Reactor fullinstall fails
cpss454
Post by cpss454 »
Problem: Reactor manual installation fails with error:
Running 'timezone'...
./libinstall.sh: line 279: /etc/sysconfig/clock: No such file or directory
Environment: Nagios XI 5.2.3 (Enterprise), CentOS 7.2.1151 x86_64
(/tmp/nagiosreactor/install.log and Nagios system profile attached to this post)
Steps to reproduce:
1. Ran yum update (successful)
2. Bounced server
3. Ran commands per Reactor Installation Instructions:
cd /tmp
wget http://assets.nagios.com/downloads/nagi ... est.tar.gz
tar xzf reactor-latest.tar.gz
cd nagiosreactor
./fullinstall
hsmith
Agent Smith
Re: Reactor fullinstall fails
Post by hsmith »
Are you trying to install reactor on the same server as XI? If so, that is not supported. It may work, but we can't promise that it will work, nor can we support it if it interferes with the functionality of XI.
Reactor will need to be installed on its own server.
Former Nagios Employee.
me.
cpss454
Post by cpss454 »
Ah, I didn't know that. :idea: I will install it on another server.
hsmith
Agent Smith
Post by hsmith »
Let us know if you run into issues with that. Thanks!
me.
