Event ID monitoring consolidation or grouping
mi6agent
Post by mi6agent »
As we have to monitor lot of event ID's. Can we consolidate or group the monitoring of event ID's to reduce the number of services?
Regards,
Ravi
Re: Event ID monitoring consolidation or grouping
What exactly would you like to do with the event ID's? Are you looking to monitor them, or log them as they come in?
mi6agent
Post by mi6agent »
to monitor the events.
Got it, so you are looking for one service check to look for 10 different event ID's for example? I don't think this will work as you expect. Each event ID will need it's own service check.
