Event handler vs Free variable
PFSit
Post by PFSit »
Hi Suppport
Can you tell me how i can use "Free variable" on service, pass to event handeler script ?
I have service with Free variable _NCPAPort,_NCPAToken, that variable need pass to event handeler script witch call NCPA script "check_ncpa.py"
At command definition i tray $_SERVICENCPAToken$, $_SERVICE_NCPAToken$, $_NCPAToken$. With no value at script.
Service and event configuration:
        host_name                       XXXXXTESTXXXXXX
        service_description             OS cpu usage
        use                             xiwizard_passive_service
        max_check_attempts              1
        check_interval                  1
        retry_interval                  1
        check_period                    xi_timeperiod_24x7
        event_handler                   event_handlers_winCPU
        event_handler_enabled           1
        notification_interval           60
        notification_period             xi_timeperiod_24x7
        notifications_enabled           0
        _NCPAPort                       5693
        _NCPAToken                      NCPAtoken
        _xiwizard                       passiveobject
        register                        1
command / event configuration:
       command_name                             event_handlers_winCPU
       command_line                             $USER1$/event_hendler_execute.sh "$HOSTNAME$" "$HOSTADDRESS$" "$SERVICEDESC$" "$SERVICESTATE$" "$SERVICESTATETYPE$" "$_SERVICENCPAToken$" "$_SERVICENCPAPort$"
Script event_hendler_execute.sh:
#!/bin/bash
# $SERVICESTATE$                        A string indicating the current state of the service ("OK", "WARNING", "UNKNOWN", or "CRITICAL").
# $SERVICESTATEID$                      A number that corresponds to the current state of the service: 0=OK, 1=WARNING, 2=CRITICAL, 3=UNKNOWN.
# $SERVICEDESC$                         The long name/description of the service (i.e. "Main Website"). This value is taken from the service_description directive of the service definition.
# Service       TECHCONTACT     $_SERVICETECHCONTACT$
# Host          MAC_ADDRESS     $_HOSTMAC_ADDRESS$
# $USER1$/event_hendler_execute.sh $HOSTNAME$ $HOSTADDRESS$ $SERVICEDESC$ $SERVICESTATE$ $STATETYPE$ $_SERVICE_NCPA_Token$ $_SERVICE_NCPA_Port$
DATE=$(date)
Hostname="$1"
HostIP="$2"
ServiceDes="$3"
ServiceState="$4"
ServiceStateType="$5"
NCPAtoken="$6"
NCPAport="$7"
NCPAbin="/usr/local/nagios/libexec/check_ncpa.py"
LogFile="/var/tmp/event_exec_Handler.log"
echo -e "$DATE Debug: \t$1 .. $2 .. $3 .. $4 .. $5 .. $6 .. $7 ..end.." > $LogFile
echo -e "$DATE Debug: \tHostname=$Hostname, HostIP=$HostIP, SeviceDes=$ServiceDes, ServiceState=$ServiceState, ServiceStateType=$ServiceStateType, NCPAtoken=$NCPAtoken, NCPAport=$NCPAport ..end.." > $LogFile
if [[ "$ServiceStateType" == "HARD" && "$ServiceState" == "CRITICAL" ]]; then
        echo -e "$DATE Spoustim: \tHostname=$Hostname, HostIP=$HostIP, SeviceDes=$ServiceDes, ServiceState=$ServiceState, ServiceStateType=$ServiceStateType"  > $LogFile
        #$NCPAbin -H $HostIP -P $NCPAport -t $NCPAtoken -M agent/plugin/Event_handler_win_CPU.ps1 > $LogFile
        echo -e "$DATE Konec: \tHostname=$Hostname."  > $LogFile
 exit 0
else
        echo -e "$DATE Neprovadim: \tHostname=$Hostname, SeviceDes=$ServiceDes, ServiceState=$ServiceState, ServiceStateType=$ServiceStateType"  > $LogFile
 exit 0
fi
Log file event_exec_Handler.log on event from OK to Critical
tail -f /var/tmp/event_exec_Handler.log 2> /dev/null
Mon Jan 11 10:51:42 CET 2016 Debug:     XXXXXXXXXXXXXXX .. XXXXXXXXXXXXXXX .. OS cpu usage .. CRITICAL .. HARD .. $ .. $ ..end..
Mon Jan 11 10:51:42 CET 2016 Debug:     Hostname=XXXXXXXXXXXXXXX, HostIP=XXXXXXXXXXXXXXX, SeviceDes=OS cpu usage, ServiceState=CRITICAL, ServiceStateType=HARD, NCPAtoken=$, NCPAport=$ ..end..
Mon Jan 11 10:51:42 CET 2016 Spoustim:  Hostname=XXXXXXXXXXXXXXX, HostIP=XXXXXXXXXXXXXXX, SeviceDes=OS cpu usage, ServiceState=CRITICAL, ServiceStateType=HARD
Mon Jan 11 10:51:42 CET 2016 Konec:     Hostname=XXXXXXXXXXXXXXX.
Emty (or singel character $) bash variable NCPAtoken=$, NCPAport=$.
So, how i can pass my free variable to this script ?
thx
Michal.
Nagios XI Version : 5.4.12 | Nagios Network Analyzer Version: 2.3.1 | Manual Installation on VMware 2.6.32-504.16.2.el6.x86_64 x86_64 | CentOS release 6.6 (Final)
Re: Event handler vs Free variable
PFSit wrote:I have service with Free variable _NCPAPort,_NCPAToken, that variable need pass to event handeler script witch call NCPA script "check_ncpa.py"
You are close...
Custom variable names are converted to all uppercase before use
https://assets.nagios.com/downloads/nag ... tvars.html
Try
$_SERVICENCPATOKEN$
PFSit
Post by PFSit »
grrr :oops:
thx for reply
close
