How to troubleshoot Configuration Wizard issues...
lee.krause
Post by lee.krause »
Install of Nagios:
1 Nagios XI 5.2.3
2 Redhat 6.7
3 64bit
4 Manual Install of XI
I'm trying to monitor a Solaris server.
1) The Solaris server has the NRPE agent installed (2.14) with the nagios server ip in allowed_hosts.
2) When I go to the Configuration Wizard, I just get "Waiting for configuration verification......................." repeating and never ending....
Where do I start looking at troubleshooting? What logs Server side or Client side?
Thanks!
Re: How to troubleshoot Configuration Wizard issues...
Please run the following command as root from the Nagios server command line and post last 20 or so lines of output: /usr/local/nagiosxi/scripts/reconfigure_nagios.sh
lee.krause
PHP Warning: fgets() expects parameter 1 to be resource, boolean given in /usr/local/nagiosxi/scripts/nagiosql_login.php on line 53
PHP Warning: feof() expects parameter 1 to be resource, boolean given in /usr/local/nagiosxi/scripts/nagiosql_login.php on line 51
The script ran for 20 minutes and this was repeated over and over.
Does your nagiosadmin password contain any characters that aren't alphanumeric?
lee.krause
Yes.
hsmith
Agent Smith
Post by hsmith »
Are you making sure the password is wrapped in single quotes?
Former Nagios Employee.
me.
lee.krause
Where do I put the password in?
lee.krause wrote:Yes.
This may be the issue, depending what the symbol is as this query could be parsing or stripping. Can you try changing your nagiosadmin password to something alphanumeric, and then try again?
lee.krause
Do I change it in the GUI? Or is there somewhere else I need to change it?
lee.krause
Ok I changed the nagiosadmin password and here the last few lines of the script:
WRITE CONFIGS SUCCESSFUL!
OUTPUT:
Nagios Core 4.1.1
Last Modified: 08-19-2015
License: GPL
Reading configuration data...
Read main config file okay...
Checking objects...
Checked 20 services.
Checked 2 hosts.
Checked 1 host groups.
Checked 0 service groups.
Checked 5 contacts.
Checked 2 contact groups.
Checked 125 commands.
Checked 11 time periods.
Checked 0 host escalations.
Checked 2 hosts
Checked 0 host dependencies
Checked 11 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 0
RET: 0
Running configuration check...
Stopping nagios:. done.
Starting nagios: done.
