Having a bit of a problem with check_disk
ejacobs
Post by ejacobs »
check_disk works fine for disks mounted on / and /home but cannot fine /home/hs or /var/log/wbi, saying it cannot find the filesystems
ejacobs
Re: Having a bit of a problem with check_disk
Post by ejacobs »
Actually, that's not the problem. If I run it locally on the remote server, it works. It appears that NRPE wasn't working and it was actually looking at the nagios server, not the remote one. Still trying to debug the NRPE problem (Nagios server - CentOS 6.7, client AIX-7.1)
Can you provide the syntax you're using to run the check_disk?
Additionally, what are the permissions of /home/hs and /var/log/wbi?
