Nagios XI Don't Send E-Mail
as your advice, I'm opening a new Thread for this new Problem.
Nagios XI is not sending Alerts E-Mail anymore.
All notification rules are always the same (all enabled), and if I try to send a E-Mail Test from Nagios XI, I receveid it.
Any advice?
Thank you.
Any advice?
Thank you.
Re: Nagios XI Don't Send E-Mail
Are you using sendmail or SMTP? Is this happening for all of your hosts / services or just one in particular?
Can you run tail -n 200 /usr/local/nagios/var/nagios.log and post the result?
Sendmail, and this is happening for all my HOSTS.rkennedy wrote:Are you using sendmail or SMTP? Is this happening for all of your hosts / services or just one in particular?
[1452814543] External command error: Command failed
[1452814974] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-20CACEIS', but the service could not be found!
[1452814974] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-20CACEIS;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452814974] External command error: Command failed
[1452815430] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-101SIA', but the service could not be found!
[1452815430] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-101SIA;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452815430] External command error: Command failed
[1452816315] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-101SIA', but the service could not be found!
[1452816315] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-101SIA;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452816315] External command error: Command failed
[1452816608] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-20CACEIS', but the service could not be found!
[1452816608] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-20CACEIS;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452816608] External command error: Command failed
[1452816776] Auto-save of retention data completed successfully.
[1452816915] Warning: Passive check result was received for service 'Application EventLog' on host 'KFINANCETEST-20CACEIS', but the service could not be found!
[1452816915] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-20CACEIS;Application EventLog;2;Application [CertEnroll #65]: Local system {FD0AB85F-3AD8-4305-ACC8-30E9BD5F2984}
[1452816915] External command error: Command failed
[1452816915] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-20CACEIS;Application EventLog;2;Application [CertEnroll #64]: Local system
[1452816915] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-20CACEIS;Application EventLog;2;Application [warning] [AutoEnrollment #64]: local system 01 2d b6 9c 44 10 77 5c ee 2b f6 69 2f c4 88 14 e3 ea 0a af
[1452817201] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-101SIA', but the service could not be found!
[1452817201] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-101SIA;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452817201] External command error: Command failed
[1452818087] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-101SIA', but the service could not be found!
[1452818087] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-101SIA;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452818087] External command error: Command failed
[1452818245] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-20CACEIS', but the service could not be found!
[1452818245] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-20CACEIS;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452818245] External command error: Command failed
[1452818974] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-101SIA', but the service could not be found!
[1452818974] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-101SIA;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452818974] External command error: Command failed
[1452819860] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-101SIA', but the service could not be found!
[1452819860] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-101SIA;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452819860] External command error: Command failed
[1452819879] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-20CACEIS', but the service could not be found!
[1452819879] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-20CACEIS;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452819879] External command error: Command failed
[1452820376] Auto-save of retention data completed successfully.
[1452820746] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-101SIA', but the service could not be found!
[1452820746] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-101SIA;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452820746] External command error: Command failed
[1452821525] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-20CACEIS', but the service could not be found!
[1452821525] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-20CACEIS;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452821525] External command error: Command failed
[1452821667] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-101SIA', but the service could not be found!
[1452821667] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-101SIA;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452821667] External command error: Command failed
[1452822553] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-101SIA', but the service could not be found!
[1452822553] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-101SIA;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452822553] External command error: Command failed
[1452823159] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-20CACEIS', but the service could not be found!
[1452823159] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-20CACEIS;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452823159] External command error: Command failed
[1452823438] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-101SIA', but the service could not be found!
[1452823438] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-101SIA;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452823438] External command error: Command failed
[1452823976] Auto-save of retention data completed successfully.
[1452824326] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-101SIA', but the service could not be found!
[1452824326] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-101SIA;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452824326] External command error: Command failed
[1452824793] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-20CACEIS', but the service could not be found!
[1452824793] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-20CACEIS;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452824793] External command error: Command failed
[1452825212] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-101SIA', but the service could not be found!
[1452825212] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-101SIA;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452825212] External command error: Command failed
[1452826097] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-101SIA', but the service could not be found!
[1452826097] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-101SIA;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452826097] External command error: Command failed
[1452826427] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-20CACEIS', but the service could not be found!
[1452826427] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-20CACEIS;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452826427] External command error: Command failed
[1452826983] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-101SIA', but the service could not be found!
[1452826983] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-101SIA;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452826983] External command error: Command failed
[1452827578] Auto-save of retention data completed successfully.
[1452827868] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-101SIA', but the service could not be found!
[1452827868] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-101SIA;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452827868] External command error: Command failed
[1452828061] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-20CACEIS', but the service could not be found!
[1452828061] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-20CACEIS;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452828061] External command error: Command failed
[1452828752] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-101SIA', but the service could not be found!
[1452828752] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-101SIA;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452828752] External command error: Command failed
[1452829636] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-101SIA', but the service could not be found!
