp -p /var/run/ntpd.pid -g
root 1550 1 0 10:01 ? 00:00:00 /bin/sh /usr/bin/mysqld_safe --datadir=/var/lib/mysql --socket=/var/lib/mysql/mysql.sock --pid-file=/var/run/mysqld/mysqld.pid --basedir=/usr --user=mysql
mysql 1652 1550 1 10:01 ? 00:00:03 /usr/libexec/mysqld --basedir=/usr --datadir=/var/lib/mysql --user=mysql --log-error=/var/log/mysqld.log --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/lib/mysql/mysql.sock
postgres 1691 1 0 10:01 ? 00:00:00 /usr/bin/postmaster -p 5432 -D /var/lib/pgsql/data
postgres 1693 1691 0 10:01 ? 00:00:00 postgres: logger process
postgres 1695 1691 0 10:01 ? 00:00:00 postgres: writer process
postgres 1696 1691 0 10:01 ? 00:00:00 postgres: wal writer process
postgres 1697 1691 0 10:01 ? 00:00:00 postgres: autovacuum launcher process
postgres 1698 1691 0 10:01 ? 00:00:00 postgres: stats collector process
root 1777 1 0 10:01 ? 00:00:00 /usr/libexec/postfix/master
postfix 1786 1777 0 10:01 ? 00:00:00 pickup -l -t fifo -u
postfix 1787 1777 0 10:01 ? 00:00:00 qmgr -l -t fifo -u
root 1788 1 0 10:01 ? 00:00:00 /usr/sbin/httpd
root 1798 1 0 10:01 ? 00:00:00 crond
nagios 1809 1 0 10:01 ? 00:00:00 /usr/local/nagios/bin/npcd -d -f /usr/local/nagios/etc/pnp/npcd.cfg
nagios 1825 1 0 10:01 ? 00:00:00 /usr/local/nagios/bin/ndo2db -c /usr/local/nagios/etc/ndo2db.cfg
ajaxterm 1835 1 0 10:01 ? 00:00:00 python /usr/share/ajaxterm/ajaxterm.py --daemon --port=8022 --uid=ajaxterm
nagios 1872 1 0 10:01 ? 00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios 1878 1872 0 10:01 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 1879 1872 0 10:01 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 1880 1872 0 10:01 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 1882 1872 0 10:01 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 1883 1872 0 10:01 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 1884 1872 0 10:01 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 1889 1825 0 10:01 ? 00:00:00 /usr/local/nagios/bin/ndo2db -c /usr/local/nagios/etc/ndo2db.cfg
nagios 1890 1889 2 10:01 ? 00:00:03 /usr/local/nagios/bin/ndo2db -c /usr/local/nagios/etc/ndo2db.cfg
nagios 1915 1872 0 10:01 ? 00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
apache 1917 1788 0 10:01 ? 00:00:01 /usr/sbin/httpd
apache 1918 1788 0 10:01 ? 00:00:00 /usr/sbin/httpd
apache 1919 1788 0 10:01 ? 00:00:00 /usr/sbin/httpd
apache 1920 1788 0 10:01 ? 00:00:00 /usr/sbin/httpd
apache 1921 1788 0 10:01 ? 00:00:01 /usr/sbin/httpd
apache 1922 1788 0 10:01 ? 00:00:00 /usr/sbin/httpd
apache 1923 1788 0 10:01 ? 00:00:01 /usr/sbin/httpd
apache 1924 1788 0 10:01 ? 00:00:01 /usr/sbin/httpd
apache 1935 1788 0 10:01 ? 00:00:00 /usr/sbin/httpd
apache 2028 1788 0 10:01 ? 00:00:00 /usr/sbin/httpd
apache 2029 1788 0 10:01 ? 00:00:01 /usr/sbin/httpd
root 2030 1 0 10:01 ? 00:00:00 /opt/tina/Bin/tina_daemon -td_op 1 -comm_by_pipe YES
root 2033 2030 0 10:01 ? 00:00:00 /opt/tina/Bin/tina_daemon -td_op 20 -td_shm_id 32769 -comm_by_pipe YES
apache 2039 1788 0 10:01 ? 00:00:00 /usr/sbin/httpd
apache 2040 1788 0 10:01 ? 00:00:01 /usr/sbin/httpd
apache 2041 1788 0 10:01 ? 00:00:01 /usr/sbin/httpd
apache 2042 1788 0 10:01 ? 00:00:01 /usr/sbin/httpd
root 2179 1 0 10:01 tty1 00:00:00 /sbin/mingetty /dev/tty1
root 2181 1 0 10:01 tty2 00:00:00 /sbin/mingetty /dev/tty2
root 2183 1 0 10:01 tty3 00:00:00 /sbin/mingetty /dev/tty3
root 2185 509 0 10:01 ? 00:00:00 /sbin/udevd -d
root 2186 509 0 10:01 ? 00:00:00 /sbin/udevd -d
root 2187 1 0 10:01 tty4 00:00:00 /sbin/mingetty /dev/tty4
root 2189 1 0 10:01 tty5 00:00:00 /sbin/mingetty /dev/tty5
root 2191 1 0 10:01 tty6 00:00:00 /sbin/mingetty /dev/tty6
postgres 2225 1691 0 10:01 ? 00:00:00 postgres: nagiosxi nagiosxi ::1(47844) idle
postgres 2226 1691 0 10:01 ? 00:00:00 postgres: nagiosxi nagiosxi ::1(47845) idle
postgres 2233 1691 0 10:01 ? 00:00:00 postgres: nagiosxi nagiosxi ::1(47847) idle
