We have installed Nagios Xi 5.2.3 fresh on vmware using the ova template.
Imported config files for our switches.
The config files also has mrtg entries in it.
The configuration files are imported successfully
The lookup on the Dashboard shows.
Port 1 Bandwidth Usage:
(Name of the switch)
check_mrtgtraf: Unable to open MRTG log file
Usage check_mrtgtraf -F <log_file> -a <AVG
There are a few posts for Installation of MRTG installation for Nagios on Linux.
yum install mrtg output shows
Package mrtg-2.16.2-7.el6.x86_64 already installed and latest version
Nothing to do
Checked to see if mrtg direcory is available in /var/www/html/mrtg is available
There is no such directory
Request your help in resolving this.
Rgds
Prashanth.
Error- OUTPUT: check_mrtgtraf: Unable to open MRTG log file
Re: Error- OUTPUT: check_mrtgtraf: Unable to open MRTG log f
Can you post the service definition for the service that is returning that error?
Like I was mentioning this is a new installation of nagiosxi 5.2.3
We have imported the switch configurations from a config file.
The import of the switch.cfg file was successful
the service Port1 Bandwidth Usage gives the error
"check_mrtgtraf: Unable to open MRTG log file
Usage check_mrtgtraf -F <log_file> -a <AVG "
Please find the printscreen attached.
Can you verify the permissions of the /var/www/mrtg/ directory and post the output?
ls -l /var/www/mrtg/
ls -l /var/www/mrtg
total 1540
-rw-r--r-- 1 root root 2051 Jan 7 09:00 172.16.24.5_10101-day.png
-rw-r--r-- 1 root root 6788 Jan 7 09:00 172.16.24.5_10101.html
-rw-r--r-- 1 root root 51142 Jan 7 09:00 172.16.24.5_10101.log
-rw-r--r-- 1 root root 1570 Jan 7 08:15 172.16.24.5_10101-month.png
-rw-r--r-- 1 root root 51138 Jan 7 08:55 172.16.24.5_10101.old
-rw-r--r-- 1 root root 1689 Jan 7 08:50 172.16.24.5_10101-week.png
-rw-r--r-- 1 root root 1733 Jan 6 17:40 172.16.24.5_10101-year.png
-rw-r--r-- 1 root root 1734 Jan 7 09:00 172.16.24.5_10102-day.png
-rw-r--r-- 1 root root 6718 Jan 7 09:00 172.16.24.5_10102.html
-rw-r--r-- 1 root root 49102 Jan 7 09:00 172.16.24.5_10102.log
-rw-r--r-- 1 root root 1552 Jan 7 08:15 172.16.24.5_10102-month.png
-rw-r--r-- 1 root root 49103 Jan 7 08:55 172.16.24.5_10102.old
-rw-r--r-- 1 root root 1565 Jan 7 08:50 172.16.24.5_10102-week.png
-rw-r--r-- 1 root root 1733 Jan 6 17:40 172.16.24.5_10102-year.png
-rw-r--r-- 1 root root 1879 Jan 7 09:00 172.16.24.5_10103-day.png
-rw-r--r-- 1 root root 6771 Jan 7 09:00 172.16.24.5_10103.html
-rw-r--r-- 1 root root 50261 Jan 7 09:00 172.16.24.5_10103.log
-rw-r--r-- 1 root root 1589 Jan 7 08:15 172.16.24.5_10103-month.png
-rw-r--r-- 1 root root 50260 Jan 7 08:55 172.16.24.5_10103.old
-rw-r--r-- 1 root root 1590 Jan 7 08:50 172.16.24.5_10103-week.png
-rw-r--r-- 1 root root 1733 Jan 6 17:40 172.16.24.5_10103-year.png
-rw-r--r-- 1 root root 1987 Jan 7 09:00 172.16.24.5_10104-day.png
-rw-r--r-- 1 root root 6760 Jan 7 09:00 172.16.24.5_10104.html
-rw-r--r-- 1 root root 50389 Jan 7 09:00 172.16.24.5_10104.log
-rw-r--r-- 1 root root 1631 Jan 7 08:15 172.16.24.5_10104-month.png
-rw-r--r-- 1 root root 50389 Jan 7 08:55 172.16.24.5_10104.old
-rw-r--r-- 1 root root 1654 Jan 7 08:50 172.16.24.5_10104-week.png
-rw-r--r-- 1 root root 1733 Jan 6 17:40 172.16.24.5_10104-year.png
-rw-r--r-- 1 root root 2507 Jan 7 09:00 172.16.24.5_10105-day.png
-rw-r--r-- 1 root root 6784 Jan 7 09:00 172.16.24.5_10105.html
-rw-r--r-- 1 root root 51003 Jan 7 09:00 172.16.24.5_10105.log
-rw-r--r-- 1 root root 1581 Jan 7 08:15 172.16.24.5_10105-month.png
-rw-r--r-- 1 root root 51002 Jan 7 08:55 172.16.24.5_10105.old
