This support forum board is for support questions relating to
Nagios XI , our flagship commercial network monitoring solution.
raamardhani7
Posts: 459 Joined: Tue Jun 02, 2015 12:36 am
Post
by raamardhani7 » Mon Jan 25, 2016 1:37 am
Hi Team,
I have followed the document:
https://assets.nagios.com/downloads/na ... os-XI.pdf
Have installed the code and the output I had at the end is as below:
This installer has successfully installed both vSphere CLI and the vSphere SDK
for Perl.
The following Perl modules were found on the system but may be too old to work
with vSphere CLI:
MIME::Base64 3.14 or newer
Compress::Zlib 2.037 or newer
Compress::Raw::Zlib 2.037 or newer
version 0.78 or newer
IO::Compress::Base 2.037 or newer
IO::Compress::Zlib::Constants 2.037 or newer
LWP::Protocol::https 5.805 or newer
Socket6 0.23 or newer
IO::Socket::INET6 2.71 or newer
Enjoy,
--the VMware team
But when I a trying to run the VMware wizard from the servers, I am getting the below error. Please help me with this, thanks.
Error: It appears as though you have not installed the VMware SDK or ESX plugins on your Nagios XI server. You must have these components properly installed on your system before using this wizard.
To complete the installation of the required components please follow the Monitoring VMware with Nagios XI documentation.
Posts: 13589 Joined: Mon May 23, 2011 12:15 pm
Post
by lmiltchev » Mon Jan 25, 2016 10:14 am
Run the following command:
yum list installed | grep perl > /tmp/perl.txt
then post the "perl.txt" that was generated in the "/tmp/" directory.
Also, run the following command and show the output:
/usr/local/nagios/libexec/check_esx3.pl -V
Be sure to check out our
Knowledgebase for helpful articles and solutions!
raamardhani7
Post
by raamardhani7 » Mon Jan 25, 2016 11:52 am
lmiltchev wrote: Run the following command:
Please find the output's asked for:
check_esx3.pl 0.2.0
more /tmp/perl.txt
mod_perl.x86_64 2.0.4-11.el6_5 @rhel-x86_64-server-6
net-snmp-perl.x86_64 1:5.5-54.el6_7.1 @rhel-x86_64-server-6
perl.x86_64 4:5.10.1-141.el6_7.1 @rhel-x86_64-server-6
perl-Archive-Extract.x86_64 1:0.38-141.el6_7.1 @rhel-x86_64-server-6
perl-Archive-Tar.x86_64 1.58-141.el6_7.1 @rhel-x86_64-server-6
perl-BSD-Resource.x86_64 1.29.03-3.el6 @anaconda-RedHatEnterpriseLinux-201301301459.x86_64/6.4
perl-CGI.x86_64 3.51-141.el6_7.1 @rhel-x86_64-server-6
perl-CGI-Simple.noarch 1.113-1.el6 @epel
perl-CPAN.x86_64 1.9402-141.el6_7.1 @rhel-x86_64-server-6
perl-CPANPLUS.x86_64 0.88-141.el6_7.1 @rhel-x86_64-server-6
perl-Class-Accessor.noarch 0.31-6.1.el6 @rhel-x86_64-server-optional-6
perl-Class-Singleton.noarch 1.4-6.el6 @rhel-x86_64-server-6
perl-Compress-Raw-Bzip2.x86_64 2.052-1.el6.rf @rpmforge
perl-Compress-Raw-Zlib.x86_64 1:2.021-141.el6_7.1 @rhel-x86_64-server-6
perl-Compress-Zlib.x86_64 2.021-141.el6_7.1 @rhel-x86_64-server-6
perl-Config-General.noarch 2.52-1.el6 @rhel-x86_64-server-6
perl-Config-IniFiles.noarch 2.72-2.el6 @epel
perl-Config-Tiny.noarch 2.12-7.1.el6 @rhel-x86_64-server-optional-6
perl-Crypt-DES.x86_64 2.05-9.el6 @epel
perl-Crypt-Rijndael.x86_64 1.09-2.el6 @epel
