{:timestamp=>"2016-01-28T09:56:02.408000-0800", :message=>"failed action with response of 400, dropping action: [\"index\", {:_id=>nil, :_index=>\"logstash-2016.01.28\", :_type=>\"syslog\", :_routing=>nil}, #<LogStash::Event:0x7e4cbf91 @metadata={\"retry_count\"=>0}, @accessors=#<LogStash::Util::Accessors:0xd7a2bec @store={\"message\"=>\" nagios : TTY=unknown ; PWD=/var/www/html/nagioslogserver/www ; USER=root ; COMMAND=/etc/init.d/logstash status\\n\", \"@version\"=>\"1\", \"@timestamp\"=>\"2016-01-28T17:56:01.000Z\", \"type\"=>\"syslog\", \"host\"=>\"0:0:0:0:0:0:0:1\", \"priority\"=>85, \"timestamp\"=>\"Jan 28 09:56:01\", \"logsource\"=>\"fptnaglsp1\", \"program\"=>\"sudo\", \"severity\"=>5, \"facility\"=>10, \"facility_label\"=>\"security/authorization\", \"severity_label\"=>\"Notice\"}, @lut={\"type\"=>[{\"message\"=>\" nagios : TTY=unknown ; PWD=/var/www/html/nagioslogserver/www ; USER=root ; COMMAND=/etc/init.d/logstash status\\n\", \"@version\"=>\"1\", \"@timestamp\"=>\"2016-01-28T17:56:01.000Z\", \"type\"=>\"syslog\", \"host\"=>\"0:0:0:0:0:0:0:1\", \"priority\"=>85, \"timestamp\"=>\"Jan 28 09:56:01\", \"logsource\"=>\"fptnaglsp1\", \"program\"=>\"sudo\", \"severity\"=>5, \"facility\"=>10, \"facility_label\"=>\"security/authorization\", \"severity_label\"=>\"Notice\"}, \"type\"], \"host\"=>[{\"message\"=>\" nagios : TTY=unknown ; PWD=/var/www/html/nagioslogserver/www ; USER=root ; COMMAND=/etc/init.d/logstash status\\n\", \"@version\"=>\"1\", \"@timestamp\"=>\"2016-01-28T17:56:01.000Z\", \"type\"=>\"syslog\", \"host\"=>\"0:0:0:0:0:0:0:1\", \"priority\"=>85, \"timestamp\"=>\"Jan 28 09:56:01\", \"logsource\"=>\"fptnaglsp1\", \"program\"=>\"sudo\", \"severity\"=>5, \"facility\"=>10, \"facility_label\"=>\"security/authorization\", \"severity_label\"=>\"Notice\"}, \"host\"], \"message\"=>[{\"message\"=>\" nagios : TTY=unknown ; PWD=/var/www/html/nagioslogserver/www ; USER=root ; COMMAND=/etc/init.d/logstash status\\n\", \"@version\"=>\"1\", \"@timestamp\"=>\"2016-01-28T17:56:01.000Z\", \"type\"=>\"syslog\", \"host\"=>\"0:0:0:0:0:0:0:1\", \"priority\"=>85, \"timestamp\"=>\"Jan 28 09:56:01\", \"logsource\"=>\"fptnaglsp1\", \"program\"=>\"sudo\", \"severity\"=>5, \"facility\"=>10, \"facility_label\"=>\"security/authorization\", \"severity_label\"=>\"Notice\"}, \"message\"], \"priority\"=>[{\"message\"=>\" nagios : TTY=unknown ; PWD=/var/www/html/nagioslogserver/www ; USER=root ; COMMAND=/etc/init.d/logstash status\\n\", \"@version\"=>\"1\", \"@timestamp\"=>\"2016-01-28T17:56:01.000Z\", \"type\"=>\"syslog\", \"host\"=>\"0:0:0:0:0:0:0:1\", \"priority\"=>85, \"timestamp\"=>\"Jan 28 