Need agent binary link for Solaris
ranjitw
Post by ranjitw »
Hi ,
Please provide right binary for SunOS hsuntst01 5.8 Generic_117350-62 sun4u sparc SUNW,Sun-Fire-V490 .
While installation Nagios agent on solaris server I am getting following error :
Solaris test server OS version 8
root@hsuntst01:/tmp/Solaris_Agent/solaris-nrpe-agent # ./fullinstall
Nagios XI Solaris Agent Installer
This script will do a complete install of the Nagios XI
Solaris agent by executing all necessary sub-scripts.
IMPORTANT: This script should only be used on a Solaris
system. Do NOT use this on a system running
any other operating system.
Do you want to continue? [Y/n] y
Proceeding with installation...
This platform () is not currently supported.
Below is the OS details on which I need to install agent:
root@xxxxx:/tmp/Solaris_Agent/solaris-nrpe-agent # uname -a
Regards,
Ranjit W
Re: Need agent binary link for Solaris
While we do not provide binaries for most systems, we can try to get the agent to compile for you. Please bear in mind that the script performs the platform checks for a reason, and circumventing them is not recommended.
In the fullinstall script try removing the following lines near the beginning:
# Check platform and architecture
case "$platform" in
        "sol10")
                case "$arch" in
                        i386|sparc)
                                : do nothing
                                echo "This architecture ($arch) is not currently supported." >&2
                                exit 1
                esac
                echo "This platform ($platform) is not currently supported." >&2
                exit 1
esac
Then try to run the fullinstall again. It seems like the script was not able to parse out your system architecture.
ranjitw
Post by ranjitw »
We have modified the script as suggested and we are facing issues .
Could you please share the link for binary which supports solaris 8 ?
Regards,
Ranjit W
hsmith
Agent Smith
Post by hsmith »
ranjitw wrote:We have modified the script as suggested and we are facing issues
Can you please elaborate on the issues you are facing?
ranjitw wrote:Could you please share the link for binary which supports solaris 8 ?
We do not provide binaries for most systems.
Former Nagios Employee.
me.
