install error Error: Package: nagiosxi-deps-5.2.3-1.noarch
razaahmed
Post by razaahmed »
I am running :
[root@sc-nagiosxi nagiosxi]# cat /etc/redhat-release; uname -r
Red Hat Enterprise Linux Server release 6.7 (Santiago)
2.6.32-573.12.1.el6.x86_64
The sc-nagiosxi host is register with satellite for all the updates. The rhel-6-server-optional-rpms already been added to channel.
[root@sc-nagiosxi nagiosxi]# yum -v repolist
Loading "rhnplugin" plugin
Loading "product-id" plugin
Loading "security" plugin
Loading "subscription-manager" plugin
Updating Subscription Management repositories.
Config time: 0.453
This system is receiving updates from RHN Classic or RHN Satellite.
Looking for repo options for [main]
Looking for repo options for [rhel-x86_64-server-6]
Repo 'rhel-x86_64-server-6' setting option 'enabled' = '1'
Repo 'rhel-x86_64-server-6' setting option 'gpgcheck' = '1'
Yum Version: 3.2.29
Setting up Package Sacks
pkgsack time: 0.034
Repo-id      : epel
Repo-name    : Extra Packages for Enterprise Linux 6 - x86_64
Repo-revision: 1453679201
Repo-tags    : binary-x86_64
Repo-updated : Sun Jan 24 17:36:55 2016
Repo-pkgs    : 11,922
Repo-size    : 11 G
Repo-metalink: https://mirrors.fedoraproject.org/metalink?repo=epel-6&arch=x86_64
  Updated    : Sun Jan 24 17:36:55 2016
Repo-baseurl : http://mirrors.kernel.org/fedora-epel/6/x86_64/ (22 more)
Repo-expire  : 21,600 second(s) (last: Mon Jan 25 08:11:25 2016)
Repo-id      : nagios-base
Repo-name    : Nagios
Repo-revision: 1444772471
Repo-updated : Tue Oct 13 14:42:59 2015
Repo-pkgs    : 151
Repo-size    : 1.1 G
Repo-baseurl : http://repo.nagios.com/nagios/6/
Repo-expire  : 21,600 second(s) (last: Mon Jan 25 08:11:29 2016)
Repo-id      : nagiosxi-deps
Repo-name    : Nagios XI Dependencies
Repo-revision: 1444743584
Repo-updated : Tue Oct 13 06:39:45 2015
Repo-pkgs    : 33
Repo-size    : 13 M
Repo-baseurl : http://repo.nagios.com/nagiosxi-deps/6/
Repo-id      : rhel-x86_64-server-6
Repo-name    : Red Hat Enterprise Linux Server (v. 6 for 64-bit x86_64)
Repo-updated : Sat Jan 23 02:25:57 2016
Repo-pkgs    : 16,491
Repo-size    : 29 G
Repo-baseurl : https://satellite.icumed.com/XMLRPC/GET-REQ/rhel-x86_64-server-6
Repo-id      : rpmforge
Repo-name    : RHEL 6Server - RPMforge.net - dag
Repo-updated : Thu Jul 10 18:46:59 2014
Repo-pkgs    : 4,718
Repo-size    : 2.2 G
Repo-baseurl : http://apt.sw.be/redhat/el6/en/x86_64/rpmforge
Repo-mirrors : http://mirrorlist.repoforge.org/el6/mirrors-rpmforge
Repo-expire  : 21,600 second(s) (last: Mon Jan 25 08:11:57 2016)
repolist: 33,315
getting the following error:
[root@sc-nagiosxi nagiosxi]# ./fullinstall
Nagios XI Full Installer
This script will do a complete install of Nagios XI by executing all necessary sub-scripts.
IMPORTANT: This script should only be used on a 'clean' install of CentOS or RedHat. Do NOT use this on a system that has been tasked with other purposes
or has an existing install of Nagios Core. To create such a clean install you should have selected ONLY the 'Base' package in the OS installer.
Do you want to continue? [Y/n] y
Proceeding with installation...
Checking MySQL credentials...
MySQL not yet installed - that's okay.
Running './0-repos'...
Repos already configured - exiting.
RESULT=0
Running './1-prereqs'...
Installing prerequisites...
