I’m trying to get to the pdf on Using the XI Config Import Prep Tool, but the link is broken:
http://assets.nagios.com/downloads/nagi ... p_Tool.pdf
I'll root around in the forum to see if I can find instructions, but if anyone knows what commands need to be run on the files i've put in /usr/local/nagios/etc/import/ i'd be grateful.
Bryant
Broken Link for XI Import Prep Tool
Re: Broken Link for XI Import Prep Tool
Fixed the link. Last time we updated the doc the name was changed slightly, check the link again.
Nicholas Scott
It's working now. Thanks for the quick response!
