Log Server EC2 instance upgrade to 1.4 fails
beachbar
Post by beachbar »
I am trying to upgrade the standard EC2 image instance to 1.4.0. I followed the upgrade instructions and the installation indicated it was successful, but elasticsearch database will not start and the following messages appear repeatedly on the console until a reboot. After reboot, the database remains offline and will not start using service elasticsearch start. I have tried to upgrade an existing EC2 image instance with data, and a brand new image instance. The same thing happened to both.
Jan 14, 2016 2:29:31 PM org.apache.http.impl.execchain.RetryExec execute
INFO: Retrying request to {}->http://localhost:9200
INFO: I/O exception (org.apache.http.conn.HttpHostConnectException) caught when processing request to {}->http://localhost:9200: Connect to localhost:9200 [localhost/127.0.0.1] failed: Connection refused
jolson
Attack Rabbit
Re: Log Server EC2 instance upgrade to 1.4 fails
Post by jolson »
It almost seems like elasticsearch isn't binding to localhost. Could you please get the output of the following for me?
cat /etc/*release*
cat /usr/local/nagioslogserver/elasticsearch/config/*.yml
cat /etc/hosts
cat /etc/sysconfig/elasticsearch /etc/sysconfig/logstash
tail -n200 /var/log/elasticsearch/*.log
sestatus
Twits Blog
beachbar
Post by beachbar »
These are from the new EC2 image instance I installed, verified working from the image, and then ran the upgrade process.
[~]$ cat /etc/*release*
CentOS release 6.7 (Final)
