who does NSClient++ run scripts as?
jriker1
Post by jriker1 »
I am trying to reboot my server (part of another thread), but had a question thought could stand on it's own. I have a batch reboot bat file that uses psshutdown.exe to reboot the server.
If I run the batch file on my computer thru a standard dos window it returns access denied.
If I run the batch file from a dos windows that I selected open as Administrator, it reboots instantly.
When I call the script what is nrpe using for the account that is running the bat file. I am not seeing it function and thinking permissions to complete the task may be an issue.
Thanks.
JR
bwallace
Re: who does NSClient++ run scripts as?
Post by bwallace »
By default, I believe NSCLIENT runs as Local System
http://docs.nsclient.org/tutorial/core/ ... g-nsclient
jriker1
Post by jriker1 »
Thanks, so even though my account is an admin (domain admin) of the box, it still requires open as admin to be selected in order to reboot from a bat file. If I set the service to run as my admin account will it work considering the above, or do I physically have to have NSClient++ run as local admin? Being a domain controller local admin is probably disabled. Thanks.
Note tried running "C:\Program Files\NSClient++\nscp.exe" test
without run as admin and gave all kinds of errors. When I opened a dos windows "as admin" and ran it came up waiting for command.
Sent a "reboot" which is the name of the script and rebooted the computer but guessing that's because of the way I manually called NSClient.
Thoughts?
JR
I believe this falls into the windows security settings. The service does indeed run as local system, as @bwallace mentioned. I am not having the same issue you are as I try to replicate, but I do have local admin. I suspect your domain admins group might not have the right permissions.
Under a normal eleveated prompt (not admin), I am seeing the following result (last few lines) -
D       core NSClient++ - 0.4.4.15 2015-11-25 Started!
D       core C:\Program Files\NSClient++/modules\CommandClient.dll.dll
D       core adding C:\Program Files\NSClient++/modules\CommandClient.dll
D       core Loading plugin: CommandClient.dll...
D        cli Enter command to execute, help for help or exit to exit...
From here, I can run any check command I otherwise would without an issue.
In your environment, can you post the output of this command ran in powershell?
get-acl -path 'C:\Program Files\NSClient++\' | format-list
We do like to keep topics contained to one issue, so please try to keep this specifically to your question, and the reboot script separate.
