check_dhcp core dump + patch (OpenBSD)
wimh
Post by wimh »
On OpenBSD 5.8, 64 bits (amd64), check_dhcp dumps core:
# /usr/local/nagios/libexec/check_dhcp -i em0
Abort trap
The attached patch fixes it.
Basically, sysctl function requires a size_t argument instead of an int.
Regards,
Wim.
nagios-plugins-2.1.1.patch
(597 Bytes) Downloaded 267 times
hsmith
Agent Smith
Re: check_dhcp core dump + patch (OpenBSD)
Post by hsmith »
Hi @wimh, thank you for the contribution!
If possible, can I ask you to post it at https://github.com/nagios-plugins/nagios-plugins? The development team browses the forums much less than the support team does, and they'll be notified you posted there. Thank you!
Former Nagios Employee.
me.
wimh
Post by wimh »
I have found someone else also found and fixed the same problem, almost a year ago.
See https://github.com/nagios-plugins/nagio ... /issues/70
It hasn't been included yet...
I've attached a patch file to the posting, hoping it will draw attention and included.
hsmith
Agent Smith
Post by hsmith »
Thanks for posting it there, I'll reach out and make sure he got an alert for it.
me.