Loaded plugins: product-id, rhnplugin, security, subscription-manager
Setting up Local Package Process
Examining /tmp/nagiosxi/packages/php-pear-HTML-Template-IT-1.3.0-2.el5.noarch.rpm: php-pear-HTML-Template-IT-1.3.0-2.el5.noarch
Marking /tmp/nagiosxi/packages/php-pear-HTML-Template-IT-1.3.0-2.el5.noarch.rpm to be installed
Examining /tmp/nagiosxi/nagiosxi-deps-5.2.3-1.noarch.rpm: nagiosxi-deps-5.2.3-1.noarch
Marking /tmp/nagiosxi/nagiosxi-deps-5.2.3-1.noarch.rpm to be installed
Resolving Dependencies
--> Running transaction check
---> Package nagiosxi-deps.noarch 0:5.2.3-1 will be installed
--> Processing Dependency: expat-devel for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: fping for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: gd for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: gd-devel for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: graphviz for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: libmcrypt for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: libmcrypt-devel for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: mod_ssl for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: mrtg for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: mysql-devel for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: nmap for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: openldap-devel for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: openssl-devel for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: perl(Crypt::Rijndael) for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: perl-Mail-IMAPClient for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: perl(Mail::POP3Client) for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: perl(Net::SMTP::TLS) for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: perl(Number::Format) for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: perl(XML::Simple) for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: perl(Class::Accessor) for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: perl-Params-Validate for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: perl-Config-Tiny for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: perl-Math-Calc-Units for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: perl-Net-DNS for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: perl-Net-SNMP for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: php for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: php-gd for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: php-mcrypt for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: php-mssql for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: php-mysql for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: php-pear for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: php-pecl-ssh2 for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: php-pgsql for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: php-snmp for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: php-xml for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: php-mbstring for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: php-ldap for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: postgresql-server for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: pymssql for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: rrdtool for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: rrdtool-perl for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: rrdtool-python for package: nagiosxi-deps-5.2.3-1.noarch
--> Processing Dependency: tftp for package: nagiosxi-deps-5.2.3-1.noarch
---> Package php-pear-HTML-Template-IT.noarch 0:1.3.0-2.el5 will be installed
---> Package expat-devel.x86_64 0:2.0.1-11.el6_2 will be installed
---> Package fping.x86_64 0:3.10-1.el6.rf will be installed
---> Package gd.x86_64 0:2.0.35-11.el6 will be installed
---> Package graphviz.x86_64 0:2.26.0-10.el6 will be installed
---> Package libmcrypt.x86_64 0:2.5.8-9.el6 will be installed
---> Package libmcrypt-devel.x86_64 0:2.5.8-9.el6 will be installed
---> Package mod_ssl.x86_64 1:2.2.15-47.el6_7.1 will be installed
---> Package mrtg.x86_64 0:2.16.2-7.el6 will be installed
--> Processing Dependency: mrtg-libs = 2.16.2-7.el6 for package: mrtg-2.16.2-7.el6.x86_64
--> Processing Dependency: perl-IO-Socket-INET6 for package: mrtg-2.16.2-7.el6.x86_64
--> Processing Dependency: perl(locales_mrtg) for package: mrtg-2.16.2-7.el6.x86_64
--> Processing Dependency: perl(MRTG_lib) for package: mrtg-2.16.2-7.el6.x86_64