cpe:/o:centos:linux:6:GA
[~]$ cat /usr/local/nagioslogserver/elasticsearch/config/*.yml
##################### Elasticsearch Configuration Example #####################
# This file contains an overview of various configuration settings,
# targeted at operations staff. Application developers should
# consult the guide at <http://elasticsearch.org/guide>.
# The installation procedure is covered at
# <http://elasticsearch.org/guide/en/elasticsearch/reference/current/setup.html>.
# Elasticsearch comes with reasonable defaults for most settings,
# so you can try it out without bothering with configuration.
# Most of the time, these defaults are just fine for running a production
# cluster. If you're fine-tuning your cluster, or wondering about the
# effect of certain configuration option, please _do ask_ on the
# mailing list or IRC channel [http://elasticsearch.org/community].
# Any element in the configuration can be replaced with environment variables
# by placing them in ${...} notation. For example:
# node.rack: ${RACK_ENV_VAR}
# For information on supported formats and syntax for the config file, see
# <http://elasticsearch.org/guide/en/elasticsearch/reference/current/setup-configuration.html>
################################### Cluster ###################################
# Cluster name identifies your cluster for auto-discovery. If you're running
# multiple clusters on the same network, make sure you're using unique names.
cluster.name: nagios_elasticsearch
#################################### Node #####################################
# Node names are generated dynamically on startup, so you're relieved
# from configuring them manually. You can tie this node to a specific name:
# node.name: "Franz Kafka"
# Every node can be configured to allow or deny being eligible as the master,
# and to allow or deny to store the data.
# Allow this node to be eligible as a master node (enabled by default):
# node.master: true
# Allow this node to store data (enabled by default):
# node.data: true
# You can exploit these settings to design advanced cluster topologies.
# 1. You want this node to never become a master node, only to hold data.
#    This will be the "workhorse" of your cluster.
# node.master: false
# node.data: true
# 2. You want this node to only serve as a master: to not store any data and
#    to have free resources. This will be the "coordinator" of your cluster.
# node.master: true
# node.data: false
# 3. You want this node to be neither master nor data node, but
#    to act as a "search load balancer" (fetching data from nodes,
#    aggregating results, etc.)
# node.data: false
# Use the Cluster Health API [http://localhost:9200/_cluster/health], the
# Node Info API [http://localhost:9200/_nodes] or GUI tools
# such as <http://www.elasticsearch.org/overview/marvel/>,
# <http://github.com/karmi/elasticsearch-paramedic>,
# <http://github.com/lukas-vlcek/bigdesk> and
# <http://mobz.github.com/elasticsearch-head> to inspect the cluster state.
[~]$ cat /etc/hosts
127.0.0.1               localhost.localdomain localhost
::1             localhost6.localdomain6 localhost6
[~]$ cat /etc/sysconfig/elasticsearch /etc/sysconfig/logstash
# Directory where the Elasticsearch binary distribution resides
APP_DIR="/usr/local/nagioslogserver"
ES_HOME="$APP_DIR/elasticsearch"