postgres 2251 1691 0 10:01 ? 00:00:00 postgres: nagiosxi nagiosxi ::1(47860) idle
postgres 2252 1691 0 10:01 ? 00:00:00 postgres: nagiosxi nagiosxi ::1(47861) idle
postgres 2257 1691 0 10:01 ? 00:00:00 postgres: nagiosxi nagiosxi ::1(47864) idle
postgres 2271 1691 0 10:01 ? 00:00:00 postgres: nagiosxi nagiosxi ::1(47868) idle
postgres 2272 1691 0 10:01 ? 00:00:00 postgres: nagiosxi nagiosxi ::1(47867) idle
postgres 2331 1691 0 10:01 ? 00:00:00 postgres: nagiosxi nagiosxi ::1(47903) idle
postgres 2335 1691 0 10:01 ? 00:00:00 postgres: nagiosxi nagiosxi ::1(47904) idle
postgres 2336 1691 0 10:01 ? 00:00:00 postgres: nagiosxi nagiosxi ::1(47905) idle
postgres 2348 1691 0 10:02 ? 00:00:00 postgres: nagiosxi nagiosxi ::1(47912) idle
postgres 2351 1691 0 10:02 ? 00:00:00 postgres: nagiosxi nagiosxi ::1(47913) idle
postgres 2587 1691 0 10:02 ? 00:00:00 postgres: nagiosxi nagiosxi ::1(47988) idle
root 2912 1495 0 10:02 ? 00:00:00 sshd: root@pts/0
root 3107 1495 0 10:03 ? 00:00:00 sshd: root@notty
root 3111 3107 0 10:03 ? 00:00:00 /usr/libexec/openssh/sftp-server
root 3115 2912 0 10:03 pts/0 00:00:00 -bash
postgres 3228 1691 0 10:03 ? 00:00:00 postgres: nagiosxi nagiosxi ::1(48233) idle
root 3562 1798 0 10:04 ? 00:00:00 CROND
root 3563 1798 0 10:04 ? 00:00:00 CROND
root 3564 1798 0 10:04 ? 00:00:00 CROND
root 3565 1798 0 10:04 ? 00:00:00 CROND
root 3566 1798 0 10:04 ? 00:00:00 CROND
nagios 3569 3565 0 10:04 ? 00:00:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php > /usr/local/nagiosxi/var/cmdsubsys.log 2>&1
nagios 3571 3563 0 10:04 ? 00:00:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php > /usr/local/nagiosxi/var/feedproc.log 2>&1
nagios 3574 3566 0 10:04 ? 00:00:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php > /usr/local/nagiosxi/var/sysstat.log 2>&1
nagios 3575 3562 0 10:04 ? 00:00:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php > /usr/local/nagiosxi/var/perfdataproc.log 2>&1
nagios 3577 3564 0 10:04 ? 00:00:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php > /usr/local/nagiosxi/var/eventman.log 2>&1
nagios 3578 3569 0 10:04 ? 00:00:00 /usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php
nagios 3579 3571 0 10:04 ? 00:00:00 /usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php
nagios 3580 3577 0 10:04 ? 00:00:00 /usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php
nagios 3581 3574 0 10:04 ? 00:00:00 /usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php
nagios 3582 3575 0 10:04 ? 00:00:00 /usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php
postgres 3584 1691 0 10:04 ? 00:00:00 postgres: nagiosxi nagiosxi ::1(48381) idle
postgres 3590 1691 0 10:04 ? 00:00:00 postgres: nagiosxi nagiosxi ::1(48384) idle
postgres 3595 1691 0 10:04 ? 00:00:00 postgres: nagiosxi nagiosxi ::1(48385) idle
postgres 3597 1691 0 10:04 ? 00:00:00 postgres: nagiosxi nagiosxi ::1(48386) idle
postgres 3608 1691 0 10:04 ? 00:00:00 postgres: nagiosxi nagiosxi ::1(48389) idle
nagios 3690 1879 0 10:04 ? 00:00:00 /usr/local/nagios/libexec/check_nrpe -H 160.147.112.145 -t 30 -c check_oracle_login_dwh
nagios 3694 1884 0 10:04 ? 00:00:00 /usr/local/nagios/libexec/check_nrpe -H 160.147.112.245 -t 30 -c check_total_procs
nagios 3905 1882 0 10:04 ? 00:00:00 /usr/local/nagios/libexec/check_nrpe -H 160.150.219.83 -t 30 -c check_cpu_stats
nagios 3913 1882 0 10:04 ? 00:00:00 /usr/local/nagios/libexec/check_icmp -H 221.10.140.237 -w 3000.0 80 -c 5000.0 100 -p 5
nagios 3915 1884 0 10:04 ? 00:00:00 /usr/local/nagios/libexec/check_nt -H 221.10.107.129 -s siam4321 -p 12489 -v MEMUSE -w 80 -c 90
root 3916 3115 0 10:04 pts/0 00:00:00 ps -ef
uname - a
Linux prod_eyes-sid 2.6.32-504.8.1.el6.x86_64 #1 SMP Wed Jan 28 21:11:36 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
cat /etc/*release
CentOS release 6.6 (Final)
The objects.cache error from the Apache log may be the issue. Can you run the following as root on the XI server and post the results?