--> Processing Dependency: perl-Socket6 for package: mrtg-2.16.2-7.el6.x86_64
---> Package mysql-devel.x86_64 0:5.1.73-5.el6_6 will be installed
---> Package nmap.x86_64 2:6.47-1 will be installed
---> Package openldap-devel.x86_64 0:2.4.40-7.el6_7 will be installed
--> Processing Dependency: cyrus-sasl-devel >= 2.1 for package: openldap-devel-2.4.40-7.el6_7.x86_64
---> Package openssl-devel.x86_64 0:1.0.1e-42.el6_7.2 will be installed
--> Processing Dependency: krb5-devel for package: openssl-devel-1.0.1e-42.el6_7.2.x86_64
--> Processing Dependency: zlib-devel for package: openssl-devel-1.0.1e-42.el6_7.2.x86_64
---> Package perl-Class-Accessor.noarch 0:0.31-0.6.1.el6 will be installed
---> Package perl-Crypt-Rijndael.x86_64 0:1.09-2.el6 will be installed
---> Package perl-Mail-IMAPClient.noarch 0:3.37-1.el6 will be installed
--> Processing Dependency: perl(Parse::RecDescent) for package: perl-Mail-IMAPClient-3.37-1.el6.noarch
---> Package perl-Mail-POP3Client.noarch 0:2.18-6.el6 will be installed
---> Package perl-Math-Calc-Units.noarch 0:1.07-6.el6 will be installed
---> Package perl-Net-DNS.x86_64 0:0.65-5.el6 will be installed
--> Processing Dependency: perl(Digest::HMAC_MD5) for package: perl-Net-DNS-0.65-5.el6.x86_64
---> Package perl-Net-SMTP-TLS.noarch 0:0.12-1.el6.rf will be installed
--> Processing Dependency: perl(Net::SSLeay) for package: perl-Net-SMTP-TLS-0.12-1.el6.rf.noarch
--> Processing Dependency: perl(IO::Socket::SSL) for package: perl-Net-SMTP-TLS-0.12-1.el6.rf.noarch
---> Package perl-Net-SNMP.noarch 0:5.2.0-4.el6 will be installed
--> Processing Dependency: perl(Digest::SHA1) for package: perl-Net-SNMP-5.2.0-4.el6.noarch
--> Processing Dependency: perl(Crypt::DES) for package: perl-Net-SNMP-5.2.0-4.el6.noarch
---> Package perl-Number-Format.noarch 0:1.73-3.el6 will be installed
---> Package perl-Params-Validate.x86_64 0:0.92-3.el6 will be installed
---> Package php.x86_64 0:5.3.3-46.el6_6 will be installed
--> Processing Dependency: php-common(x86-64) = 5.3.3-46.el6_6 for package: php-5.3.3-46.el6_6.x86_64
--> Processing Dependency: php-cli(x86-64) = 5.3.3-46.el6_6 for package: php-5.3.3-46.el6_6.x86_64
---> Package php-gd.x86_64 0:5.3.3-46.el6_6 will be installed
---> Package php-ldap.x86_64 0:5.3.3-46.el6_6 will be installed
---> Package php-mcrypt.x86_64 0:5.3.3-4.el6 will be installed
---> Package php-mssql.x86_64 0:5.3.3-4.el6 will be installed
--> Processing Dependency: php-pdo-abi = 20080721 for package: php-mssql-5.3.3-4.el6.x86_64
--> Processing Dependency: libsybdb.so.5()(64bit) for package: php-mssql-5.3.3-4.el6.x86_64
---> Package php-mysql.x86_64 0:5.3.3-46.el6_6 will be installed
---> Package php-pear.noarch 1:1.9.4-4.el6 will be installed
---> Package php-pecl-ssh2.x86_64 0:0.11.0-7.el6 will be installed
---> Package php-pgsql.x86_64 0:5.3.3-46.el6_6 will be installed
---> Package php-xml.x86_64 0:5.3.3-46.el6_6 will be installed
---> Package postgresql-server.x86_64 0:8.4.20-4.el6_7 will be installed
--> Processing Dependency: postgresql(x86-64) = 8.4.20-4.el6_7 for package: postgresql-server-8.4.20-4.el6_7.x86_64
---> Package pymssql.x86_64 0:1.0.2-4.el6 will be installed
---> Package rrdtool.x86_64 0:1.3.8-7.el6 will be installed
--> Processing Dependency: dejavu-lgc-sans-mono-fonts for package: rrdtool-1.3.8-7.el6.x86_64
--> Processing Dependency: dejavu-sans-mono-fonts for package: rrdtool-1.3.8-7.el6.x86_64
---> Package tftp.x86_64 0:0.49-7.el6 will be installed
---> Package cyrus-sasl-devel.x86_64 0:2.1.23-15.el6_6.2 will be installed
---> Package dejavu-lgc-sans-mono-fonts.noarch 0:2.33-1.el6 will be installed
---> Package dejavu-sans-mono-fonts.noarch 0:2.33-1.el6 will be installed
---> Package freetds.x86_64 0:0.91-2.el6 will be installed
--> Processing Dependency: libodbcinst.so.2()(64bit) for package: freetds-0.91-2.el6.x86_64
--> Processing Dependency: libodbc.so.2()(64bit) for package: freetds-0.91-2.el6.x86_64
---> Package krb5-devel.x86_64 0:1.10.3-42.el6 will be installed
--> Processing Dependency: keyutils-libs-devel for package: krb5-devel-1.10.3-42.el6.x86_64
--> Processing Dependency: libselinux-devel for package: krb5-devel-1.10.3-42.el6.x86_64
--> Processing Dependency: libcom_err-devel for package: krb5-devel-1.10.3-42.el6.x86_64
---> Package mrtg-libs.x86_64 0:2.16.2-7.el6 will be installed
--> Processing Dependency: perl(SNMP_Session) for package: mrtg-libs-2.16.2-7.el6.x86_64
--> Processing Dependency: perl(BER) for package: mrtg-libs-2.16.2-7.el6.x86_64
---> Package perl-Crypt-DES.x86_64 0:2.05-9.el6 will be installed
---> Package perl-Digest-HMAC.noarch 0:1.01-22.el6 will be installed