perl-Crypt-SSLeay.x86_64 0.57-17.el6 @rhel-x86_64-server-6
perl-DBD-MySQL.x86_64 4.013-3.el6 @rhel-x86_64-server-6
perl-DBD-SQLite.x86_64 1.27-3.el6 @anaconda-RedHatEnterpriseLinux-201301301459.x86_64/6.4
perl-DBI.x86_64 1.609-4.el6 @anaconda-RedHatEnterpriseLinux-201301301459.x86_64/6.4
perl-DBIx-Simple.noarch 1.32-3.el6 @anaconda-RedHatEnterpriseLinux-201301301459.x86_64/6.4
perl-Date-Manip.noarch 6.24-1.el6 @anaconda-RedHatEnterpriseLinux-201301301459.x86_64/6.4
perl-DateTime.x86_64 1:0.5300-2.el6 @rhel-x86_64-server-6
perl-Digest-HMAC.noarch 1.01-22.el6 @rhel-x86_64-server-6
perl-Digest-SHA.x86_64 1:5.47-141.el6_7.1 @rhel-x86_64-server-6
perl-Digest-SHA1.x86_64 2.12-2.el6 @rhel-x86_64-server-6
perl-Email-Date-Format.noarch 1.002-5.el6 @rhel-x86_64-server-optional-6
perl-Error.noarch 1:0.17015-4.el6 @rhel-x86_64-server-6
perl-ExtUtils-CBuilder.x86_64 1:0.27-141.el6_7.1 @rhel-x86_64-server-6
perl-ExtUtils-Embed.x86_64 1.28-141.el6_7.1 @rhel-x86_64-server-6
perl-ExtUtils-MakeMaker.x86_64 6.55-141.el6_7.1 @rhel-x86_64-server-6
perl-ExtUtils-ParseXS.x86_64 1:2.2003.0-141.el6_7.1 @rhel-x86_64-server-6
perl-File-Fetch.x86_64 0.26-141.el6_7.1 @rhel-x86_64-server-6
perl-HTML-Parser.x86_64 3.64-2.el6 @anaconda-RedHatEnterpriseLinux-201301301459.x86_64/6.4
perl-HTML-Tagset.noarch 3.20-4.el6 @anaconda-RedHatEnterpriseLinux-201301301459.x86_64/6.4
perl-IO-Compress-Base.x86_64 2.021-141.el6_7.1 @rhel-x86_64-server-6
perl-IO-Compress-Bzip2.x86_64 2.021-141.el6_7.1 @rhel-x86_64-server-6
perl-IO-Compress-Zlib.x86_64 2.021-141.el6_7.1 @rhel-x86_64-server-6
perl-IO-Socket-INET6.noarch 2.56-4.el6 @rhel-x86_64-server-6
perl-IO-Socket-SSL.noarch 1.31-2.el6 @rhel-x86_64-server-6
perl-IO-Zlib.x86_64 1:1.09-141.el6_7.1 @rhel-x86_64-server-6
perl-IO-stringy.noarch 2.110-10.1.el6 @rhel-x86_64-server-optional-6
perl-IPC-Cmd.x86_64 1:0.56-141.el6_7.1 @rhel-x86_64-server-6
perl-JSON-XS.x86_64 1:2.27-2.el6 @epel
perl-JSON-XS-VersionOneAndTwo.noarch
perl-List-MoreUtils.x86_64 0.22-10.el6 @rhel-x86_64-server-6
perl-Locale-Maketext-Simple.x86_64 1:0.18-141.el6_7.1 @rhel-x86_64-server-6
perl-Log-Message.x86_64 1:0.02-141.el6_7.1 @rhel-x86_64-server-6
perl-Log-Message-Simple.x86_64 0.04-141.el6_7.1 @rhel-x86_64-server-6
perl-MIME-Lite.noarch 3.027-2.el6 @epel
perl-MIME-Types.noarch 1.28-2.el6 @epel
perl-Mail-IMAPClient.noarch 3.34-1.el6 @epel
perl-Mail-POP3Client.noarch 2.18-6.el6 @epel
perl-MailTools.noarch 2.04-4.el6 @rhel-x86_64-server-6
perl-Math-Calc-Units.noarch 1.07-6.el6 @epel
perl-Module-Build.x86_64 1:0.3500-141.el6_7.1 @rhel-x86_64-server-6
perl-Module-CoreList.x86_64 2.18-141.el6_7.1 @rhel-x86_64-server-6
perl-Module-Load.x86_64 1:0.16-141.el6_7.1 @rhel-x86_64-server-6
perl-Module-Load-Conditional.x86_64
perl-Module-Loaded.x86_64 1:0.02-141.el6_7.1 @rhel-x86_64-server-6
perl-Module-Pluggable.x86_64 1:3.90-141.el6_7.1 @rhel-x86_64-server-6
perl-Nagios-Plugin.noarch 0.35-2.el6.rf @rpmforge
perl-Net-DNS.x86_64 0.65-5.el6 @rhel-x86_64-server-6
perl-Net-LibIDN.x86_64 0.12-3.el6 @rhel-x86_64-server-6
perl-Net-SMTP-TLS.noarch 0.12-1.el6.rf @nagiosxi-deps
perl-Net-SNMP.noarch 5.2.0-4.el6 @epel