[1452829636] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-101SIA;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452829636] External command error: Command failed
[1452829696] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-20CACEIS', but the service could not be found!
[1452829696] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-20CACEIS;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452829696] External command error: Command failed
[1452830520] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-101SIA', but the service could not be found!
[1452830520] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-101SIA;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452830520] External command error: Command failed
[1452831176] Auto-save of retention data completed successfully.
[1452831332] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-20CACEIS', but the service could not be found!
[1452831332] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-20CACEIS;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452831332] External command error: Command failed
[1452831404] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-101SIA', but the service could not be found!
[1452831404] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-101SIA;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452831404] External command error: Command failed
[1452832288] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-101SIA', but the service could not be found!
[1452832288] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-101SIA;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452832288] External command error: Command failed
[1452832966] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-20CACEIS', but the service could not be found!
[1452832966] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-20CACEIS;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452832966] External command error: Command failed
[1452833172] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-101SIA', but the service could not be found!
[1452833172] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-101SIA;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452833172] External command error: Command failed
[1452834056] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-101SIA', but the service could not be found!
[1452834056] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-101SIA;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452834056] External command error: Command failed
[1452834600] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-20CACEIS', but the service could not be found!
[1452834600] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-20CACEIS;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452834600] External command error: Command failed
[1452834776] Auto-save of retention data completed successfully.
[1452834940] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-101SIA', but the service could not be found!
[1452834940] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-101SIA;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452834940] External command error: Command failed
[1452835824] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-101SIA', but the service could not be found!
[1452835824] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-101SIA;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452835824] External command error: Command failed
[1452836234] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-20CACEIS', but the service could not be found!
[1452836234] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-20CACEIS;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452836234] External command error: Command failed
[1452836708] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-101SIA', but the service could not be found!
[1452836708] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-101SIA;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452836708] External command error: Command failed
[1452837592] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-101SIA', but the service could not be found!
[1452837592] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-101SIA;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452837592] External command error: Command failed
[1452837680] Warning: Host performance data file processing command '/bin/mv /usr/local/nagios/var/host-perfdata /usr/local/nagios/var/spool/xidpe/1452837674.perfdata.host' timed out after 5 seconds
[1452837697] SERVICE ALERT: localhost;Current Load;WARNING;SOFT;1;WARNING - load average: 5.54, 2.00, 0.81
[1452837774] SERVICE ALERT: localhost;Current Load;WARNING;SOFT;2;WARNING - load average: 6.25, 2.98, 1.24
[1452837872] Warning: Host performance data file processing command '/bin/mv /usr/local/nagios/var/host-perfdata /usr/local/nagios/var/spool/xidpe/1452837850.perfdata.host' timed out after 5 seconds
[1452837872] SERVICE ALERT: localhost;Current Load;WARNING;SOFT;3;WARNING - load average: 5.26, 3.43, 1.53
[1452837872] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-20CACEIS', but the service could not be found!
[1452837872] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-20CACEIS;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452837872] External command error: Command failed
[1452837941] SERVICE ALERT: localhost;Current Load;WARNING;HARD;4;WARNING - load average: 6.84, 4.63, 2.14
[1452837941] SERVICE NOTIFICATION: nagiosadmin;localhost;Current Load;WARNING;xi_service_notification_handler;WARNING - load average: 6.84, 4.63, 2.14
[1452838036] SERVICE ALERT: SRVKLREPO - 9.1;MySQL Connection Time;WARNING;SOFT;1;WARNING - 1.21 seconds to connect as segnalazioni
[1452838096] SERVICE ALERT: SRVKLREPO - 9.1;MySQL Connection Time;OK;SOFT;2;OK - 0.18 seconds to connect as segnalazioni
[1452838376] Auto-save of retention data completed successfully.
[1452838427] Warning: Passive check result was received for service 'System EventLog' on host 'KFINANCETEST-20CACEIS', but the service could not be found!
[1452838427] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-20CACEIS;System EventLog;2;System [warning] [KDC #29]: No description available
[1452838427] External command error: Command failed
[1452838482] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-101SIA', but the service could not be found!
[1452838482] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-101SIA;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452838482] External command error: Command failed
[1452838542] SERVICE ALERT: localhost;Current Load;OK;HARD;4;OK - load average: 1.37, 2.49, 2.32
[1452838542] SERVICE NOTIFICATION: nagiosadmin;localhost;Current Load;OK;xi_service_notification_handler;OK - load average: 1.37, 2.49, 2.32
[1452839101] Warning: Passive check result was received for service 'Application EventLog' on host 'KFINANCETEST-101SIA', but the service could not be found!
[1452839101] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-101SIA;Application EventLog;2;Application [error] [Report Server Windows Service (MSSQLSERVER) #107]: Report Server Windows Service (MSSQLSERVER)
[1452839101] External command error: Command failed
[1452839367] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-101SIA', but the service could not be found!