---> Package perl-Digest-SHA1.x86_64 0:2.12-2.el6 will be installed
---> Package perl-IO-Socket-INET6.noarch 0:2.56-4.el6 will be installed
---> Package perl-IO-Socket-SSL.noarch 0:1.31-2.el6 will be installed
--> Processing Dependency: perl(Net::LibIDN) for package: perl-IO-Socket-SSL-1.31-2.el6.noarch
---> Package perl-Net-SSLeay.x86_64 0:1.35-9.el6 will be installed
---> Package perl-Parse-RecDescent.noarch 0:1.965-1.el6 will be installed
---> Package perl-Socket6.x86_64 0:0.23-4.el6 will be installed
---> Package php-cli.x86_64 0:5.3.3-46.el6_6 will be installed
---> Package php-common.x86_64 0:5.3.3-46.el6_6 will be installed
---> Package php-pdo.x86_64 0:5.3.3-46.el6_6 will be installed
---> Package postgresql.x86_64 0:8.4.20-4.el6_7 will be installed
---> Package zlib-devel.x86_64 0:1.2.3-29.el6 will be installed
---> Package keyutils-libs-devel.x86_64 0:1.4-5.el6 will be installed
---> Package libcom_err-devel.x86_64 0:1.41.12-22.el6 will be installed
---> Package libselinux-devel.x86_64 0:2.0.94-5.8.el6 will be installed
--> Processing Dependency: libsepol-devel >= 2.0.32-1 for package: libselinux-devel-2.0.94-5.8.el6.x86_64
--> Processing Dependency: pkgconfig(libsepol) for package: libselinux-devel-2.0.94-5.8.el6.x86_64
---> Package perl-Net-LibIDN.x86_64 0:0.12-3.el6 will be installed
---> Package perl-SNMP_Session.noarch 0:1.12-4.el6 will be installed
---> Package unixODBC.x86_64 0:2.2.14-14.el6 will be installed
---> Package libsepol-devel.x86_64 0:2.0.41-4.el6 will be installed
Error: Package: nagiosxi-deps-5.2.3-1.noarch (/nagiosxi-deps-5.2.3-1.noarch)
           Requires: gd-devel
           Requires: perl-Config-Tiny
           Requires: rrdtool-python
           Requires: php-snmp
           Requires: php-mbstring
           Requires: perl(XML::Simple)
           Requires: rrdtool-perl
 You could try using --skip-broken to work around the problem
 You could try running: rpm -Va --nofiles --nodigest
RESULT=1
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './1-prereqs'
Reason: Please use [code][/code] tags around long output
Re: install error Error: Package: nagiosxi-deps-5.2.3-1.noa
Are you able to manually install any of the required dependencies? What happens if you run yum install gd-devel? Also, was this system used for anything before XI? Leftover packages from previous software can cause issues.
razaahmed
Post by razaahmed »
I was able to get resolve the issue. It was actually related to satellite system but now I am getting the following error. should I try "--skip-broken" option at this point?
Requires: gd-devel
Requires: php-snmp
RESULT=1
hsmith
Agent Smith
Post by hsmith »
tmcdonald wrote:Are you able to manually install any of the required dependencies? What happens if you run yum install gd-devel? Also, was this system used for anything before XI? Leftover packages from previous software can cause issues.
Can you please let us know if this works for you?
Former Nagios Employee.
me.
razaahmed
Post by razaahmed »
It's all working now.
Are we good to close this thread out then?
Muthulinux
Post by Muthulinux »
Could you please let me know how suddenly issue got resolved, since i am facing the same issue when i am installing the nagios XI in redhat linux 6.5?
Thanks in advance
hsmith
Agent Smith
Post by hsmith »
@ Muthulinux, can you please open a new thread describing your issue? This issue can be different across different machines. Please include the output of the installation failing in your new post, along with the output of a yum repolist command.
me.
Muthulinux
now i have installed the nagios XI by using offline method but i dont know the password of nagiosadmin to login into the web interface.
So i have changed the password by using below command
# htpasswd -c /usr/local/nagios/etc/htpasswd.users nagiosadmin
i got an output in the command line like below. even after that also i could not login into web interface getting username or password invalid.
New password:
Re-type new password:
Adding password for user nagiosadmin
[root@localhost conf.d]#
hsmith wrote:@ Muthulinux, can you please open a new thread describing your issue? This issue can be different across different machines. Please include the output of the installation failing in your new post, along with the output of a yum repolist command.
I'll be closing this thread out now, as it's resolved by the OP.
Please open a new thread for your issue, and we will address it. You should have seen an xi setup page though where you set the password for nagiosadmin. The command you mentioned, is to change the nagiosadmin password on core, not XI.