# Heap Size (defaults to 256m min, 1g max)
# Nagios Log Server Default to 0.5 physical Memory
ES_HEAP_SIZE=$(expr $(free -m|awk '/^Mem:/{print $2}') / 2 )m
# Heap new generation
#ES_HEAP_NEWSIZE=
# max direct memory
#ES_DIRECT_SIZE=
# Additional Java OPTS
#ES_JAVA_OPTS=
# Maximum number of open files
MAX_OPEN_FILES=65535
# Maximum amount of locked memory
MAX_LOCKED_MEMORY=unlimited
# Maximum number of VMA (Virtual Memory Areas) a process can own
MAX_MAP_COUNT=262144
# Elasticsearch log directory
LOG_DIR=/var/log/elasticsearch
# Elasticsearch data directory
DATA_DIR="$ES_HOME/data"
# Elasticsearch work directory
WORK_DIR="$APP_DIR/tmp/elasticsearch"
# Elasticsearch conf directory
CONF_DIR="$ES_HOME/config"
# Elasticsearch configuration file (elasticsearch.yml)
CONF_FILE="$ES_HOME/config/elasticsearch.yml"
# User to run as, change this to a specific elasticsearch user if possible
# Also make sure, this user can write into the log directories in case you change them
# This setting only works for the init script, but has to be configured separately for systemd startup
ES_USER=nagios
ES_GROUP=nagios
# Configure restart on package upgrade (true, every other setting will lead to not restarting)
#RESTART_ON_UPGRADE=true
if [ "x$1" == "xstart" -o "x$1" == "xrestart" -o "x$1" == "xreload" -o "x$1" == "xforce-reload" ];then
        GET_ES_CONFIG_MESSAGE="$( php $APP_DIR/scripts/get_es_config.php )"
        GET_ES_CONFIG_RETURN=$?
        if [ "$GET_ES_CONFIG_RETURN" != "0" ]; then
                echo $GET_ES_CONFIG_MESSAGE
                exit 1
        else
                ES_JAVA_OPTS="$GET_ES_CONFIG_MESSAGE"
        fi
fi
# Default settings for logstash
# Override Java location
#JAVACMD=/usr/bin/java
# Set a home directory
APP_DIR=/usr/local/nagioslogserver
LS_HOME="$APP_DIR/logstash"
# set ES_CLUSTER
ES_CLUSTER=$(cat $APP_DIR/var/cluster_uuid)
# Arguments to pass to java
#LS_HEAP_SIZE="256m"
LS_JAVA_OPTS="-Djava.io.tmpdir=$APP_DIR/tmp"
# Logstash filter worker threads
#LS_WORKER_THREADS=1
# pidfiles aren't used for upstart; this is for sysv users.
#LS_PIDFILE=/var/run/logstash.pid
# user id to be invoked as; for upstart: edit /etc/init/logstash.conf
LS_USER=nagios
LS_GROUP=nagios
# logstash logging
#LS_LOG_FILE=/var/log/logstash/logstash.log
#LS_USE_GC_LOGGING="true"
# logstash configuration directory
LS_CONF_DIR="$LS_HOME/etc/conf.d"
# Open file limit; cannot be overridden in upstart
#LS_OPEN_FILES=2048
# Nice level
#LS_NICE=0
# Increate Filter workers to 4 threads
LS_OPTS=" -w 4"
if [ "x$1" == "xstart" -o "x$1" == "xrestart" -o "x$1" == "xreload" ];then
        GET_LOGSTASH_CONFIG_MESSAGE=$( php /usr/local/nagioslogserver/scripts/get_logstash_config.php )
        GET_LOGSTASH_CONFIG_RETURN=$?
        if [ "$GET_LOGSTASH_CONFIG_RETURN" != "0" ]; then
                echo $GET_LOGSTASH_CONFIG_MESSAGE
                exit 1
        fi
[~]$ tail -n200 /var/log/elasticsearch/*.log
==> /var/log/elasticsearch/e5484b24-18a8-419a-bfea-a7de2bb2defe_index_indexing_slowlog.log <==
==> /var/log/elasticsearch/e5484b24-18a8-419a-bfea-a7de2bb2defe_index_search_slowlog.log <==
==> /var/log/elasticsearch/e5484b24-18a8-419a-bfea-a7de2bb2defe.log <==
[2016-01-14 14:11:46,375][WARN ][common.jna               ] Unable to lock JVM memory (ENOMEM). This can result in part of the JVM being swapped out. Increase RLIMIT_MEMLOCK (ulimit).
