My nagios configuration is working fine for linux environment but when i try to configure windows host and go for nagios test i get below error.
Error: Unable to locate host 'hostname' for service 'C:\ Drive Space'
Error: Could not register service (config file '/usr/local/nagios/etc/objects/web-remote.cfg', starting on line 91)
whereas i have do mentioned the hostname in /etc/hosts file.
I'm able to ping the server and run the command manually.
command_name check_nt
command_line $USER1$/check_nt -H $HOSTADDRESS$ -p 12489 -s password -v $ARG1$ $ARG2$
#web-remote.cfg file
host_name hostname ; Name of this template
address x.x.x.x
use windows-server ; Inherit default values
check_period 24x7
check_interval 3
retry_interval 1
max_check_attempts 10
notification_period 24x7
notification_interval 30
notification_options d,r
contact_groups admins
register 0 ; DONT REGISTER THIS - ITS A TEMPLATE
#define host{
# use windows-server ; Inherit default values from a template
# host_name hostname ; The name we're giving to this host
# alias My Windows Server ; A longer name associated with the host
# address x.x.x.x. ; IP address of the host
# Create a service for monitoring the version of NSCLient++ that is installed
# Change the host_name to match the name of the host you defined above
host_name hostname
service_description NSClient++ Version
check_command check_nt!CLIENTVERSION
# Create a service for monitoring the uptime of the server
host_name hostname
service_description Uptime
check_command check_nt!UPTIME
# Create a service for monitoring CPU load
host_name hostname
service_description CPU Load
check_command check_nt!CPULOAD!-l 1,80,90
# Create a service for monitoring memory usage
host_name hostname
service_description Memory Usage
check_command check_nt!MEMUSE!-w 80 -c 90
# Create a service for monitoring C:\ disk usage
host_name hostname
service_description C:\ Drive Space
check_command check_nt!USEDDISKSPACE!-l c -w 80 -c 90
# Create a service for monitoring D:\ disk usage
host_name hostname
service_description D:\ Drive Space
check_command check_nt!USEDDISKSPACE!-l d -w 80 -c 90
# Create a service for monitoring E:\ disk usage
host_name hostname
service_description E:\ Drive Space
check_command check_nt!USEDDISKSPACE!-l e -w 80 -c 90
# Create a service for monitoring the W3SVC service
host_name hostname
service_description W3SVC
check_command check_nt!SERVICESTATE!-d SHOWALL -l W3SVC
# Create a service for monitoring the Explorer.exe process
host_name hostname
service_description Explorer
check_command check_nt!PROCSTATE!-d SHOWALL -l Explorer.exe
search4u2003
Re: Error: Unable to locate host
I have managed to resolve the issue now its working fine.
U can close this post.