Thanks.
ls -l /usr/local/nagios/
ls -l /usr/local/nagios/var/
grep objects.cache /usr/local/nagios/etc/nagios.cfg
Hi
_____
total 28
drwxrwxr-x 2 nagios nagios 4096 16 déc. 10:36 bin
drwsrwsr-x 7 apache nagios 4096 16 déc. 17:54 etc
drwxr-xr-x 2 root root 4096 16 mai 2014 include
drwxrwsr-x 2 apache nagios 4096 16 déc. 10:37 libexec
drwxrwxr-x 2 nagios nagios 4096 16 déc. 10:36 sbin
drwxrwxr-x 18 nagios nagios 4096 16 déc. 10:36 share
drwxrwxr-x 6 nagios nagios 4096 6 janv. 08:30 var
________
total 12364
drwxrwxr-x 2 nagios nagios 40960 6 janv. 00:00 archives
-rw-r--r-- 1 nagios nagios 306 6 janv. 08:30 host-perfdata
-rw-r--r-- 1 nagios nagios 34 5 janv. 12:11 nagios.configtest
-rw-r--r-- 1 nagios nagios 6 5 janv. 10:19 nagios.lock
-rw-r--r-- 1 nagios nagios 740305 6 janv. 08:30 nagios.log
-rw-rw-r-- 1 nagios nagios 2659280 29 août 08:08 nagios.tmpe4XWIc
-rw-rw-r-- 1 nagios users 3498533 13 juin 2014 nagios.tmptxR73p
-rw-r--r-- 1 nagios nagios 5 5 janv. 10:01 ndo2db.lock
-rw-r--r-- 1 nagios nagios 0 5 janv. 10:19 ndomod.tmp
srwxr-xr-x 1 nagios nagios 0 5 janv. 10:01 ndo.sock
-rw-r--r-- 1 nagios nagios 187586 5 janv. 10:01 npcd.log
-rw-r--r-- 1 nagios nagios 163399 8 oct. 2014 npcd.org.log
-rw-r--r-- 1 nagios nagios 992166 5 janv. 10:19 objects.cache
-rw-r--r-- 1 nagios nagios 992166 5 janv. 12:11 objects.precache
-rw-rw-rw- 1 nagios users 258941 29 août 08:37 perfdata.log
-rw------- 1 nagios nagios 1538107 6 janv. 08:19 retention.dat
drwxrwsr-x 2 nagios nagcmd 4096 5 janv. 10:19 rw
-rw-r--r-- 1 nagios nagios 2783 6 janv. 08:30 service-perfdata
drwxr-xr-x 5 root root 4096 14 oct. 2013 spool
drwxr-xr-x 2 nagios nagios 4096 5 janv. 2015 stats
-rw-rw-r-- 1 nagios nagios 1529941 6 janv. 08:30 status.dat
_____
object_cache_file=/usr/local/nagios/var/objects.cache
The permissions for the objects.cache file look good so that was a false alarm.
Can you post the upgrade.log file here so we can review it?
Can you run the following as root on the server while you run a report and post any errors you receive?
And run this command and post here.
tail -f /var/log/httpd/error_logCode: Select all
tail -50 /var/log/mysqld.logBe sure to check out our Knowledgebase for helpful articles and solutions!
hi ,
No error in mysql
No error in apache
the update log file
i try to restore a backup in an other plateforme i work fine!!!!
No error in mysql
No error in apache
the update log file
I noticed your system seems to be in French? Is the other system that does work after a restore also in French? I know we have had some language-based errors in the past.
hi ,
platforms are clones.
All the changes are applied on one does on the other
In the integration environment ,
Restoring a backup Version 5.2.2 and then update to version 5.2.3.
The reports run
In the integration environment , restoring a backup production 5.2.3
The reports are not working.
In the "Event Log" I get the message "it appears as though you do not have permission to view the log file"
Arrrgg ...
The reports run
Arrrgg ...
The error in the Event Log, does it tell you which log file it cannot view?
Can you login as root to the XI server and run the following and post the output here?
ls -l /usr/local/nagios/varBe sure to check out our Knowledgebase for helpful articles and solutions!
