NRPE check_os
bwnikula
NRPE check_os
Post by bwnikula »
while attempting to run this command the result returned Windows 8 when the computer I was testing was running Windows 10. Is anyone else experiencing this issue on a windows 10 machine?
running the command
running the command
computer properties
computer properties
Re: NRPE check_os
What version of NSClient++ are you running?
bwnikula
Re: NRPE check_os
Post by bwnikula »
64bit version 0.4.4.15
hsmith
Agent Smith
Re: NRPE check_os
Post by hsmith »
Have you tried posting on the NSClient forums? NSClient is not our product, though it is heavily used by us. I'll see if I still have my Windows 10 virtual machine here, or if I blew it up. It's correctly reporting my Windows 7.
Former Nagios Employee.
me.
bwnikula
Re: NRPE check_os
Post by bwnikula »
thanks i'll do that as well.
hsmith
Agent Smith
Re: NRPE check_os
Post by hsmith »
Reproduced on 0.4.4.19.
[root@XI5 libexec]# ./check_nrpe -H 172.16.0.63 -c check_os_version
OK: Windows 8 (6.2.9200)|'version'=62;50;50
I'd file a bug report on his website.
me.
