up check failure with firewall
jriker1
Post by jriker1 »
if my windows box has a firewall and the UP check is failing, short of killing the firewall what are my options?
thanks
Re: up check failure with firewall
Post by Box293 »
You can allow ICMP packets (with the Window built in firewall that's the File/Printer sharing rule).
If you have NSClient++ installed then you would have ports 5666 or 12489 open. You can use the client version check as an UP/Down check instead of a ping check:
check_nt -H win2008r2-01 -p 12489 -v CLIENTVERSION
NSClient++ 0.5.0.17 2015-11-29
or
check_nrpe -H win2008r2-01
I (0.5.0.17 2015-11-29) seem to be doing fine...
jriker1
Post by jriker1 »
Thanks for the info. I went with just opening up the ability to ping the box from the firewall. Internal machine so no biggy.
Thanks.
JR
Sounds good. Am I good to mark this thread as solved, and close it out?
jriker1
Post by jriker1 »
Close away.