[2016-01-14 14:11:47,272][INFO ][node                     ] [358bc8b4-69db-4f31-8311-70ea54fffe63] version[1.3.2], pid[1622], build[dee175d/2014-08-13T14:29:30Z]
[2016-01-14 14:11:47,273][INFO ][node                     ] [358bc8b4-69db-4f31-8311-70ea54fffe63] initializing ...
[2016-01-14 14:11:48,592][INFO ][plugins                  ] [358bc8b4-69db-4f31-8311-70ea54fffe63] loaded [knapsack-1.3.2.0-d5501ef], sites []
[2016-01-14 14:12:57,095][WARN ][common.jna               ] Unable to lock JVM memory (ENOMEM). This can result in part of the JVM being swapped out. Increase RLIMIT_MEMLOCK (ulimit).
[2016-01-14 14:12:57,450][INFO ][node                     ] [358bc8b4-69db-4f31-8311-70ea54fffe63] version[1.3.2], pid[848], build[dee175d/2014-08-13T14:29:30Z]
[2016-01-14 14:12:57,450][INFO ][node                     ] [358bc8b4-69db-4f31-8311-70ea54fffe63] initializing ...
[2016-01-14 14:12:57,499][INFO ][plugins                  ] [358bc8b4-69db-4f31-8311-70ea54fffe63] loaded [knapsack-1.3.2.0-d5501ef], sites []
[2016-01-14 14:13:03,841][INFO ][node                     ] [358bc8b4-69db-4f31-8311-70ea54fffe63] initialized
[2016-01-14 14:13:03,841][INFO ][node                     ] [358bc8b4-69db-4f31-8311-70ea54fffe63] starting ...
[2016-01-14 14:13:04,008][INFO ][transport                ] [358bc8b4-69db-4f31-8311-70ea54fffe63] bound_address {inet[/0:0:0:0:0:0:0:0:9300]}, publish_address {inet[/172.31.15.220:9300]}
[2016-01-14 14:13:04,016][INFO ][discovery                ] [358bc8b4-69db-4f31-8311-70ea54fffe63] e5484b24-18a8-419a-bfea-a7de2bb2defe/mLE1LMNmTEKwBANNIMQbUw
[2016-01-14 14:13:07,074][INFO ][cluster.service          ] [358bc8b4-69db-4f31-8311-70ea54fffe63] new_master [358bc8b4-69db-4f31-8311-70ea54fffe63][mLE1LMNmTEKwBANNIMQbUw][ip-172-31-15-220.us-west-2.compute.internal][inet[/172.31.15.220:9300]]{max_local_storage_nodes=1}, reason: zen-disco-join (elected_as_master)
[2016-01-14 14:13:07,112][INFO ][http                     ] [358bc8b4-69db-4f31-8311-70ea54fffe63] bound_address {inet[/127.0.0.1:9200]}, publish_address {inet[localhost/127.0.0.1:9200]}
[2016-01-14 14:13:07,113][INFO ][node                     ] [358bc8b4-69db-4f31-8311-70ea54fffe63] started
[2016-01-14 14:13:07,146][INFO ][gateway                  ] [358bc8b4-69db-4f31-8311-70ea54fffe63] recovered [0] indices into cluster_state
[2016-01-14 14:16:51,190][INFO ][cluster.metadata         ] [358bc8b4-69db-4f31-8311-70ea54fffe63] [nagioslogserver] creating index, cause [auto(index api)], shards [1]/[1], mappings [cf_option, node, reactor_server, snapshot, alert, _default_, query, commands, snmp_reactor, nrdp_server, user]
[2016-01-14 14:16:52,101][INFO ][cluster.metadata         ] [358bc8b4-69db-4f31-8311-70ea54fffe63] [nagioslogserver_log] creating index, cause [auto(index api)], shards [5]/[1], mappings []
[2016-01-14 14:16:52,594][INFO ][cluster.metadata         ] [358bc8b4-69db-4f31-8311-70ea54fffe63] [nagioslogserver_log] update_mapping [SECURITY] (dynamic)
[2016-01-14 14:16:52,953][INFO ][cluster.metadata         ] [358bc8b4-69db-4f31-8311-70ea54fffe63] [nagioslogserver] update_mapping [node] (dynamic)
[2016-01-14 14:17:02,612][INFO ][cluster.metadata         ] [358bc8b4-69db-4f31-8311-70ea54fffe63] [nagioslogserver_log] update_mapping [POLLER] (dynamic)
[2016-01-14 14:17:03,107][INFO ][cluster.metadata         ] [358bc8b4-69db-4f31-8311-70ea54fffe63] [nagioslogserver_log] update_mapping [JOBS] (dynamic)
[2016-01-14 14:17:18,668][INFO ][cluster.metadata         ] [358bc8b4-69db-4f31-8311-70ea54fffe63] [kibana-int] creating index, cause [auto(index api)], shards [5]/[1], mappings []
[2016-01-14 14:17:18,991][INFO ][cluster.metadata         ] [358bc8b4-69db-4f31-8311-70ea54fffe63] [kibana-int] update_mapping [dashboard] (dynamic)
[2016-01-14 14:18:08,133][INFO ][cluster.metadata         ] [358bc8b4-69db-4f31-8311-70ea54fffe63] [logstash-2016.01.14] creating index, cause [auto(bulk api)], shards [5]/[1], mappings [_default_]
[2016-01-14 14:18:08,480][INFO ][cluster.metadata         ] [358bc8b4-69db-4f31-8311-70ea54fffe63] [logstash-2016.01.14] update_mapping [syslog] (dynamic)
[2016-01-14 14:18:12,431][INFO ][cluster.metadata         ] [358bc8b4-69db-4f31-8311-70ea54fffe63] [nagioslogserver_log] update_mapping [SECURITY] (dynamic)
[2016-01-14 14:21:45,454][INFO ][node                     ] [358bc8b4-69db-4f31-8311-70ea54fffe63] stopping ...
[2016-01-14 14:21:45,774][INFO ][node                     ] [358bc8b4-69db-4f31-8311-70ea54fffe63] stopped
[2016-01-14 14:21:45,774][INFO ][node                     ] [358bc8b4-69db-4f31-8311-70ea54fffe63] closing ...
[2016-01-14 14:21:45,801][INFO ][node                     ] [358bc8b4-69db-4f31-8311-70ea54fffe63] closed
[~]$ sestatus
SELinux status:                 disabled
Reason: Please wrap long outputs in [code][/code] tags.
jolson
Attack Rabbit
Post by jolson »
Try opening the elasticsearch.yml file and adding the following lines:
discovery.zen.ping.multicast.enabled: false
discovery.zen.ping.unicast.hosts: ["localhost"]
http.host: "localhost"
transport.tcp.compress: true
bootstrap.mlockall: true
node.max_local_storage_nodes: 1
After adding the above lines, give it a restart:
service elasticsearch restart
Does this alter your behavior at all? I'm not sure why those values wouldn't be set by default if you ran a normal install - they should be. Give it a try and let me know, thanks!
Twits Blog
beachbar
Post by beachbar »
Those lines are in there. Apparently my previously posted cat output was cut off for some reason. Here are the contents of that file:
