Host Group Status Summary
Are there any dashlets for Fusion like the Host Group Status Summary in XI? I have only found them for the individual host groups. I have to start using distributed monitoring now, and it looks like Fusion will be ideal if I can get the dashboard to look like they use in XI.
Re: Host Group Status Summary
I took a look at Fusion, and currently there is no way to display 'all' of the hostgroups as you have requested. You options are:
Select a single hostgroup and view its status information (naturally you could add as many individual hostgroups as you'd like to a dashboard)
Select a panel that gives you an overview of all of your servers.
Nagios Fusion is going to be re-built from scratch in the future, and the plan is to add a lot of functionality, including the ability to configure your Nagios XI servers through a single dashboard. I'm not positive when the next version of Fusion will land, but it's worth looking forward to!
Jesse
Jesse
