Just install Nagios XI and tried to configure to monitor two svrs.
First, mornitor DB01 server and resulted ok. Second, added AP01 using the same method but this time round wasn't check on SQL but only the IIS. in the Service Detail page it show me 1 error and mentioned AP01 SQL critical. Trying to remove this but when go to CCM - Service Management cannot found this.
Anyone encounter this?
Service monitor conflict
Re: Service monitor conflict
Yes actually. The names that are displayed are not the intuitive ones. They are perhaps meaningless and reflect the name of the file used to import them.
Check every entry(edit each one, but don't make any changes) looking for the service you'd want.
Hi, I were using the Run the Monitoring Wizard -> selected Windows Server -> from here you can check the IIS and SQL box to monitor, however i did not check the box of SQL but only the IIS, and why it appeared SQL?
I'll try this myself a little later. Though I can hardly call doing too much as being a problem, there should be some margin of error so I'd say I feel lucky the error was in the right direction.
I am unable to duplicate this. However it's not a bug rather a feature.
One thing to check is the Nagios Core service detail page.
/nagiosxi/includes/components/xicore/status.php?host=192.168.5.254
http://go.nagios.com/forum/374