[~]$ cat /usr/local/nagioslogserver/elasticsearch/config/elasticsearch.yml
# node.master: true
# node.data: true
# node.data: true
# node.master: true
# node.data: false
# node.data: false
# A node can have generic attributes associated with it, which can later be used
# for customized shard allocation filtering, or allocation awareness. An attribute
# is a simple key value pair, similar to node.key: value, here is an example:
# node.rack: rack314
# By default, multiple nodes are allowed to start from the same installation location
# to disable it, set the following:
#################################### Index ####################################
# You can set a number of options (such as shard/replica options, mapping
# or analyzer definitions, translog settings, ...) for indices globally,
# in this file.
# Note, that it makes more sense to configure index settings specifically for
# a certain index, either when creating it or by using the index templates API.
# See <http://elasticsearch.org/guide/en/elasticsearch/reference/current/index-modules.html> and
# <http://elasticsearch.org/guide/en/elasticsearch/reference/current/indices-create-index.html>
# for more information.
# Set the number of shards (splits) of an index (5 by default):
# index.number_of_shards: 5
# Set the number of replicas (additional copies) of an index (1 by default):
# index.number_of_replicas: 1
# Note, that for development on a local machine, with small indices, it usually
# makes sense to "disable" the distributed features:
# index.number_of_shards: 1
# index.number_of_replicas: 0
# These settings directly affect the performance of index and search operations
# in your cluster. Assuming you have enough machines to hold shards and
# replicas, the rule of thumb is:
# 1. Having more *shards* enhances the _indexing_ performance and allows to
#    _distribute_ a big index across machines.
# 2. Having more *replicas* enhances the _search_ performance and improves the
#    cluster _availability_.
# The "number_of_shards" is a one-time setting for an index.
# The "number_of_replicas" can be increased or decreased anytime,
# by using the Index Update Settings API.
# Elasticsearch takes care about load balancing, relocating, gathering the
# results from nodes, etc. Experiment with different settings to fine-tune
# your setup.
# Use the Index Status API (<http://localhost:9200/A/_status>) to inspect
# the index status.
#################################### Paths ####################################
# Path to directory containing configuration (this file and logging.yml):
# path.conf: /path/to/conf
# Path to directory where to store index data allocated for this node.
# path.data: /path/to/data
# Can optionally include more than one location, causing data to be striped across
# the locations (a la RAID 0) on a file level, favouring locations with most free
# space on creation. For example:
# path.data: /path/to/data1,/path/to/data2
# Path to temporary files:
# path.work: /path/to/work
# Path to log files:
# path.logs: /path/to/logs
# Path to where plugins are installed:
# path.plugins: /path/to/plugins
#################################### Plugin ###################################
# If a plugin listed here is not installed for current node, the node will not start.
# plugin.mandatory: mapper-attachments,lang-groovy
################################### Memory ####################################
# Elasticsearch performs poorly when JVM starts swapping: you should ensure that
# it _never_ swaps.
# Set this property to true to lock the memory:
# Make sure that the ES_MIN_MEM and ES_MAX_MEM environment variables are set
# to the same value, and that the machine has enough memory to allocate
# for Elasticsearch, leaving enough memory for the operating system itself.
# You should also make sure that the Elasticsearch process is allowed to lock
# the memory, eg. by using `ulimit -l unlimited`.
############################## Network And HTTP ###############################
# Elasticsearch, by default, binds itself to the 0.0.0.0 address, and listens
# on port [9200-9300] for HTTP traffic and on port [9300-9400] for node-to-node
# communication. (the range means that if the port is busy, it will automatically
# try the next port).
# Set the bind address specifically (IPv4 or IPv6):
# network.bind_host: 192.168.0.1
# Set the address other nodes will use to communicate with this node. If not
# set, it is automatically derived. It must point to an actual IP address.
# network.publish_host: 192.168.0.1
# Set both 'bind_host' and 'publish_host':
# network.host: 192.168.0.1
# Set a custom port for the node to node communication (9300 by default):
# transport.tcp.port: 9300
# Enable compression for all communication between nodes (disabled by default):
# Set a custom port to listen for HTTP traffic:
# http.port: 9200
# Set a custom allowed content length:
# http.max_content_length: 100mb
# Disable HTTP completely:
# http.enabled: false
# Set the HTTP host to listen to
################################### Gateway ###################################