09:56:01\", \"logsource\"=>\"fptnaglsp1\", \"program\"=>\"sudo\", \"severity\"=>5, \"facility\"=>10, \"facility_label\"=>\"security/authorization\", \"severity_label\"=>\"Notice\"}, \"priority\"], \"timestamp\"=>[{\"message\"=>\" nagios : TTY=unknown ; PWD=/var/www/html/nagioslogserver/www ; USER=root ; COMMAND=/etc/init.d/logstash status\\n\", \"@version\"=>\"1\", \"@timestamp\"=>\"2016-01-28T17:56:01.000Z\", \"type\"=>\"syslog\", \"host\"=>\"0:0:0:0:0:0:0:1\", \"priority\"=>85, \"timestamp\"=>\"Jan 28 09:56:01\", \"logsource\"=>\"fptnaglsp1\", \"program\"=>\"sudo\", \"severity\"=>5, \"facility\"=>10, \"facility_label\"=>\"security/authorization\", \"severity_label\"=>\"Notice\"}, \"timestamp\"], \"logsource\"=>[{\"message\"=>\" nagios : TTY=unknown ; PWD=/var/www/html/nagioslogserver/www ; USER=root ; COMMAND=/etc/init.d/logstash status\\n\", \"@version\"=>\"1\", \"@timestamp\"=>\"2016-01-28T17:56:01.000Z\", \"type\"=>\"syslog\", \"host\"=>\"0:0:0:0:0:0:0:1\", \"priority\"=>85, \"timestamp\"=>\"Jan 28 09:56:01\", \"logsource\"=>\"fptnaglsp1\", \"program\"=>\"sudo\", \"severity\"=>5, \"facility\"=>10, \"facility_label\"=>\"security/authorization\", \"severity_label\"=>\"Notice\"}, \"logsource\"], \"program\"=>[{\"message\"=>\" nagios : TTY=unknown ; PWD=/var/www/html/nagioslogserver/www ; USER=root ; COMMAND=/etc/init.d/logstash status\\n\", \"@version\"=>\"1\", \"@timestamp\"=>\"2016-01-28T17:56:01.000Z\", \"type\"=>\"syslog\", \"host\"=>\"0:0:0:0:0:0:0:1\", \"priority\"=>85, \"timestamp\"=>\"Jan 28 09:56:01\", \"logsource\"=>\"fptnaglsp1\", \"program\"=>\"sudo\", \"severity\"=>5, \"facility\"=>10, \"facility_label\"=>\"security/authorization\", \"severity_label\"=>\"Notice\"}, \"program\"], \"tags\"=>[{\"message\"=>\" nagios : TTY=unknown ; PWD=/var/www/html/nagioslogserver/www ; USER=root ; COMMAND=/etc/init.d/logstash status\\n\", \"@version\"=>\"1\", \"@timestamp\"=>\"2016-01-28T17:56:01.000Z\", \"type\"=>\"syslog\", \"host\"=>\"0:0:0:0:0:0:0:1\", \"priority\"=>85, \"timestamp\"=>\"Jan 28 09:56:01\", \"logsource\"=>\"fptnaglsp1\", \"program\"=>\"sudo\", \"severity\"=>5, \"facility\"=>10, \"facility_label\"=>\"security/authorization\", \"severity_label\"=>\"Notice\"}, \"tags\"], \"severity\"=>[{\"message\"=>\" nagios : TTY=unknown ; PWD=/var/www/html/nagioslogserver/www ; USER=root ; COMMAND=/etc/init.d/logstash status\\n\", \"@version\"=>\"1\", \"@timestamp\"=>\"2016-01-28T17:56:01.000Z\", \"type\"=>\"syslog\", \"host\"=>\"0:0:0:0:0:0:0:1\", \"priority\"=>85, \"timestamp\"=>\"Jan 28 09:56:01\", \"logsource\"=>\"fptnaglsp1\", \"program\"=>\"sudo\", \"severity\"=>5, \"facility\"=>10, \"facility_label\"=>\"security/authorization\", \"severity_label\"=>\"Notice\"}, \"severity\"], \"facility\"=>[{\"message\"=>\" nagios : TTY=unknown ; PWD=/var/www/html/nagioslogserver/www ; USER=root ; COMMAND=/etc/init.d/logstash status\\n\", \"@version\"=>\"1\", \"@timestamp\"=>\"2016-01-28T17:56:01.000Z\", \"type\"=>\"syslog\", \"host\"=>\"0:0:0:0:0:0:0:1\", \"priority\"=>85, \"timestamp\"=>\"Jan 28 09:56:01\", \"logsource\"=>\"fptnaglsp1\", \"program\"=>\"sudo\", \"severity\"=>5, \"facility\"=>10, \"facility_label\"=>\"security/authorization\", \"severity_label\"=>\"Notice\"}, \"facility\"], \"timestamp8601\"=>[{\"message\"=>\" nagios : TTY=unknown ; PWD=/var/www/html/nagioslogserver/www ; USER=root ; COMMAND=/etc/init.d/logstash status\\n\", \"@version\"=>\"1\", \"@timestamp\"=>\"2016-01-28T17:56:01.000Z\", \"type\"=>\"syslog\", \"host\"=>\"0:0:0:0:0:0:0:1\", \"priority\"=>85, \"timestamp\"=>\"Jan 28 09:56:01\", \"logsource\"=>\"fptnaglsp1\", \"program\"=>\"sudo\", \"severity\"=>5, \"facility\"=>10, \"facility_label\"=>\"security/authorization\", \"severity_label\"=>\"Notice\"}, \"timestamp8601\"], \"@timestamp\"=>[{\"message\"=>\" nagios : TTY=unknown ; PWD=/var/www/html/nagioslogserver/www ; USER=root ; COMMAND=/etc/init.d/logstash status\\n\", \"@version\"=>\"1\", \"@timestamp\"=>\"2016-01-28T17:56:01.000Z\", \"type\"=>\"syslog\", \"host\"=>\"0:0:0:0:0:0:0:1\", \"priority\"=>85, \"timestamp\"=>\"Jan 28 09:56:01\", \"logsource\"=>\"fptnaglsp1\", \"program\"=>\"sudo\", \"severity\"=>5, \"facility\"=>10, \"facility_label\"=>\"security/authorization\", \"severity_label\"=>\"Notice\"}, \"@timestamp\"], \"facility_label\"=>[{\"message\"=>\" nagios : TTY=unknown ; PWD=/var/www/html/nagioslogserver/www ; USER=root ; COMMAND=/etc/init.d/logstash status\\n\", \"@version\"=>\"1\", \"@timestamp\"=>\"2016-01-28T17:56:01.000Z\", \"type\"=>\"syslog\", \"host\"=>\"0:0:0:0:0:0:0:1\", \"priority\"=>85, \"timestamp\"=>\"Jan 28 09:56:01\", \"logsource\"=>\"fptnaglsp1\", \"program\"=>\"sudo\", \"severity\"=>5, \"facility\"=>10, \"facility_label\"=>\"security/authorization\", \"severity_label\"=>\"Notice\"}, \"facility_label\"], \"severity_label\"=>[{\"message\"=>\" nagios : TTY=unknown ; PWD=/var/www/html/nagioslogserver/www ; USER=root ; COMMAND=/etc/init.d/logstash status\\n\", \"@version\"=>\"1\", \"@timestamp\"=>\"2016-01-28T17:56:01.000Z\", \"type\"=>\"syslog\", \"host\"=>\"0:0:0:0:0:0:0:1\", \"priority\"=>85, \"timestamp\"=>\"Jan 28 09:56:01\", \"logsource\"=>\"fptnaglsp1\", \"program\"=>\"sudo\", \"severity\"=>5, \"facility\"=>10, \"facility_label\"=>\"security/authorization\", \"severity_label\"=>\"Notice\"}, \"severity_label\"], \"[program]\"=>[{\"message\"=>\" nagios : TTY=unknown ; PWD=/var/www/html/nagioslogserver/www ; USER=root ; COMMAND=/etc/init.d/logstash status\\n\", \"@version\"=>\"1\", \"@timestamp\"=>\"2016-01-28T17:56:01.000Z\", \"type\"=>\"syslog\", \"host\"=>\"0:0:0:0:0:0:0:1\", \"priority\"=>85, \"timestamp\"=>\"Jan 28 09:56:01\", \"logsource\"=>\"fptnaglsp1\", \"program\"=>\"sudo\", \"severity\"=>5, \"facility\"=>10, \"facility_label\"=>\"security/authorization\", \"severity_label\"=>\"Notice\"}, \"program\"], \"[host]\"=>[{\"message\"=>\" nagios : TTY=unknown ; PWD=/var/www/html/nagioslogserver/www ; USER=root ; COMMAND=/etc/init.d/logstash status\\n\", \"@version\"=>\"1\", \"@timestamp\"=>\"2016-01-28T17:56:01.000Z\", \"type\"=>\"syslog\", \"host\"=>\"0:0:0:0:0:0:0:1\", \"priority\"=>85, \"timestamp\"=>\"Jan 28 09:56:01\", \"logsource\"=>\"fptnaglsp1\", \"program\"=>\"sudo\", \"severity\"=>5, \"facility\"=>10, \"facility_label\"=>\"security/authorization\", \"severity_label\"=>\"Notice\"}, \"host\"], \"[type]\"=>[{\"message\"=>\" nagios : TTY=unknown ; PWD=/var/www/html/nagioslogserver/www ; USER=root ; COMMAND=/etc/init.d/logstash status\\n\", \"@version\"=>\"1\", \"@timestamp\"=>\"2016-01-28T17:56:01.000Z\", \"type\"=>\"syslog\", \"host\"=>\"0:0:0:0:0:0:0:1\", \"priority\"=>85, \"timestamp\"=>\"Jan 28 09:56:01\", \"logsource\"=>\"fptnaglsp1\", \"program\"=>\"sudo\", \"severity\"=>5, \"facility\"=>10, \"facility_label\"=>\"security/authorization\", \"severity_label\"=>\"Notice\"}, \"type\"], \"[prog]\"=>[{\"message\"=>\" nagios : TTY=unknown ; PWD=/var/www/html/nagioslogserver/www ; USER=root ; COMMAND=/etc/init.d/logstash status\\n\", \"@version\"=>\"1\", \"@timestamp\"=>\"2016-01-28T17:56:01.000Z\", \"type\"=>\"syslog\", \"host\"=>\"0:0:0:0:0:0:0:1\", \"priority\"=>85, \"timestamp\"=>\"Jan 28 09:56:01\", \"logsource\"=>\"fptnaglsp1\", \"program\"=>\"sudo\", \"severity\"=>5, \"facility\"=>10, \"facility_label\"=>\"security/authorization\", \"severity_label\"=>\"Notice\"}, \"prog\"]}>, @data={\"message\"=>\" nagios : TTY=unknown ; PWD=/var/www/html/nagioslogserver/www ; USER=root ; COMMAND=/etc/init.d/logstash status\\n\", \"@version\"=>\"1\", \"@timestamp\"=>\"2016-01-28T17:56:01.000Z\", \"type\"=>\"syslog\", \"host\"=>\"0:0:0:0:0:0:0:1\", \"priority\"=>85, \"timestamp\"=>\"Jan 28 09:56:01\", \"logsource\"=>\"fptnaglsp1\", \"program\"=>\"sudo\", \"severity\"=>5, \"facility\"=>10, \"facility_label\"=>\"security/authorization\", \"severity_label\"=>\"Notice\"}, @metadata_accessors=#<LogStash::Util::Accessors:0x759f0a7e @store={\"retry_count\"=>0}, @lut={}>, @cancelled=false>]", :level=>:warn}
