Good afternoon Nagios guys, Can I import snapshots from Nagios XI 2012R2.9 to Nagios XI5?
I'm trying but the file (.tar.gz) appears to be empty from the Nagios XI5 interface, If I extract the tar file all the ítems are there but if I try to import or view the file through the XI5 interface the txt file is empty.
any ideas?
Import Snapshots to NagiosXI5 from Nagios XI 2012R2.9
oscardlima
Re: Import Snapshots to NagiosXI5 from Nagios XI 2012R2.9
The recommended method is to spin up another server running 2012R2.9, import your configuration, and then upgrade the server.oscardlima wrote: Can I import snapshots from Nagios XI 2012R2.9 to Nagios XI5?
I would try my method I listed above.oscardlima wrote:I'm trying but the file (.tar.gz) appears to be empty from the Nagios XI5 interface, If I extract the tar file all the ítems are there but if I try to import or view the file through the XI5 interface the txt file is empty.
Former Nagios Employee.
me.
me.
