No proformance graph to display.
eric.lin826
Hi !
When I set the "check interval" to 1440, I got no proformance graph to display.
Is there anyone can help me?
Nagios XI 5.2.3
CentOS 6.7 x64
Nagios XI 5.2.3
CentOS 6.7 x64
Re: No proformance graph to display.
Did you wait a day after making the change? If you changed that interval, it would need to collect new data.
Former Nagios Employee.
me.
me.
eric.lin826
Yes, I am already waiting for a few days.
Please refer to the attachment.
Many thanks!
Many thanks!
I've setup a test to replicate this, going to let it run until tomorrow morning so that I can see how this turns up.
Just to check, can you try disabling the Highcharts - do you see graphs after doing so? Here's what I'm seeing so far - To do so, navigate to Admin -> System Settings -> Theme & Display -> Uncheck 'Use Highcarts for Perfdata Graphs'
I'll follow up tomorrow once the check has run again as well.
eric.lin826
It still has nothing to display.
Was it affected by rra.cfg ?
If So, what can i do ?
It still appears that I am seeing no graphs, however in order to graph it will need a few points of data.I am trying to replicate this issue, and as the timing is every day - this will take some time to test.
I'll check back to this post towards the end of the week, and let you know how things are going on my end.
Following up on this, I still do not have any reports available after this amount of time.
I've filed a bug report for it, ID #7747.
eric.lin826
Hi
any updates ?
where am i could follow up the states?
any updates ?
Our developers made some notes:
1. Set:
in the "/usr/local/nagios/etc/pnp/process_perfdata.cfg" file.
2. Stop nagios and npcd.
3. Delete existing rrd and xml files for the service in question.
4. Start nagios and npcd.
5. Run at least one check against the service
6. Change back the "RRD_HEARTBEAT" and "RRA_STEP" values to the defaults:
and restart services:
Note: This is a hack (workaround), not an actual solution! I would NOT recommend it. Use it at your own risk.
I you REALLY want to monitor a service once a day and have graphs you can try the following:The (pnp4nagios) docs essentially state that any time event greater than RRD_HEARTBEAT won't be graphed.
1. Set:
RRD_HEARTBEAT = 86400
RRA_STEP = 864002. Stop nagios and npcd.
service nagios stop
service npcd stop4. Start nagios and npcd.
service nagios start
service npcd start6. Change back the "RRD_HEARTBEAT" and "RRA_STEP" values to the defaults:
RRD_HEARTBEAT = 8460
RRA_STEP = 60Code: Select all
service nagios restart
service npcd restartBe sure to check out our Knowledgebase for helpful articles and solutions!
eric.lin826
Thanks for your information sharing.