perl-Net-SSLeay.x86_64 1.35-9.el6 @rhel-x86_64-server-6
perl-Newt.x86_64 1.08-26.el6 @anaconda-RedHatEnterpriseLinux-201301301459.x86_64/6.4
perl-Number-Format.noarch 1.73-3.el6 @epel
perl-Object-Accessor.x86_64 1:0.34-141.el6_7.1 @rhel-x86_64-server-6
perl-Package-Constants.x86_64 1:0.02-141.el6_7.1 @rhel-x86_64-server-6
perl-Params-Check.x86_64 1:0.26-141.el6_7.1 @rhel-x86_64-server-6
perl-Params-Validate.x86_64 0.92-3.el6 @rhel-x86_64-server-6
perl-Parse-CPAN-Meta.x86_64 1:1.40-141.el6_7.1 @rhel-x86_64-server-6
perl-Parse-RecDescent.noarch 1.965-1.el6 @epel
perl-Pod-Escapes.x86_64 1:1.04-141.el6_7.1 @rhel-x86_64-server-6
perl-Pod-Simple.x86_64 1:3.13-141.el6_7.1 @rhel-x86_64-server-6
perl-RRD-Simple.noarch 1.44-1.el6.rf @rpmforge
perl-SNMP_Session.noarch 1.12-4.el6 @rhel-x86_64-server-6
perl-SOAP-Lite.noarch 0.710.10-3.el6 @rhel-x86_64-server-optional-6
perl-Socket6.x86_64 0.23-4.el6 @rhel-x86_64-server-6
perl-Term-UI.x86_64 0.20-141.el6_7.1 @rhel-x86_64-server-6
perl-Test-Harness.x86_64 3.17-141.el6_7.1 @rhel-x86_64-server-6
perl-Test-Simple.x86_64 0.92-141.el6_7.1 @rhel-x86_64-server-6
perl-Time-HiRes.x86_64 4:1.9721-141.el6_7.1 @rhel-x86_64-server-6
perl-Time-Piece.x86_64 1.15-141.el6_7.1 @rhel-x86_64-server-6
perl-TimeDate.noarch 1:1.16-13.el6 @rhel-x86_64-server-6
perl-URI.noarch 1.40-2.el6 @anaconda-RedHatEnterpriseLinux-201301301459.x86_64/6.4
perl-XML-Dumper.noarch 0.81-8.el6 @rhel-x86_64-server-6
perl-XML-Grove.noarch 0.46alpha-40.el6 @anaconda-RedHatEnterpriseLinux-201301301459.x86_64/6.4
perl-XML-LibXML.x86_64 1:1.70-5.el6 @rhel-x86_64-server-6
perl-XML-NamespaceSupport.noarch 1.10-3.el6 @rhel-x86_64-server-6
perl-XML-Parser.x86_64 2.36-7.el6 @anaconda-RedHatEnterpriseLinux-201301301459.x86_64/6.4
perl-XML-SAX.noarch 0.96-7.el6 @rhel-x86_64-server-6
perl-XML-Simple.noarch 2.18-6.el6 @rhel-x86_64-server-optional-6
perl-XML-Twig.noarch 3.34-1.el6 @anaconda-RedHatEnterpriseLinux-201301301459.x86_64/6.4
perl-YAML.noarch 0.70-4.el6 @rhel-x86_64-server-optional-6
perl-YAML-Syck.x86_64 1.07-4.el6 @anaconda-RedHatEnterpriseLinux-201301301459.x86_64/6.4
perl-common-sense.noarch 3.5-1.el6 @epel
perl-core.x86_64 5.10.1-141.el6_7.1 @rhel-x86_64-server-6
perl-devel.x86_64 4:5.10.1-141.el6_7.1 @rhel-x86_64-server-6
perl-libs.x86_64 4:5.10.1-141.el6_7.1 @rhel-x86_64-server-6
perl-libwww-perl.noarch 5.833-2.el6 @anaconda-RedHatEnterpriseLinux-201301301459.x86_64/6.4
perl-libxml-perl.noarch 0.08-10.el6 @anaconda-RedHatEnterpriseLinux-201301301459.x86_64/6.4
perl-parent.x86_64 1:0.221-141.el6_7.1 @rhel-x86_64-server-6
perl-version.x86_64 3:0.77-141.el6_7.1 @rhel-x86_64-server-6
rrdtool-perl.x86_64 1.3.8-7.el6 @rhel-x86_64-server-optional-6
hsmith
Agent Smith
Posts: 3539 Joined: Thu Jul 30, 2015 11:09 am
Post
by hsmith » Mon Jan 25, 2016 5:34 pm
Can you attempt to restart the httpd and nagios services, and see if it works? I just followed the documentation and it worked from start to finish.
service nagios restart
service httpd restart
Also, what version of XI are you running? It looks like I have version 0.2.1 of the plugin, and you only have 0.2.0.
