I am installing an evaluation environment to test dual master with nagios fusion. I am running into the following error when attempting to send a test email from the fusion server host. Neither nagios xi nor core are installed on this host.
Any ideas as to why this 404 error is occurring?
From the Mail Settings page, (located at http://fusion1.example.com/nagiosfusion ... ttings.php),
I click on http://fusion1.example.com/nagiosfusion ... temail.php
This is the result:
Not Found
The requested URL /nagiosfusion/admin/testemail.php was not found on this server.
Apache/2.2.3 (Red Hat) Server at fusion1.example.com Port 80
So.... why is testemail.php not installed? Is this indicative of another problem, a configuration error, or something else? Where would I get testemail.php? How do I verify other key components are missing or not missing- is there a log that I can run a diff against?
billalbertson
___________
Bill Albertson
Bill Albertson
Re: testemail.php was not found on this server
You are correct, that particular script is missing. Let me see what's going on there and I"ll post back with a solution.
Unzip and copy the following file to:
/usr/local/nagiosfusion/html/admin
Thanks for the heads up, we'll make sure this is fixed in the next update.
billalbertson
Good deal, thanks for the update!
