Manage NRDS conf file
Francesco
Post by Francesco »
I saw a web tutorial on this link: "http://library.nagios.com/library/produ ... s-tutorial".
I'd like to ask how the versions are managed editing the NRDS config file.
Is it possible to restore a previous version from NRDS config file?
Here an example:
During the day T0 I create my NRDS config file pippo.local.it node, than I apply al new services.
The day T0+2 I modify the config file (of the same node) and I apply again all the services.
The day T0+3 I would to restore the situation of T0+1.
How can I do using the NRDS file?
Tank you
Francesco
ssax
Dreams In Code
Re: Manage NRDS conf file
Post by ssax »
That functionality is not currently implemented, the version number is helpful when comparing it to other clients to make sure they have the proper version but unfortunately there isn't a revision system in place, that is a great idea though. I'll create a feature request for it.
At this time, there isn't "versioning" available in the NRDS config manager.
I have filed a feature request for it though, to be similar to how XI treats the config files. The ID is 7510.
Francesco
Post by Francesco »
Do you have a roadmap that I can have a look? I would find requests planning or which version of Nagios XI will have these features.
Thank you
Francesco
hsmith
Agent Smith
Post by hsmith »
Francesco wrote:Do you have a roadmap that I can have a look? I would find requests planning or which version of Nagios XI will have these features.
We do not currently have a publicly accessible roadmap.
I'll leave this thread open for now so you can request that we check on it at a later date. Let's give it some time though - the developers always have a lot on their plates.
Former Nagios Employee.
me.
Francesco
Post by Francesco »
I see
Thank you
Francesco
Thanks for suggesting the feature! Please only respond to this if you're looking for an update.