-rw-r--r-- 1 root root 1883 Jan 7 08:50 172.16.24.5_10105-week.png
-rw-r--r-- 1 root root 1733 Jan 6 17:40 172.16.24.5_10105-year.png
-rw-r--r-- 1 root root 2032 Jan 7 09:00 172.16.24.5_10109-day.png
-rw-r--r-- 1 root root 6765 Jan 7 09:00 172.16.24.5_10109.html
-rw-r--r-- 1 root root 50177 Jan 7 09:00 172.16.24.5_10109.log
-rw-r--r-- 1 root root 1620 Jan 7 08:15 172.16.24.5_10109-month.png
-rw-r--r-- 1 root root 50177 Jan 7 08:55 172.16.24.5_10109.old
-rw-r--r-- 1 root root 1653 Jan 7 08:50 172.16.24.5_10109-week.png
-rw-r--r-- 1 root root 1733 Jan 6 17:40 172.16.24.5_10109-year.png
-rw-r--r-- 1 root root 2468 Jan 7 09:00 172.16.24.5_24-day.png
-rw-r--r-- 1 root root 6674 Jan 7 09:00 172.16.24.5_24.html
-rw-r--r-- 1 root root 49678 Jan 7 09:00 172.16.24.5_24.log
-rw-r--r-- 1 root root 1593 Jan 7 08:15 172.16.24.5_24-month.png
-rw-r--r-- 1 root root 49689 Jan 7 08:55 172.16.24.5_24.old
-rw-r--r-- 1 root root 1858 Jan 7 08:50 172.16.24.5_24-week.png
-rw-r--r-- 1 root root 1733 Jan 6 17:40 172.16.24.5_24-year.png
-rw-r--r-- 1 root root 1841 Jan 7 09:00 172.16.24.5_2-day.png
-rw-r--r-- 1 root root 6616 Jan 7 09:00 172.16.24.5_2.html
-rw-r--r-- 1 root root 48281 Jan 7 09:00 172.16.24.5_2.log
-rw-r--r-- 1 root root 1464 Jan 7 08:15 172.16.24.5_2-month.png
-rw-r--r-- 1 root root 48294 Jan 7 08:55 172.16.24.5_2.old
-rw-r--r-- 1 root root 1498 Jan 7 08:50 172.16.24.5_2-week.png
-rw-r--r-- 1 root root 1733 Jan 6 17:40 172.16.24.5_2-year.png
-rw-r--r-- 1 root root 1978 Jan 7 09:00 172.16.24.5_401-day.png
-rw-r--r-- 1 root root 6484 Jan 7 09:00 172.16.24.5_401.html
-rw-r--r-- 1 root root 48224 Jan 7 09:00 172.16.24.5_401.log
-rw-r--r-- 1 root root 1423 Jan 7 08:15 172.16.24.5_401-month.png
-rw-r--r-- 1 root root 48241 Jan 7 08:55 172.16.24.5_401.old
-rw-r--r-- 1 root root 1620 Jan 7 08:50 172.16.24.5_401-week.png
-rw-r--r-- 1 root root 1733 Jan 6 17:40 172.16.24.5_401-year.png
-rw-r--r-- 1 root root 2041 Jan 7 09:00 172.16.24.5_601-day.png
-rw-r--r-- 1 root root 6490 Jan 7 09:00 172.16.24.5_601.html
-rw-r--r-- 1 root root 48257 Jan 7 09:00 172.16.24.5_601.log
-rw-r--r-- 1 root root 1472 Jan 7 08:15 172.16.24.5_601-month.png
-rw-r--r-- 1 root root 48274 Jan 7 08:55 172.16.24.5_601.old
-rw-r--r-- 1 root root 1656 Jan 7 08:50 172.16.24.5_601-week.png
-rw-r--r-- 1 root root 1733 Jan 6 17:40 172.16.24.5_601-year.png
-rw-r--r-- 1 root root 1775 Jan 7 09:00 172.16.24.5_801-day.png
-rw-r--r-- 1 root root 6484 Jan 7 09:00 172.16.24.5_801.html
-rw-r--r-- 1 root root 48218 Jan 7 09:00 172.16.24.5_801.log
-rw-r--r-- 1 root root 1406 Jan 7 08:15 172.16.24.5_801-month.png
-rw-r--r-- 1 root root 48235 Jan 7 08:55 172.16.24.5_801.old
-rw-r--r-- 1 root root 1500 Jan 7 08:50 172.16.24.5_801-week.png
-rw-r--r-- 1 root root 1733 Jan 6 17:40 172.16.24.5_801-year.png
-rw-r--r-- 1 root root 2097 Jan 7 09:00 172.16.24.5_901-day.png
-rw-r--r-- 1 root root 6496 Jan 7 09:00 172.16.24.5_901.html
-rw-r--r-- 1 root root 48569 Jan 7 09:00 172.16.24.5_901.log
-rw-r--r-- 1 root root 1494 Jan 7 08:15 172.16.24.5_901-month.png
-rw-r--r-- 1 root root 48586 Jan 7 08:55 172.16.24.5_901.old
-rw-r--r-- 1 root root 1715 Jan 7 08:50 172.16.24.5_901-week.png
-rw-r--r-- 1 root root 1733 Jan 6 17:40 172.16.24.5_901-year.png
-rw-r--r-- 1 root root 350 Nov 12 2012 favicon.ico
-rw-r--r-- 1 root root 5464 Jan 6 17:38 index.html
Reason: Please use [code][/code] tags around long output
Can you run the following in a command prompt on the Nagios server and post the output here? I want to see if the nagios user account can run the command.
