xi-5.2.3 state history wrong report while download as csv
dear expert we have xi-5.2.3 running , when we fetch state history of any service it gives right services but when we download as CSV it includes other services and its state kindly check also refer an attached snap highlighted issue
Zajil NMS
Re: xi-5.2.3 state history wrong report while download as cs
I was able to recreate the issue on my test box and filed an internal bug report (TASK ID 7502).
thanks , how would we notify and track when issue get fixed ?
Zajil NMS
There isn't a way for customers to view the status of internal bug reports. You would have to ask the status of that task ID.
FYI, it looks like this bug will be fixed in the next release of XI.