Former Nagios Employee.
me.
raamardhani7
Post
by raamardhani7 » Mon Jan 25, 2016 7:58 pm
hsmith wrote: Can you attempt to restart the httpd and nagios services, and see if it works? I just followed the documentation and it worked from start to finish.
I am really sorry, I uploaded the output from other production server which is working fine.
Please find the update.
cat /tmp/perl.txt
perl.x86_64 4:5.10.1-141.el6 @rhel-x86_64-server-6
perl-Archive-Extract.x86_64 1:0.38-141.el6 @rhel-x86_64-server-6
perl-Archive-Tar.x86_64 1.58-141.el6 @rhel-x86_64-server-6
perl-CGI.x86_64 3.51-141.el6 @rhel-x86_64-server-6
perl-CPAN.x86_64 1.9402-141.el6 @rhel-x86_64-server-6
perl-CPANPLUS.x86_64 0.88-141.el6 @rhel-x86_64-server-6
perl-Compress-Raw-Zlib.x86_64 1:2.021-141.el6 @rhel-x86_64-server-6
perl-Compress-Zlib.x86_64 2.021-141.el6 @rhel-x86_64-server-6
perl-Digest-SHA.x86_64 1:5.47-141.el6 @rhel-x86_64-server-6
perl-ExtUtils-CBuilder.x86_64 1:0.27-141.el6 @rhel-x86_64-server-6
perl-ExtUtils-Embed.x86_64 1.28-141.el6 @rhel-x86_64-server-6
perl-ExtUtils-MakeMaker.x86_64 6.55-141.el6 @rhel-x86_64-server-6
perl-ExtUtils-ParseXS.x86_64 1:2.2003.0-141.el6 @rhel-x86_64-server-6
perl-File-Fetch.x86_64 0.26-141.el6 @rhel-x86_64-server-6
perl-IO-Compress-Base.x86_64 2.021-141.el6 @rhel-x86_64-server-6
perl-IO-Compress-Bzip2.x86_64 2.021-141.el6 @rhel-x86_64-server-6
perl-IO-Compress-Zlib.x86_64 2.021-141.el6 @rhel-x86_64-server-6
perl-IO-Zlib.x86_64 1:1.09-141.el6 @rhel-x86_64-server-6
perl-IPC-Cmd.x86_64 1:0.56-141.el6 @rhel-x86_64-server-6
perl-Locale-Maketext-Simple.x86_64 1:0.18-141.el6 @rhel-x86_64-server-6
perl-Log-Message.x86_64 1:0.02-141.el6 @rhel-x86_64-server-6
perl-Log-Message-Simple.x86_64 0.04-141.el6 @rhel-x86_64-server-6
perl-Module-Build.x86_64 1:0.3500-141.el6 @rhel-x86_64-server-6
perl-Module-CoreList.x86_64 2.18-141.el6 @rhel-x86_64-server-6
perl-Module-Load.x86_64 1:0.16-141.el6 @rhel-x86_64-server-6
perl-Module-Loaded.x86_64 1:0.02-141.el6 @rhel-x86_64-server-6
perl-Module-Pluggable.x86_64 1:3.90-141.el6 @rhel-x86_64-server-6
perl-Object-Accessor.x86_64 1:0.34-141.el6 @rhel-x86_64-server-6
perl-Package-Constants.x86_64 1:0.02-141.el6 @rhel-x86_64-server-6
perl-Params-Check.x86_64 1:0.26-141.el6 @rhel-x86_64-server-6
perl-Parse-CPAN-Meta.x86_64 1:1.40-141.el6 @rhel-x86_64-server-6
perl-Pod-Escapes.x86_64 1:1.04-141.el6 @rhel-x86_64-server-6
perl-Pod-Simple.x86_64 1:3.13-141.el6 @rhel-x86_64-server-6
perl-Term-UI.x86_64 0.20-141.el6 @rhel-x86_64-server-6
perl-Test-Harness.x86_64 3.17-141.el6 @rhel-x86_64-server-6
perl-Test-Simple.x86_64 0.92-141.el6 @rhel-x86_64-server-6
perl-Time-HiRes.x86_64 4:1.9721-141.el6 @rhel-x86_64-server-6
perl-Time-Piece.x86_64 1.15-141.el6 @rhel-x86_64-server-6
perl-core.x86_64 5.10.1-141.el6 @rhel-x86_64-server-6
perl-devel.x86_64 4:5.10.1-141.el6 @rhel-x86_64-server-6
perl-libs.x86_64 4:5.10.1-141.el6 @rhel-x86_64-server-6
perl-parent.x86_64 1:0.221-141.el6 @rhel-x86_64-server-6
perl-version.x86_64 3:0.77-141.el6 @rhel-x86_64-server-6
check_esx3.pl 0.2.1
Post
by lmiltchev » Tue Jan 26, 2016 12:36 pm
Can you run a couple of check from the command line, and show the output?