While you are logged in, can you run the following and post the output?
su nagios
/usr/local/nagios/libexec/check_mrtgtraf -F /var/www/mrtg/172.16.24.5_10101.log -a AVG -w 1000000,1000000 -c 5000000,5000000 -e 10Code: Select all
ls -l /var
ls -l /var/www
Please ignore the output of ls -l /var/www/mrtg sent to you on 7/01/2016 as this was sent to you from a previous working setup.
The new installation on nagiosxi 5.2.3 has the below output.
ls -l /var/www/mrtg
total 44
The output requested by you on Jan 8 are below.
su nagios
[nagios@nagios-11 mrtg]$ /usr/local/nagios/libexec/check_mrtgtraf -F /var/www/mrtg/172.16.24.5_10101.log -a AVG -w 1000000,1000000 -c 5000000,5000000 -e 10
Usage check_mrtgtraf -F <log_file> -a <AVG | MAX> -w <warning_pair>
-c <critical_pair> [-e expire_minutes]
ls -l /var
total 64
drwxr-xr-x. 9 root root 4096 Dec 8 22:50 cache
drwxr-xr-x. 3 root root 4096 Apr 5 2013 db
drwxr-xr-x. 3 root root 4096 Sep 23 2011 empty
drwxr-xr-x. 2 root root 4096 Sep 23 2011 games
drwxr-xr-x. 23 root root 4096 Jan 8 03:12 lib
drwxr-xr-x. 2 root root 4096 Sep 23 2011 local
drwxrwxr-x. 5 root lock 4096 Jan 8 03:12 lock
drwxr-xr-x. 8 root root 4096 Jan 7 16:58 log
lrwxrwxrwx. 1 root root 10 Apr 5 2013 mail -> spool/mail
drwxr-xr-x. 2 root root 4096 Sep 23 2011 nis
drwxr-xr-x. 2 root root 4096 Sep 23 2011 opt
drwxr-xr-x. 2 root root 4096 Sep 23 2011 preserve
drwxr-xr-x. 15 root root 4096 Jan 7 16:16 run
drwxr-xr-x. 9 root root 4096 Jan 5 14:15 spool
drwxrwxrwt. 2 root root 4096 Jan 5 14:15 tmp
drwxr-xr-x 7 root root 4096 Dec 8 22:50 www
drwxr-xr-x. 2 root root 4096 Sep 23 2011 yp
ls -l /var/www
total 20
drwxr-xr-x 2 root root 4096 Aug 24 23:23 cgi-bin
drwxr-xr-x 3 root root 4096 Dec 8 22:50 error
drwxr-xr-x 3 root root 4096 Dec 8 23:05 html
drwxr-xr-x 3 root root 4096 Dec 8 22:50 icons
drwxr-xr-x 2 root root 4096 Dec 8 22:50 mrtg
ls -l /var/www/mrtg
total 44
su nagios
ls -l /var
total 64
ls -l /var/www
total 20
It look like the new server may needs to have MRTG installed and / or configured on your new system.
If you still have access to the old server, the configs that need to be transferred should be in this folder /etc/mrtg
The issue is resolved.
I changed the permission for
/var/www/mrtg to nagios
by issuing the command
1) chown -R nagios:nagios mrtg
Then the cfgmaker commands below
2) cfgmaker --global 'WorkDir: /var/www/mrtg' --output /etc/mrtg/mrtg.cfg [email protected]
3) indexmaker --output=/var/www/mrtg/index.html /etc/mrtg/mrtg.cfg
4) env LANG=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg --logging /var/log/mrtg.log
crontab -e
*/5 * * * * env LANG=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg --logging /var/log/mrtg.log
The mrtg graphs are shown now.
Thanks for all the assistance.
crontab -e