# The gateway allows for persisting the cluster state between full cluster
# restarts. Every change to the state (such as adding an index) will be stored
# in the gateway, and when the cluster starts up for the first time,
# it will read its state from the gateway.
# There are several types of gateway implementations. For more information, see
# <http://elasticsearch.org/guide/en/elasticsearch/reference/current/modules-gateway.html>.
# The default gateway type is the "local" gateway (recommended):
# gateway.type: local
# Settings below control how and when to start the initial recovery process on
# a full cluster restart (to reuse as much local data as possible when using shared
# gateway).
# Allow recovery process after N nodes in a cluster are up:
# gateway.recover_after_nodes: 1
# Set the timeout to initiate the recovery process, once the N nodes
# from previous setting are up (accepts time value):
# gateway.recover_after_time: 5m
# Set how many nodes are expected in this cluster. Once these N nodes
# are up (and recover_after_nodes is met), begin recovery process immediately
# (without waiting for recover_after_time to expire):
# gateway.expected_nodes: 2
############################# Recovery Throttling #############################
# These settings allow to control the process of shards allocation between
# nodes during initial recovery, replica allocation, rebalancing,
# or when adding and removing nodes.
# Set the number of concurrent recoveries happening on a node:
# 1. During the initial recovery
# cluster.routing.allocation.node_initial_primaries_recoveries: 4
# 2. During adding/removing nodes, rebalancing, etc
# cluster.routing.allocation.node_concurrent_recoveries: 2
# Set to throttle throughput when recovering (eg. 100mb, by default 20mb):
# indices.recovery.max_bytes_per_sec: 20mb
# Set to limit the number of open concurrent streams when
# recovering a shard from a peer:
# indices.recovery.concurrent_streams: 5
################################## Discovery ##################################
# Discovery infrastructure ensures nodes can be found within a cluster
# and master node is elected. Multicast discovery is the default.
# Set to ensure a node sees N other master eligible nodes to be considered
# operational within the cluster. Its recommended to set it to a higher value
# than 1 when running more than 2 nodes in the cluster.
# discovery.zen.minimum_master_nodes: 1
# Set the time to wait for ping responses from other nodes when discovering.
# Set this option to a higher value on a slow or congested network
# to minimize discovery failures:
# discovery.zen.ping.timeout: 3s
# For more information, see
# <http://elasticsearch.org/guide/en/elasticsearch/reference/current/modules-discovery-zen.html>
# Unicast discovery allows to explicitly control which nodes will be used
# to discover the cluster. It can be used when multicast is not present,
# or to restrict the cluster communication-wise.
# 1. Disable multicast discovery (enabled by default):
# 2. Configure an initial list of master nodes in the cluster
#    to perform discovery when new nodes (master or data) are started:
# EC2 discovery allows to use AWS EC2 API in order to perform discovery.
# You have to install the cloud-aws plugin for enabling the EC2 discovery.
# <http://elasticsearch.org/guide/en/elasticsearch/reference/current/modules-discovery-ec2.html>
# See <http://elasticsearch.org/tutorials/elasticsearch-on-ec2/>
# for a step-by-step tutorial.
# GCE discovery allows to use Google Compute Engine API in order to perform discovery.
# You have to install the cloud-gce plugin for enabling the GCE discovery.
# For more information, see <https://github.com/elasticsearch/elasticsearch-cloud-gce>.
# Azure discovery allows to use Azure API in order to perform discovery.
# You have to install the cloud-azure plugin for enabling the Azure discovery.
# For more information, see <https://github.com/elasticsearch/elasticsearch-cloud-azure>.
################################## Slow Log ##################################
# Shard level query and fetch threshold logging.
#index.search.slowlog.threshold.query.warn: 10s
#index.search.slowlog.threshold.query.info: 5s
#index.search.slowlog.threshold.query.debug: 2s
#index.search.slowlog.threshold.query.trace: 500ms
#index.search.slowlog.threshold.fetch.warn: 1s
#index.search.slowlog.threshold.fetch.info: 800ms
#index.search.slowlog.threshold.fetch.debug: 500ms
#index.search.slowlog.threshold.fetch.trace: 200ms
#index.indexing.slowlog.threshold.index.warn: 10s
#index.indexing.slowlog.threshold.index.info: 5s
#index.indexing.slowlog.threshold.index.debug: 2s
#index.indexing.slowlog.threshold.index.trace: 500ms
################################## GC Logging ################################
#monitor.jvm.gc.young.warn: 1000ms
#monitor.jvm.gc.young.info: 700ms
#monitor.jvm.gc.young.debug: 400ms
#monitor.jvm.gc.old.warn: 10s
#monitor.jvm.gc.old.info: 5s
#monitor.jvm.gc.old.debug: 2s
jolson
Attack Rabbit
Post by jolson »
How much memory and disk space is your server configured with?