[1452839367] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-101SIA;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452839367] External command error: Command failed
[1452839505] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-20CACEIS', but the service could not be found!
[1452839505] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-20CACEIS;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452839505] External command error: Command failed
[1452840251] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-101SIA', but the service could not be found!
[1452840251] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-101SIA;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452840251] External command error: Command failed
[1452841140] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-20CACEIS', but the service could not be found!
[1452841140] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-20CACEIS;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452841140] External command error: Command failed
[1452841216] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-101SIA', but the service could not be found!
[1452841216] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-101SIA;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452841216] External command error: Command failed
[1452841883] Warning: Passive check result was received for service 'Application EventLog' on host 'KFINANCETEST-20CACEIS', but the service could not be found!
[1452841883] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-20CACEIS;Application EventLog;2;Application [error] [Application Error #1000]: Faulting application name: w4glrun.exe, version: 511.0.5104.14300, time stamp: 0x4fd6fac4 Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000 Exception code: 0xc000041d Fault offset: 0x756
[1452841883] External command error: Command failed
[1452841976] Auto-save of retention data completed successfully.
[1452842100] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-101SIA', but the service could not be found!
[1452842100] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-101SIA;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452842100] External command error: Command failed
[1452842427] Warning: Passive check result was received for service 'Application EventLog' on host 'KFINANCETEST-20CACEIS', but the service could not be found!
[1452842427] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-20CACEIS;Application EventLog;2;Application [error] [Application Error #1000]: Faulting application name: w4glrun.exe, version: 511.0.5104.14300, time stamp: 0x4fd6fac4 Faulting module name: ntdll.dll, version: 6.1.7601.18247, time stamp: 0x521ea8e7 Exception code: 0xc0000005 Fault offs
[1452842427] External command error: Command failed
[1452842775] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-20CACEIS', but the service could not be found!
[1452842775] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-20CACEIS;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452842775] External command error: Command failed
[1452842984] Warning: Passive check result was received for service 'EventLog Agent' on host 'KFINANCETEST-101SIA', but the service could not be found!
[1452842984] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-101SIA;EventLog Agent;0;HEARTBEAT [INFO #0]: Service running OK
[1452842984] External command error: Command failed
[1452843082] Warning: Passive check result was received for service 'Application EventLog' on host 'KFINANCETEST-20CACEIS', but the service could not be found!
[1452843082] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-20CACEIS;Application EventLog;2;Application [error] [Application Error #1000]: Faulting application name: w4glrun.exe, version: 511.0.5104.14300, time stamp: 0x4fd6fac4 Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000 Exception code: 0xc000041d Fault offset: 0x756
[1452843082] External command error: Command failed
[1452843115] Warning: Passive check result was received for service 'System EventLog' on host 'KFINANCETEST-20CACEIS', but the service could not be found!
[1452843115] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-20CACEIS;System EventLog;2;System [error] [UmrdpService #1111]: RICOH Aficio MP C3500 PCL 5c RICOH Aficio MP C3500 PCL 5c
[1452843115] External command error: Command failed
[1452843627] Warning: Passive check result was received for service 'Application EventLog' on host 'KFINANCETEST-20CACEIS', but the service could not be found!
[1452843627] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;KFINANCETEST-20CACEIS;Application EventLog;2;Application [error] [Application Error #1000]: Faulting application name: w4glrun.exe, version: 511.0.5104.14300, time stamp: 0x4fd6fac4 Faulting module name: ntdll.dll, version: 6.1.7601.18247, time stamp: 0x521ea8e7 Exception code: 0xc0000005 Fault offs
[1452843627] External command error: Command failed
It looks like your notifications are firing.SERVICE NOTIFICATION: nagiosadmin;localhost;Current Load;OK;xi_service_notification_handler;OK - load average: 1.37, 2.49, 2.32
Can you select SMTP and try again? It looks like you have mail settings filled in here.
I did but Notifications still not coming.rkennedy wrote:It looks like your notifications are firing.SERVICE NOTIFICATION: nagiosadmin;localhost;Current Load;OK;xi_service_notification_handler;OK - load average: 1.37, 2.49, 2.32
What should I do now?
Can you post a host / service related definition for us to take a look at?
rkennedy wrote:Can you post a host / service related definition for us to take a look at?
Also, I think that I have some stuff of mysql broken.
In /var/log i got messages and mysql.log like 2GB full (only of 2 days messages).
I tried already 2 times to repair mysql with the Nagios commands, but it seems to be all okay.
Are you using host / service groups above these to control notifications at all?
If not, it looks like you'll need to select some Notification Options. See this link - https://assets.nagios.com/downloads/nag ... ios-XI.pdf
As for the mysql, can you open a new thread for that? We like to keep issues contained to one per thread.
The problem is that it was always working, until one day, randomly is stopped sending E-Mail.rkennedy wrote:Are you using host / service groups above these to control notifications at all?
I don't understand why.
