how to check a specific process in AIX
daverdino
Post by daverdino »
I would like to monitor some processes on AIX servers. For example the TSM BA Client (dsmc schedule)
I found a script on Nagios Exchange:
check_procs2
I added to the nrpe.cfg as shown below. I am testing to monitor TSM B Client ‘dsmc’:
command[check_dsmc]=/usr/local/nagios/libexec/check_procs2 dsmc ge 2
but have this error when run from Nagios server:
Testing check from command line...
COMMAND: /usr/local/nagios/libexec/check_nrpe -H roberts -t 30 -c check_procs2 -n
OUTPUT: NRPE: Command 'check_procs2' not defined
We have this two command in the nrpe.cfg:
If I am using the wrong script would be great if you can help and advice how to monitor specific processes in AIX
thank you
Re: how to check a specific process in AIX
Did you add this line on the client machine? Also, did you restart the NRPE service after making the change?
daverdino
Post by daverdino »
Yes I added to the nrpe.cfg on the AIX client and I restarted nrpe process.
Can you post your nrpe.cfg from the client machine for us to review?
daverdino
Post by daverdino »
Please find it attached.
Ah! I missed this at first, but the reason it's not working is NRPE is looking for you to send the command defined (check_dsmc), and not check_procs2.
Try running this and post the output -
/usr/local/nagios/libexec/check_nrpe -H roberts -t 30 -c check_dsmc -n
If you want to run it with check_procs2, add this line to your nrpe.cfg -
command[check_procs2]=/usr/local/nagios/libexec/check_procs2 dsmc ge 2