free -m
df -h
This warning is concerning, but shouldn't cause Elasticsearch to shut down. After Elasticsearch stops, take a look at /var/log/messages for any relevant information:
tail -n30 /var/log/messages
Twits Blog
beachbar
Post by beachbar »
Here is the output you requested. Thanks
[~]$ free -m
total used free shared buffers cached
Mem: 590 413 177 0 12 153
-/+ buffers/cache: 247 343
Swap: 255 16 239
[~]$ df -h
rootfs 99G 2.8G 91G 3% /
udev 276M 112K 276M 1% /dev
tmpfs 296M 0 296M 0% /dev/shm
/dev/xvde1 99G 2.8G 91G 3% /
none 296M 0 296M 0% /dev/shm
[~]$ sudo service elasticsearch restart
Stopping elasticsearch: [FAILED]
Starting elasticsearch: [ OK ]
[~]$ sudo tail -n30 /var/log/messages
Jan 18 10:09:52 ip-172-31-15-220 kernel: [ 907] 0 907 29325 2 0 0 0 crond
Jan 18 10:09:52 ip-172-31-15-220 kernel: [ 908] 48 908 59892 3 0 0 0 httpd
Jan 18 10:09:52 ip-172-31-15-220 kernel: [ 910] 48 910 59892 3 0 0 0 httpd
Jan 18 10:09:52 ip-172-31-15-220 kernel: [ 912] 48 912 59892 3 0 0 0 httpd
Jan 18 10:09:52 ip-172-31-15-220 kernel: [ 914] 48 914 59892 3 0 0 0 httpd
Jan 18 10:09:52 ip-172-31-15-220 kernel: [ 916] 48 916 59892 3 0 0 0 httpd
Jan 18 10:09:52 ip-172-31-15-220 kernel: [ 929] 0 929 32793 1 0 0 0 runuser
Jan 18 10:09:52 ip-172-31-15-220 kernel: [ 931] 502 931 390121 758 0 0 0 java
Jan 18 10:09:52 ip-172-31-15-220 kernel: [ 1025] 0 1025 1019 1 0 0 0 agetty
Jan 18 10:09:52 ip-172-31-15-220 kernel: [ 1026] 0 1026 1016 1 0 0 0 mingetty
Jan 18 10:09:52 ip-172-31-15-220 kernel: [ 1028] 0 1028 1016 1 0 0 0 mingetty
Jan 18 10:09:52 ip-172-31-15-220 kernel: [ 1030] 0 1030 1016 1 0 0 0 mingetty
Jan 18 10:09:52 ip-172-31-15-220 kernel: [ 1032] 0 1032 1016 1 0 0 0 mingetty
Jan 18 10:09:52 ip-172-31-15-220 kernel: [ 1034] 0 1034 1016 1 0 0 0 mingetty
Jan 18 10:09:52 ip-172-31-15-220 kernel: [ 1036] 0 1036 1016 1 0 0 0 mingetty
Jan 18 10:09:52 ip-172-31-15-220 kernel: [ 1584] 0 1584 4346 1 0 0 0 anacron
Jan 18 10:09:52 ip-172-31-15-220 kernel: [ 1971] 48 1971 59892 2 0 0 0 httpd
Jan 18 10:09:52 ip-172-31-15-220 kernel: [ 2020] 0 2020 23544 6 0 0 0 sshd
Jan 18 10:09:52 ip-172-31-15-220 kernel: [ 2022] 500 2022 23544 1 0 0 0 sshd
Jan 18 10:09:52 ip-172-31-15-220 kernel: [ 2023] 500 2023 27076 4 0 0 0 bash
Jan 18 10:09:52 ip-172-31-15-220 kernel: [ 2219] 502 2219 34017 2 0 0 0 crond
Jan 18 10:09:52 ip-172-31-15-220 kernel: [ 2220] 502 2220 34017 2 0 0 0 crond
Jan 18 10:09:52 ip-172-31-15-220 kernel: [ 2221] 502 2221 26515 2 0 0 0 sh
Jan 18 10:09:52 ip-172-31-15-220 kernel: [ 2222] 502 2222 26515 2 0 0 0 sh
Jan 18 10:09:52 ip-172-31-15-220 kernel: [ 2223] 502 2223 54587 51 0 0 0 php
Jan 18 10:09:52 ip-172-31-15-220 kernel: [ 2224] 502 2224 54587 39 0 0 0 php
Jan 18 10:09:52 ip-172-31-15-220 kernel: [ 2315] 502 2315 323212 136094 0 0 0 java
Jan 18 10:09:52 ip-172-31-15-220 kernel: [ 2328] 500 2328 27367 55 0 0 0 sudo
Jan 18 10:09:52 ip-172-31-15-220 kernel: Out of memory: Kill process 2315 (java) score 637 or sacrifice child
Jan 18 10:09:52 ip-172-31-15-220 kernel: Killed process 2315, UID 502, (java) total-vm:1292848kB, anon-rss:479556kB, file-rss:64820kB
jolson
Attack Rabbit
Post by jolson »
Your server is running out of memory and is proceeding to kill elasticsearch. Because it's a memory-heavy program, it's going to want between 4 and 8 GB of memory to run properly.
Twits Blog
beachbar
Post by beachbar »
That resolved the issue. I increased memory and everything is working well. Thank you for your help!
I'll be closing this thread now, but feel free to open another if you need anything in the future!