vmware host cpu check:
/usr/local/nagios/libexec/check_esx3.pl -H <ip address> -f "/usr/local/nagiosxi/etc/components/vmware/<hostname>_auth.txt" -l "CPU"
vmware guest cpu check:
/usr/local/nagios/libexec/check_esx3.pl -H <ip address> -f "/usr/local/nagiosxi/etc/components/vmware/<hostname>_auth.txt" -N "<VM name>" -l "CPU"
Note: The "xxx_auth.txt" file needs to have the following format:
Examples:
[root@localhost scripts]# /usr/local/nagios/libexec/check_esx3.pl -H x.x.x.x -f "/usr/local/nagiosxi/etc/components/vmware/VMwareHost_auth.txt" -l "CPU"
ESX3 OK - cpu usage=9887.00 MHz (29.50%) | cpu_usagemhz=9887.00Mhz;; cpu_usage=29.50%;;
[root@localhost scripts]# /usr/local/nagios/libexec/check_esx3.pl -H x.x.x.x -f "/usr/local/nagiosxi/etc/components/vmware/VMWare_Guest_auth.txt" -N "Ludmil_Debian-6_32" -l "CPU"
ESX3 OK - "Ludmil_Debian-6_32" cpu usage=12.00 MHz(0.43%) wait=19856.00 ms | cpu_usagemhz=12.00Mhz;; cpu_usage=0.43%;; cpu_wait=19856.00ms;;
raamardhani7
Post
by raamardhani7 » Wed Jan 27, 2016 12:15 am
lmiltchev wrote: Can you run a couple of check from the command line, and show the output?
Examples:
Hi Lmiltchev,
Do we need to have same ID and password created on Guests as well, or the ID created in VC is fine in pulling the information for ESX hosts.
When I am running the command for CPU on VC, i am getting this below error.
ESX3 CRITICAL - Error: Cannot complete login due to an incorrect user name or password.
Checking with our windows team on the same. User ID is a domain account, they usually use the domain followed by user ID and then enters into the server. When trying remote is the same command what we are using above is correct, just wanted to know.
Post
by lmiltchev » Wed Jan 27, 2016 11:44 am
The "auth" file is created when you run the vmware wizard. You don't need to use it while testing. You can test the check from the CLI by using "-u" and "-p" (for username & password).
/usr/local/nagios/libexec/check_esx3.pl -H <ip address> -u <'username'> -p <'password'> -l "CPU"
Since you are using a domain user, you will need to play around with the "username" to figure out what will work. Try something like this for username:
'domain/user'
'domain\user'
"domain\/user"
"domain\\user"
'user@domain'
Let me know if any of these scenarios worked for you.
raamardhani7
Post
by raamardhani7 » Wed Jan 27, 2016 12:30 pm
lmiltchev wrote: The "auth" file is created when you run the vmware wizard. You don't need to use it while testing. You can test the check from the CLI by using "-u" and "-p" (for username & password).
'domain/user'
'domain\user'
"domain\/user"
"domain\\user"
'user@domain'
domain\user is working.. Now new error
/usr/local/nagios/libexec/check_esx3.pl -H xx.xx.xx.xx -f "/usr/local/nagiosxi/etc/components/vmware/xx.xx.xx.xx_auth.txt" -l "CPU"
ESX3 CRITICAL - HOST CPU Unknown error
Posts: 6579 Joined: Mon Oct 05, 2015 11:45 am
Post
by rkennedy » Wed Jan 27, 2016 5:11 pm
You may be missing a dependency, can you verify these are installed?
once it opens, enter -
install GAAS/libwww-perl-5.837.tar.gz
What is the result now?
