i monitor my Weblogic Server infraestructure accessing by jmx.
When I execute the plugin, i obtain all information i want, for example, i attach one graph (graph01.jpg) showing the result of executing the plugin.
The problem is that in nagiosgraph i can only see a limited number of these parameters. (graph02.jpg)
It´s like nagiosgraph had a limitation parsing all this data, so it only creates a limited number of rdd files and therefore, only prints the ones it can créate.
Any idea??
Thank you very much
PROBLEM WITH NAGIOSGRAPH
Re: PROBLEM WITH NAGIOSGRAPH
We are unable to provide support for NagiosGraph as this is not our product. You can find their forum here: http://sourceforge.net/p/nagiosgraph/discussion/394748
On a more general note however, if a plugin is returning this much data you likely need to pass it some arguments/flags/options to limit what you are checking.
