How to read check_snmp response
jriker1
Post by jriker1 »
When I do an SNMP walk of a particular OID I get:
snmpwalk -v2c -c public 192.168.0.8 .1.3.6.1.4.1.674.10909.1.400.20.1.4
SNMPv2-SMI::enterprises.674.10909.1.400.20.1.4.1 = INTEGER: 3
3 is the right answer. The matrix is: other(1),unknown(2),ok(3),nonCritical(4),critical(5),nonRecoverable(6)
If I do:
# ./check_snmp -H 192.168.0.8 -o .1.3.6.1.4.1.674.10909.1.400.20.1.4.1 -C public
SNMP OK - 3 | iso.3.6.1.4.1.674.10909.1.400.20.1.4.1=3
Why is it returning OK? I know it's OK, however how does check_snmp know it's OK and what would it return if a 2 was returned? Or a 1 or 6?
Thanks.
JR
hsmith
Agent Smith
Re: How to read check_snmp response
Post by hsmith »
I'm going to explain this the best way I can, and to the best of my understanding.
SNMP doesn't really return any kind of exit code. If you get one of those other codes, Nagios is going to think it is fine still, it doesn't care what the server returns, as long as the plugin runs successfully.
You'll notice there are loads of SNMP scripts out there for different products. If check_snmp had logic to know whether something was good or bad, you wouldn't need to have that many other scripts. The proper way to approach this would be to write a wrapper script that check SNMP runs inside of, and use that for your check. The script would have to have some kind of logic, to know whether or not the output was what we desired.
I'll give you a (messy) example:
#!/bin/bash
RESULT=$(/usr/local/nagios/libexec/check_snmp -H $1 -o .1.3.6.1.4.1.674.10909.1.400.20.1.4.1 -c $2)
CODE=$(echo $RESULT | awk '{print $4}')
if  [ $CODE = 3 ]
then
        echo "Yay"
#       0 is OK
        exit 0
elif [ $CODE = 2 ]
then
        echo "Darn!"
#       1 is warning
        exit 1
elif [ $CODE = 6 ]
then
        echo "Critical Mission Failure - Abort!"
#       2 is critical
        exit 2
fi
Then from the command line, run something like this:
./check_coffee_pot.sh 172.16.0.5 public
If someone else has more information, please correct me, I'm relatively new to the world of SNMP.
Former Nagios Employee.
me.
jriker1
Post by jriker1 »
Thanks for the reply. Kind of what I was thinking but know a lot of the out of the box plugins can be rather robust in options so wanted to check.
For your sample script, the echo statements. for say when it's OK, is the expectation for plugins supposed to be status pipe description?
So instead of "Yeah" would be OK|whatever is reporting 50 degrees
Thanks.
JR
hsmith
Agent Smith
Post by hsmith »
That should be just fine. It may be different for your environment, I just wanted to give you a rough idea. It's basically running the check, assigning the result to a variable, echoing the variable, awking the number out of the variable, and doing stuff based on that. There might be a better way to do it, don't take my little five minute script for something official :)
me.
